20 Most Recent
Sony Cyber-Shot DSC-W570 Digital Camera Questions & Answers
My Sony dsc-w570 lens were
The gears inside are not stuck, in fact gears inside seems broken and camera needs new lens assembly replacement.
Turn the flash on
Sure your battery has enough power to charge the flash? charge the battery and try again.
How do i fix my phone dropped my phone in water
Dry your phone with simple towel. Then put your phone in a bag of rice for over 24 hours. Take out your phone and try to start it and see if it works. I am talking about phones in which battery can't be separated. If you could separate the battery then, dry it from outside then pull out the battery and dry gently inside then put it in a bag of rice overnight and start it next day.
Htc one how to dry it out after being drop in water?
If the battery can come out, pull it immediately to prevent further electrical and corrosion issues. If it landed in dirty water, you should rinse it off as it is already wet it won't hurt anything further.
After that there are a few options but the main goal it to be sure you get it all the way dry before turning it on again.
The last time my phone went in the water I put it in an OPEN ziplock bag full of rice then placed it by the heater.
If you are like me and it is hot enough in your house, you could turn your oven to it's lowest setting, 150 degrees or less, and leave your item in there for an hour or more. I would not turn it back on for at least a day or two. if you see and steam on the inside of the screen, it is not dry enough to turn on.
What to do if you drop your phillips mp3 in the water
I suggest you open up the unit as much as possible, then pack it in rice about 2 inches deep all around it in a box and let it sit for at least a week. The rice is good for drawing out moisture from anything. Russ
Flash does not always work
the flash light works only on low light environment, check your setup manu, change the setting to always flash if you need.
Sir/Mam, I had purchase Sony
Has it been dropped? I had a cabera that was dropped and the lense would not go all the way back in which caused the lense covers to not close.
Memory card locked
If it is a SD or SDHC memory card, there is a small write protect switch on the side of the card. Remove the memory card from the camera and slide the switch to the unlocked position.
How to apply date and time on a photo of sony DSCw570 after saving in the computer
The date and time (and a lot more) are automatically stored with every picture in its EXIF metadata. Any photo viewing/editing program should be able to display this data. To print this data, please consult the documentation for whatever program you're using to print your pictures. Depending on the program and printer you may print the date on the image, in the margins, or on the back.
The date and time (and a lot more) are stored with every picture in its EXIF metadata. Any photo viewing/editing program should be able to display this data. To print this data, please consult the documentation for whatever program you're using to print your pictures. Depending on the program and printer you may print the date on the image, in the margins, or on the back.
