20 Most Recent
Arris Touchstone 450a (CM450) Modem Questions & Answers
No driver for my modem
There are no drivers for the arris cable modem unless you are using USB.
If you are using ethernet then it is simply plug and play. You may need to press the reset button on your arris.
Thank you.
Pulse-dialing with Arris modem?
If you have the current firmware for your modem, it should work with pulse. Arris had to make it's MTA's pulse compatible due to old alarm systems that still utilize pulse dialing.
What does it mean when the far ethernet light is
Try this:
- Disconnect power to modem
- Disconnect power to router
- Shut down PC
- Wait 2-3 minutes
- Reconnect power to modem, and wait ~ 1 minute
- Reconnect power to router, and wait 30-60 sec.
- Reboot PC
- Try to reconnect to internet...
When the modem is hooked
Tyr to power cycle the router and modem. First, make sure router is plugged into modem. Unplug power cord from both devices. Plug in the modem first, let it boot all the way up first. Then Plug in router and wait for it to boot up. Check your internet connection. If there is still an error message, make sure on the back of the router you have the Ethernet cord from the modem plugged into the input port of the router. I’m happy to help further over the phone at
https://www.6ya.com/expert/charles_50dc26066e33d587
I have an Arris modem
comcast use 10.0.0.1 for ip address, I think
check direct tv box for internet settings for it's ip address should 10.0.0.2 maybe call directv maybe they could further.
Configure IP
If you are a well known person about the configuration of your modem you can reset your modem configuration yourself. But if you are not, go with any experts or technical person or user manual to do it. After resetting it check your IP address using the site
Ip-Details.com .
Link light blinking
On these cable modems the link light is supposed to blink when you are connected to a router/pc. If you are hooking up a wireless router new you need to power cycle/reset your cable modem before you hook up the wireless router so that way it can refresh its ip address.
Switched to cable(arris modem) can't set up network
cable dsl same thing. Did you switch providers and get new modem from them? If so. Just delete previous netowrk and install new one let pc discover new one. Also, with your router you got a disc. It should install correctly. Perhaps it is previous network that is hindering you.
