20 Most Recent
Toshiba 55HT1U LCD TV Questions & Answers
Power light is on but no screen or sound
Check the main digital processor board. If
you wish to get more details, check this site linked below. Pull up older posts
there. Check the site with patience, as
it has over 2380 posts now. All are
related to electronic equipment repair help.
If you search the site in Timeslide option, which can be selected from
the drop down list at the top left of the display window, it will be easy to
locate the related post. You can also
do a search by type in the brand name to your device into its search box at the
top right of display window.
No picture or sound
In fact your TV is in dead condition. Troubleshooting should begin at main power regulator bard itself.
Visit the site named 'Electro-help' for
more details. Click this link. View it in
"Timeslide" or "Flipcard" option, which can be selected
from the drop down box menu by the [Sidebar] tag, at the top left corner
of the display window. You can also
click the [Home] tab to see the latest updates. It will make search
easy. There are more than 1350 posts to different brand TVs now. Pull up older
posts there.
Turn off internal speakers
This is usually a menu option that you can reach with your remote. I don't have this particular TV, but if you can turn them off, it is usually a menu configuration option. Hunt around with your remote until you find the configuration menu and look for the "sound" settings.If your TV has a headphone jack, try plugging a set of headphones into the TV to see if that disconnects the internal speakers. If it does, go to Radio Shack and buy an appropriately sized blank plug and just plug that in to the headphone jack to disconnect the speakers.
I OWN A 55HT1U Toshiba. We just bought it
The little LED light is it on. Also did you follow the suggesations in the users/owners manual. Can you bring up the menu froim the remote? Have you telephoned the warranty phone number in the manual
TOSHIBA 55HT1U only shows 480i
Your set will automatically be in the correct resolution. If your set is broadcasting in 480, then that is what it is receiving. I would check your cable or satellite box to verify they are putting out the correct resolution.
My Toshiba 55HT1U is showing
It is probably your video source. If you are using component video, some devices only output 480p.
Check the settings of your sources. The TV will display only what the device sends to it.
In most devices under a settings directory there will be settings labeled "Video" or "Resolution" Changing these settings to more appropriate High Definition resolutions should solve your problem.
Where do I plug in
Depending on the speakers you have, they'll have different inputs.
Some have an rca input, some have a coaxial or a digital optical cable.
Your tv has a digital optical output.
Simply purchase a digital optical cable and plug it in your tv and your wireless speakers.
You'll have to change the sound output of the television in the settings menu.
It'll be under the sound area.
