20 Most Recent
Panasonic Wv-80 Wv-71 Kit Tv B/w Camera Vidicon W/ Lens Questions & Answers
I have a panasonic tv
Hello! You you cannot use the camera with a vcr. This camera needs vertical drive sync impulses from a dedicated monitor. The video signal, the vertical sync and the video signal are sharing the same coax cable. Best regards Gelu
WHERE DOSE POWER CORD GO
FOR A PANASONIC TV CAMERA WV-71
with this Camera, if I am not mistaken, you need a 24v ac power inducter. ( think that is the right name ). It will put the power in the coax that will feed the camera. Yes both video and power can be carried on the same wire at the same time.
NP-002-1 pinout
may i know exactly what your problem on your device?? kindly input some info here..
for initial help, take a look:
The switches are, from top to bottom:
- Sync selection switch (LL/INT)
- Electronic Light Control/Automatic Light Control selection switch (ELC/ALC)
- Detail level selection switch (SOFT/SHARP)
- Back light compensation on/off switch (BLC on/off)
- Lens selection switch (VIDEO/DC)
Download MANUAL
