20 Most Recent
Coco Android 2.1 Tablet (837121001186) Questions & Answers
Android mid tablet passwords help
With any Android 2.1 device you should be able to manage any account passwords through the Settings - Accounts menu (from the main screen, menu button, then go to settings, then to Accounts)
When switced on android sits
The green android guy is in the middle and it doesn't change after even the longest of times?
Well then this might be a factory defect, because this means the Android Stock OS isn't installed properly.
The only way to fix it would be to void the warranty, and that's the last thing we want.
All ways to bypass a locked screen in panigram
If you swipe the pattern wrong 5 times Android should pop up an option to wait for a timeout with a button that says "forgot pattern". If you click on that button you should be able to type in the Google account info that the system is setup on and it should put you right in.
Forgot how to unlock screen pattern drawing
hi their i forgotten the pattern code for my Midi Tablet PC'7 tipical when going to an area with Wif-Fi i cant access it now! PLEASE PLEASE Can you help me, the pattern i thought is NOT right :C Thank You ....
Unlock cruz tabletT301 screen
I think you need to hard reset your tablet so that it can be use again. NOTE: THIS WILL DELETE YOUR PERSONAL FILES. You need to access the restore menu on your device. Get a paper clip and hit the reset button on the top of the tablet. As soon as you release the reset button hold the + vol button down. This will bring you to the menu you need. Select wipe and restore to factory defaults NOTE: THIS WILL DELETE YOUR PERSONAL FILES. Once its done reboot and it`s ready to roll.
Hope this helps.
Crack screen
Nowadays, a number of replacement screens for tablets are in the markets, maybe you can look for the right one for your tablet or cell phone. Here recommend a online shop for reference: hytparts.com
