20 Most Recent
RCA RP-9316 Boombox Questions & Answers
When I want to play a CD the read out says ''rEAd''.
Its trying to read the cd. Sounds like you have a problem with a dirty laser or a incompatible disc. You can try getting some rubbing alcohol and a qtip dip one end of it in the alcohol and then rub it on the laser lens in a circular motion. Let the lens dry and try playing a cd again. Hope that helps.
CD Player Issue
the system has problems reading burned CD's
u cant fix it or anything
windman
The signal is not very good
Yes purchase an Y fm antenna wire, and attach spades to terminals on the back, if not available! attach one wire to antenna rod, and don't forget to put Y lead on the wall for maxium range.
How to get in to clean the lens for RP-9316 Boombox
I had the same issue. Over time, the cd player quit palying at all. The unit would try to read the cd but couldn't and then skip to the next cd.
- I took fairlane's advice and put a cd in and listened for the ticking sound to indicate that the laser was trying to read the cd. I also looked inside through the top "vent" area to be sure the cd was actually spinning. It was spinning and I heard what I thought I was "ticking" sound so I guessed that the laser needed to be cleaned.
- I took off the 6 side panel screws on the right side of the entire unit and loosened the screw on the backside off the unit about halfway down from the top that also held the side panel on.
- I then removed the side panel.
- I then removed the 2 screws on the top side of the other side panel and the screw in the top center back of the top panel and was able to remove the top cover that is over the unit. The top cover is "pressure fitted" in so be careful as you try to remove it, using a little wiggle at a time, but it does comes off.
- Once you have the top off, there is a screw in the center of the plate that holds the tray for the cd's. Remove the screw and you will able to lift and spin the tray to have clear access to the laser
that needs to be cleaned. (Note the position of the numbers on the tray so you put it back the right way.)
- The laser is a little "glassy" looking thing about the size of the head of the q-tip.
- I used the q-tip with 70% isopropol alcohol and rubbed it over and around the laser as best I could. I repeated the procedure 2-3 times and the used compressed air to dry it off.
- I put everything back in place in the reverse order I took it off, based on what's in the above steps.
- Remember, the top will fit in with pressure so don't get anxious as you try to get it in the right position.
The cd's actually play again.
I hope this will help someone.
My RCA home theater system,
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
1/15/2024 9:01:27 AM •
RCA Audio...
Answered
on Jan 15, 2024
Can I burn a CD from a tape on an RCA Model # 8530?
The RCA Model # 8530 appears to be a stereo receiver, which means it does not have the capability to directly burn a CD from a tape.
To convert a tape to a CD format, you would typically need a separate device called a cassette deck with a built-in CD recorder or a computer with the appropriate hardware and software.
If you have access to a cassette deck with a CD recorder, you can connect the RCA Model # 8530's tape output to the input of the cassette deck and then use the cassette deck's CD recording function to transfer the audio from the tape to a blank CD.
If you have a computer, you can use an analog-to-digital converter to connect the RCA Model # 8530's tape output to the computer's audio input. You can then use audio recording software on the computer to capture the audio from the tape and save it as a digital file. Once you have the digital file, you can use CD burning software to create a CD from the captured audio.
It's important to note that the specific steps and equipment required may vary depending on the exact models and setup you have. It's recommended to consult the user manuals for your devices and, if needed, seek additional guidance from the manufacturer or a knowledgeable audio technician.
6/18/2023 4:27:03 PM •
RCA Audio...
Answered
on Jun 18, 2023
Sub-out on Kenwood VR-6060 NOT Working with powered subwoofer
It seems like you've tried various connections and settings to get your JBL135 subwoofer working with your Kenwood receiver, but you're still facing issues. Let's break down the situation and provide some recommendations:
- Subwoofer Connection:
- Using the LFE/Subwoofer Out: This is the preferred method for connecting a subwoofer. Ensure that the cable is firmly connected to both the subwoofer's LFE input and the receiver's Subwoofer Out port. Make sure you have enabled the subwoofer output in the receiver's settings menu.
- Subwoofer Settings:
- Gain: Adjust the gain knob on the subwoofer to achieve the desired bass level. Experiment with different settings to find the right balance.
- Crossover: Set the crossover frequency on the subwoofer to blend with your tower speakers. Start with a conservative setting, such as 80Hz, and adjust as needed.
- Receiver Settings:
- Speaker Configuration: Set your tower speakers to "Small" in the receiver's settings menu to redirect bass frequencies to the subwoofer. This ensures that the tower speakers are not trying to reproduce deep bass.
- Bass Management: Enable the appropriate bass management settings in the receiver's menu, which typically includes crossover frequency and speaker size adjustments.
- Check Subwoofer Cable and Port:
- Ensure that the subwoofer cable is in good condition and securely connected to both the subwoofer and receiver.
- Try using a different cable or testing the subwoofer with another receiver if possible to rule out cable or port issues.
- Factory Reset:
- If you've exhausted all troubleshooting steps, you may consider performing a factory reset on your Kenwood receiver. This will reset all settings to their default values, potentially resolving any configuration issues.
If none of the above suggestions work, it's advisable to consult the user manual for your specific Kenwood receiver model or contact Kenwood customer support for further assistance. They can provide more detailed guidance based on your equipment and setup.
6/18/2023 4:25:51 PM •
RCA Audio...
Answered
on Jun 18, 2023
