20 Most Recent Toshiba Satellite C655D-S5120 Notebook Questions & Answers
How do i disable touch pad when mouse is in use
      Click the "Start" button and click "Control Panel." Click "Hardware and Sound" and click the "Mouse" link under Devices and Printers to open the Mouse Properties box. Click the "Touchpad" or "Buttons" tab depending on your PC, then select the "Disable" option next to thetouchpad installed on your computer.
      How to Disable TouchPad While the USB Mouse Is Plugged in
      smallbusiness.chron.com/disable-touchpad-usb-mouse-plugged-52685.html
    Feedback
    How To Turn Off Touchpad When Mouse Is Connected In ...
    www.intowindows.com > Windows 10
    Dec 14, 2015 - How To Turn Off Touchpad When Mouse Is Connected In Windows 10/7/ ... who always use a mouse and don't want to use the built-in trackpad ...
    How to Disable Your Laptop Touchpad ' PCWorld
1/31/2016 9:16:37 PM • Toshiba... • Answered on Jan 31, 2016
Touchpad was replaced an now there is no way to
Synaptic makes most mouse pads, try a different driver from them depending on the identified hardware. Remove the old drivers.
1/11/2015 11:57:50 PM • Toshiba... • Answered on Jan 11, 2015
0answers
My Toshiba Satellite c655d web cam says locked by
check the anti virus or your windows firewall,if they are not the cause,uninstall suspicious pro grams...
11/21/2013 10:44:37 PM • Toshiba... • Answered on Nov 21, 2013
Toshiba c655d - s5200 wont start up. i get a black screen that says no bootable disk
sounds like you have a bad hard drive,,try putting a bootable cd and start it like that,or at the start up hit the f2 key and go into the setup and seee if there is a hard drive loaded
9/13/2013 3:43:28 PM • Toshiba... • Answered on Sep 13, 2013
Keyboard wont work
Have you been to the repair center yet?
1/24/2013 5:28:00 PM • Toshiba... • Answered on Jan 24, 2013
I am getting an error message that reads BOOTmgr is missing. I have a Toshiba Satellite C655D
Change the boot startup order back to the hard drive as the first boot device in the BIOS. If you still have this problem then -Go to this WEB site to fix Bootmgr is missing problem.http://pcsupport.about.com/od/findbyerrormessage/a/bootmgr-is-missing.htm
3/30/2012 7:15:12 AM • Toshiba... • Answered on Mar 30, 2012
Why is my brand new laptop satellite c655d-s5529 keep on saying toshiba mq01abd032 sata disk device the following hard disk are reporting failure
Take the laptop back "asp" you should not be getting messages on the screen, it indicates device issue and maybe a bigger problem.
3/7/2012 4:01:47 PM • Toshiba... • Answered on Mar 07, 2012
2answers
Hi i want to
To turn Windows Sidebar off:
vista_sidebar_icon.jpg 1. Right-click the Windows Sidebar icon on the taskbar (it looks like the image to the left). If you do not see this icon, click the "Show Hidden Icons" arrow (it looks like the image to the right), then right-click the Windows Sidebar icon.
2. To temporarily disable the Windows Sidebar, click "Exit". Or, to permanently disable it:
* Click "Properties"
* The "Windows Sidebar Properties" dialog box will appear. Uncheck "Start Sidebar when Windows Starts".
* Click "OK".
* Finally, right-click the icon again and click "Exit".
To turn Windows Sidebar on:
1. Click the Windows button on the taskbar, enter "sidebar" (without quotes) and press the Enter key.
2. Now, if you want to permanently enable the sidebar when Windows starts:
* Right-click the Windows Sidebar icon, choosing "Properties".
* The "Windows Sidebar Properties" dialog box will appear. Check "Start Sidebar when Windows Starts".
* Click "OK".
8/14/2011 7:39:54 PM • Toshiba... • Answered on Aug 14, 2011
Have a app 3 month
Hi! Welcome to www.fixya.com.
1. Copy all your files and documents to an external storage device. 2. Shut down the computer. 3. Turn the PC back on and hit the F8 key repeatedly until the Advanced Boot Option Screen appears. 4. Click "Repair Your Computer" if you are not already on it and then press ENTER 5. choose your country and click OK 6. On the "System Recovery Options Screen" click "Restore Application" which is the last option. 7. Follow the on-screen instructions 8. When prompted, click on "Full Factory Recovery" 9. "Next" 10. Click "Yes" 11. you will notice for a while it seems like nothing is happening, give it some time. 12. After some minutes, recovery will complete and you click "Finish"
Hope this resolution fix the problem on your computer. Thanks for contacting Fixya. Bye for now.
7/27/2011 12:41:08 AM • Toshiba... • Answered on Jul 27, 2011
3answers
Is the product key for Microsoft office 2013 the same as all product keys for 2013 Microsoft offices that operate under laptops using windows 8.1?
The product key is associated with the MS Office 2013 software, not the specific MS Windows version of Operating System - unless the MS Office lists a minimum version of OS ie: "Windows 8.0" In this case, it would not install on Windows 7. Otherwise, you should be able to install it on Windows 7, Windows 8, or later.
2/15/2024 4:30:57 PM • Toshiba... • Answered on Feb 15, 2024
Japanese Visa Application with COE denied. Why?
How to Get Employment Security With Correct Japan Work Visa Japan is no different from other developing nations whereby grass seems greener on its side of the pasture. It attracts its fair share of foreign businesses as well as nationals seeking to work within its lands. Albeit many adhere to immigration procedures, some choose to test their limits on the basis of ignorance or defiance. By understanding the different types of work visa in Japan, it assures its foreign workers a continual stream of income with no threat of arrest and deportation. Visa simply infers the status of residence. Citizens obviously have no need of it as they automatically satisfy qualifications to freely reside in their country of birth. As for those of alien status who wish to join the local workforce, there should be a category to match one's requirement. Since most countries strive to improve the overall quality of life, professionals are generally welcomed to contribute knowledge and skill. Unskilled labor is normally not granted a visa to avoid flooding and dilution of the workforce. The visa is awarded in accordance to one's area of expertise. Supported with proof of relevant experience, it is based on the field of involvement whilst working in the country. In the event one's work scope changes from one expertise to another, it is essential to apply for a visa under the new circumstances. Different types of work visa in Japan also apply to foreign companies seeking to conduct local business. Domestic companies based abroad wishing to set up a local point of presence need to provide supporting documents to justify internal transfer of foreign workers. Governmental staff for diplomatic duties is assigned a category for legal residence. Over and above the general groupings, designated activities also garner approval from the authorities. Domestic service for non-native residents and citizens of certain nations on working holidays fall into this category of working visa. This, by no means, is the end of the list as it is best to consult the authorities on which visa serves best.Click Here For More Details: http://japanjobandvisaservice.com/blog/change-your-luck-when-apply-work-visa
5/22/2023 2:52:35 PM • Toshiba... • Answered on May 22, 2023
HOW TO ENABLE TOUCHPAD ON TOSHIBA SATELLITE a665-S6080
In BIOS, I made Pointing Device Enable and It has been done.
11/28/2022 9:05:08 AM • Toshiba... • Answered on Nov 28, 2022
2answers
Hello I have a Toshiba E45 B4200 and the OS is lock with a password and I don't know the password I can't use it and I don't know what to do please help me my phone number is +509(REMOVED) I have What
Question edited to remove phone number. Never do that!! We have 12 million views here a year or which 5% are scammers. Question moved from Toshiba Televisions to computers. Take it to a computer shop and they will take it apart and fix the motherboard to remove the BIOS Password.
3/22/2022 12:20:21 PM • Toshiba... • Answered on Mar 22, 2022
2answers
No picture on videos on my laptop
They are created with different encoding and Windows Media PLayer doesn't decode all so-called CODECs by default. Go to videolan.org and download the VLC media player. It can play about any video you can throw at it. VideoLAN VLC Official site Free multimedia solutions for all OS
2/13/2022 1:00:17 PM • Toshiba... • Answered on Feb 13, 2022
3answers
How to play dvd movie
use VLC it plays everything it even has extensions like subtitle downloader. VideoLAN Official page for VLC media player the Open Source video framework
11/11/2021 2:57:22 AM • Toshiba... • Answered on Nov 11, 2021
Unlock Region Code
No problem How to Make Toshiba DVD Player Region Free
  1. Press the power button on the Toshiba DVD player remote. Press the "Open/Close" button to eject the disc tray. ...
  2. Press the following keys on the remote in this order: 2,4,0,3,9,6,0.
  3. Press the "9" key on the remote.
  4. Press the "Open/Close" button to close the disc tray.
How to Make Toshiba DVD Player Region Free ' Techwalla
https://www.google.com/search?q=Unlock+Region+Code%2C+Toshiba ..
9/29/2021 4:28:11 AM • Toshiba... • Answered on Sep 29, 2021
Toshiba Satellite C655D-S5120 Notebook Logo
17 questions posted
Top Toshiba Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Satellite Toshiba
  • Satellite Toshiba
Most Popular Question
want
  • Computers & Internet
