20 Most Recent Canon A2200 Digital Camera Questions & Answers
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa ( http://picasa.google.com ).
Canon A2200... | Answered on Aug 06, 2013
Hello Phil, What did you do !!!! This is a serious problem that will be far beyond the average persons ability to fix, it takes a service tech with training and nerves of steel to work on these, kind of like watch repair.
Sorry for the bad news.
Best Regards, Russell
Canon A2200... | Answered on Jan 25, 2013
SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Canon A2200... | Answered on Jul 12, 2012
Turn the mode dial to P.Full details are in the "Shooting in Program AE" section beginning on page 84 of the manual.
Canon A2200... | Answered on Apr 16, 2012
Yes, particularly if the subject is back lit (sun or brightest areas are behind the subject). The flash will help fill (lighten the shadows) and balance the exposure. Use fill flash setting if your camera has it.
Canon A2200... | Answered on Mar 16, 2012
The camera is either set to a power save mode or the screen has failed.
Check your user guide for power save settings, if you don't have one, you should be able to download one from here:-
http://www.canon.co.uk/For_Home/Product_Finder/Cameras/Digital_Camera/PowerShot/PowerShot_A2200/
Canon A2200... | Answered on Mar 03, 2012
Press cursor-right (marked with a lightning bolt). Use cursor-left/right to select the lightning-bolt-in-a-circle-with-a-slash-through-it icon and press the OK button.
Full details are in the "Turning the Flash Off" section on page 56 of the manual.
Canon A2200... | Answered on Feb 17, 2012
The lens error indicates that the movement is inhibited possibly by sand or grit. It also may be misaligned or an internal component has failed. Look carefully between the lens and the camera body for any sand, dirt or any damaged etc.
Try turning the camera with the lens facing down and shake to dislodge anything stuck and try removing batteries and memory card. There are a number of things you can try:
- Ensure batteries are fully charged
- Look carefully between the lens and the camera body for any sand or other dirt etc
- Try turning the camera with the lens facing down and shake to dislodge anything stuck
- Try removing batteries and memory card, wait 2 minutes and refit
If no luck then we have to try some things that could possibly result in damaging your camera so should only be tried if happy to take that risk...
a. Try thumping the camera into your other hand, by thumping into your hand you are trying to jar the mechanism loose, by using your hand you will hopefully not do it too hard or it will hurt. You may need to do this a dozen or so times in different places to work. I have found the flat of the camera bottom into the flat of your hand best..
b. If the lens is stuck in the out position then remove the batteries and try twisting the lens first one way then the other, do not apply excessive force when doing this or you can break gears, you are trying to reposition not force... Likewise if the lens looks like it is crooked you can try pushing it back into position. This has a higher chance of doing more harm than the thump so please be careful...
c. Dismantle the camera, not for the faint hearted, you need to dismantle the lens assembly into the main body of the camera.
Additionally, here are a few links to some other things to try. With newer cameras I am usually hesitant to suggest these options since they include some more extreme procedures that may cause further damage if not done correctly, but since yours is probably no longer under warranty, they may save you an expensive repair bill. An older Canon camera is used to demonstrate these procedures but, the lens structure of these compact cameras is the same so the examples do apply to this unit. These procedures are effective about 60% of the time. Click on or copy and paste the links into your browser.
Lens Covers
* Lens FIX 1
* Lens FIX 2
Hope this helps to solve it.
Canon A2200... | Answered on Sep 27, 2011
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include "E18 lens error", or "lens error, restart camera". Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous interiors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many cameras, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particles that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in "no heat" setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Canon A2200... | Answered on Jul 18, 2011
I suggest check in this link, some tips about fixing-lens-error-on-digital-camera.
Hope helps.
Canon A2200... | Answered on Apr 24, 2011
okay 1 of 2 things is wrong i think A) the lens or that area is broken some where B) the screen is broken what you need to do is send it to canon so they can tell you what the problem is
if the screens broken buy one off the internet open the camera using a eyeglass screw driver or you will strip the screws look how the screen is connector flip the switch and take out and replace you screen the video that i have linked isn't your camera but the assembly and disassembly should be the same and so the screen changing i cant help you if its problem A) my only advice buy a new camera if cost effective or get it repaired
Canon A2200... | Answered on Apr 05, 2011
Canon A2200 Digital Camera Logo
34 questions posted
Top Canon Cameras Experts
old marine
old marine
Doberman
Ekse
Are you a Canon Camera Expert? Answer questions, earn points and help others
View Most Popular
Canon Cameras
  • Canon Cameras
Most Popular Question
lock memory card
  • Cameras
