20 Most Recent
Belinea 1930 S1 Monitor Questions & Answers
How to switch from analog to digital mode
Any contemporary monitor is able to switch analog/digital mode automatically if connection from signal source to monitor is set up properly.Connect digital output from your graphic card to DVI input of the monitor. Disconnect any other signal cables from monitor and switch on both devices (PC & monitor). Wait a while. Monitor checks its inputs and a activates digital DVI, because it is only one active input on it.If none picture excluding error message of monitor is displayed, go through these steps:1) Check whether your monitor is set for automatic input selection. If monitor buttons have no response try to use analog input to activate screen (any picture, desktop background...) and then get monitor menu access by pressing menu button.2) Find out what connector type has your graphics card in PC. Possibilities are: DVI, HDMI, DisplayPort and some their options. See Wikipedia for connector look if you are not sure.Remember that blue D-SUB (VGA) connectors are analogue and you cannot activate digital mode through analog VGA cable.3) Use appropriate cable to connect monitor to PC.Example: Your PC has HDMI output. Use HDMi-to-DVI cable. Your monitor input is DVI and common DVI-DVI cable is not suitable in case you have PC with the HDMI.Note that DVI-to-DVI, DisplayPort-to-DVI etc. cables are available. You must buy right one.Be aware that "Auto" button is inactive in digital mode of monitor.
Lcd screen damaged needs replaced
If the screen has a cracked screen - then the LCD display needs to be replaced, but if it has a backlight problem then the fault could be the inverter or the CCFL lamp. These components are cheaper to replace instead of the whole screen.
Check out LCD parts for parts, service and DIY info. Use this link :-
www.lcdparts.net
9/10/2009 4:30:09 AM •
Belinea...
Answered
on Sep 10, 2009
Wireless not working
Make sure the wireless pickup for the laptop, integrated or separate is installed properly and is enabled. The laptop should have a function key (check your manual) like "FN". Pressing this key and usually a function key (F1-F12) should tell you if the wireless function if built in is enabled. If the wireless pickup is USB or a PCMCIA, check the installation again and make sure the hardware is compatible with each other. It's usually not a good idea to mix vendors like using a Linksys router with a Netgear pickup.
8/23/2009 11:14:53 PM •
Belinea...
Answered
on Aug 23, 2009
My Employer Says They Are Going To Cut My Wages. Can They?
If you are in the middle of a contract, then cutting your wages is almost certainly a violation of your employment law rights. While I am by no means an expert on this matter, I did have a similar issue years ago - mid-contract wage cuts - and I hired an
employment attorney to fight the case on my behalf. It turned out that my employer was basically looking to scare people into taking the wage cut.
They got into some pretty serious legal trouble for their transgression, and nothing happened to me in terms of wage cuts after that. If you are between contracts, your employer can re-negotiate your salary, but as far as I am aware, if you are in an agreed-upon contract, they cannot just decide to reduce your salary. If you want to settle matters, contest this action with support from a legal professional.
Solitaire master has a hang
clarify pi please. if you meant pi to mean main screen picture, you probably have used up your free time on this program.
