20 Most Recent
Sony DSC-W510 Digital Camera Questions & Answers
How to format sony dsc 510
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Photos won't download to computer
Try NOT connecting your camera to your computer.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa (
http://picasa.google.com ).
Low playback sound
I have DSC W 510, but when I shoot something, like movie, you know, I hear strange sounds when I stop shooting, and play clip. I dont know why. Any help pls?
SETTINGS IN CAMERA FOR IMPORTING PICTURE AND VIDEO
The best way to download pictures and videos from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures and videos from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo/video cataloging program such as
Picasa.
WHEN I INSERT MY MEMORY
Hello there And Welcome to Fixya !
First of all there isn't any problem with your memory card or camera .
Take out the memory card from your camera and take a look at memory card , there will be a lock pin on the memory card .just unlock it with your finger cause it has a tiny knob
Do comment if it helps you in any manner
In my camara white color line is displsying on the
You have a bad LCD screen
If your camera is still under warranty, I will repair it for 35.00. If it is out of warranty, then I will fix it for 165.00
call Continental Photo, 718-268-6440 Mon - Sat 10am - 6pm, ask for vic
I bought my camera a week ago and it worked fine
Sounds like you have a defective camera. You might want to take the camera back to the place you got it and get a replacement. You can try removing and reseating the batteries to fix the problem.
The image size is just
Do not confuse image size with file size. Your camera is taking pictures with 12 million picture elements (pixels). When that image is stored on the memory card, the image file takes up about 4 million bytes, but still has 12 million pixels.
