20 Most Recent
Vizio XVT3D474SV 47 in. 3D LCD TV Questions & Answers
TV does not turn on.
You will not be able to see the fault with your eyes. You have replace the capacitor on power board or replace the power board.Sometime the value of the capacitors will change due to the heat produced by other components in the power supply. Its can make troubles. So try to replace the capacitors first rather than looking for physical damages.If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Vizio 3d tv just went dead. can't power on
The main power supply regulator section fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Search the site by type in the "
brand name" to your device; in the "
Search box at the top right of the display window of the Homepage" to get gathered related posts.
Right side screen is dark
Sounds like your screen is simply broken. See if you can get a different computer to test it out. If it's still like that, it's broken and you need to get a new one.
My remote just stopped working. I have put in fresh batteries. Any advice?
Check the remote control for its infra-red emission. Check it with fresh batteries. Check by pressing all the buttons on it; and see whether all of it generates infrared signal while pressing. If it is found OK, check and replace the infrared sensor inside the TV. If you wish to get some details; check the site linked here. It has details about how to check a remote control; by one among the post. Surf the site with patience. Pull up older posts.
http://electronicshelponline.blogspot.com/ If the remote control is found OK; check and replace the infra-red sensor inside the TV. Contact any service technician.
I GET NO PICTURE OR SOUND. WHY?
Fault with main board. Damaged component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Why is 1/2 of the screen dard
Back-light problem. Check and replace damaged component/s at its
back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the inverter board as card basis.
Backlight issue
Check the incoming power supply voltage to its back-light inverter, from main power regulator board. Check the main power regulator board.
3D video problem
3D decoding should be done by the PC card itself. If there is no decoding, there will be no 3D effect.
