20 Most Recent
Imation 1.5TB APOLLO EXPERT D200 USB HARD DRIVE Questions & Answers
Can not format portable hdd
Step 1: You have to be the computers Administrator to change any values on any Hard Drive on your computer. Click start control panel user accounts on the users tab click the name of the computer Administrator you must have full control. Click start click to open on my computer you should see your Usb drive E: or something right click select properties there will be an array of options select the sharing tab option then advanced sharing make sure you have a tick in the share this folder box then click permissions. Make sure all 3 boxes are ticked full control change and read in windows 7. Click start control panel user accounts click on the administrators account if you have made one or you will have to create one in windows XP. Click start right click on my computer select open Right click the icon of your Usb Drive (It should be E:/ or something) Click Properties in the menu that comes up Click the Sharing tab Click permissions And finally, click Allow next to Full Control. Click start click on my computer to open you should see your drive right click then select format another way Click start control panel administrative tools computer management disk management Right click on your usb drive select format.
Cannot format portable hdd
Step 1: When you connect an external hard drive or USB flash drive to your PC computer, the drive should appear in the "Computer" window. However, if the data on the drive is corrupted, you may receive an error saying that the disk is not accessible. In order to get the removable disk working again, you will need to boot up your computer using the Windows installation disk and then format the corrupted drive. Connect the removable disk to your computer. Insert the Windows installation disk into your optical drive and reboot the system. Press any key on the keyboard when you see the prompt asking if you want to boot to the CD. Press "Next" and then click on the "I accept the license terms" button. Click "Custom" when the program asks you what type of installation you want to perform. Click on the "Drive options (advanced)" button. The next window will display a list of all the hard drives connected to your computer. The removable disk will appear, even if its data is inaccessible. Highlight the removable disk that you want to format and then choose the "NTFS" option. Click "OK" to clear the data and format the hard drive.
Imation 8GB usb drive locked, how can i open it
5 Solutions to Remove Write Protected from Imation flash drive
- Solution 1:Turn off the write protected switch
- Solution 2: Clean up Imation USB flash drive
- Solution 3: Edit Windows Registry Key
- Solution 4: DiskPart command
- Solution 5: the Imation USB format tool
- Connect Imation USB with your computer
2/28/2024 3:36:15 PM •
Imation...
Answered
on Feb 28, 2024
No audio
Youtube has its own "mute/volume-control" level.
Unmute the video, and increase the volume-level.
6/21/2022 1:42:05 AM •
Imation...
Answered
on Jun 21, 2022
