20 Most Recent Battery Biz Battery-Biz CANON E230 Camcorder battery Questions & Answers
tip
Battery not Charging
Battery Charger Troubleshooter
When there is a battery failure, there is a possibility it was caused by a bad battery charger. When the charger is only plugged into the wall, it should show a green light. If there is no light showing, confirm that the outlet is good. If the outlet is good, it is very possible that the issue is with the battery charger, not the battery. If the charger is plugged into the battery only, it should show a green light. (If you have purchased a new charger within the last year, you will not get a green light if the charger is only plugged into the battery. You will get a green light however if the wall charger is just plugged into the wall and not plugged into the wiring harness) If it does not show a green light, it is likely that the charger is not making contact with the battery. The most likely reason for this is a faulty fuse on the wiring harness. This fuse is a 2-amp automotive fuse, and it should be replaced with a 2 or 3-amp fuse available anywhere that sells auto parts. The fuse can blow out if there is a short in the charging system, or if the plug-in end of the wiring harness comes in contact with a battery terminal. When the charger is plugged into both an electrical outlet and the battery, there should be a red light showing on the charger. A red light showing indicates that the charger is in contact with the battery and is actively charging the battery. Once the battery has reached a voltage level that is considered "fully charged" the red light changes to green. If after 24 hours the light has not changed to green there is no cause for alarm! Remember that when the light is red, the battery is being charged, and you will be able to use your system. After 24 hours or so, your battery is as charged as it is going to get, and if the light is still showing red you should disconnect the charger and go fishing. Replacement chargers and parts can be purchased directly from MarCum's website. If you are really concerned about your battery, consider getting a basic volt meter to check the voltage of your battery. They can be bought for less than 20 dollars and will show you exactly what the voltage level of your battery is. If after 24 hours of charging your battery should have at least 12 volts (ideally 13-14 volts) and as long as it is over 12 volts it will work. If it is not at or above 12 volts you should consider replacing the battery. If your unit starts to malfunction while you are fishing, it would not come as a surprise that the voltage has dropped down to 11 volts or lower. If the charger is plugged into the wall and battery, and you get a blinking light on the charger, it is very likely that the battery is faulty and should be replaced. Batteries are an expendable item, and must be replaced periodically. Any store that sells ice fishing electronics will stock suitable batteries. You can also buy them at a specialty battery store, or by ordering one from our website.The batteries that you should use are the "Sealed Lead Acid" variety, they are 12 volts, and range from 7 to 9 amps. The more amps the battery has the longer it will run on a full charge. Your MarCum unit can be powered off of any battery that is 12 volts, even a large automotive or deep cycle batteries will work.
on Jun 14, 2018 • Battery Biz Cameras
3answers
How do i know that this battery is best for my digital camera?
Digital cameras should have nickel metal hydride (NI-MH) for long life usage. Ordinary alkaline batteries have no service life in digital cameras
3/16/2017 3:30:02 PM • Battery Biz... • Answered on Mar 16, 2017
2answers
Which battery is better for cameras backup?
Normally, for Panasonic brand you have to use Panasonic original batteries for better backup. You have to buy newly branded batteries such as Panasonic, Kodak or Energizer in very reasonable rates. I suggest you check this link. http://www.batterywarehouse.co.uk
1/27/2015 5:42:23 AM • Battery Biz... • Answered on Jan 27, 2015
Digital Harinezumi 2++ won't turn on
It is not well thought of and considered a toy. https://www.google.com/search?q=digital+harinezumi+2+won%27t+turn+on ..
4/20/2024 12:20:14 PM • Cameras • Answered on Apr 20, 2024
My open view is not showing any pictures but showing information about programs playing what might be the problem
Some steps you can try: Check Picture Location: Ensure that the pictures you want to view are in the same folder location. Sometimes, if the images are scattered across different folders, they may not appear correctly in the photo viewer. Repair or Reset the Photo App (for Windows 11): Go to Settings > Apps > Photo. Click on Advanced options. Choose either Repair or Reset to address any potential issues with the Photo app. Enable Thumbnail Previews (for Windows 10): Open File Explorer Options: Type "file explorer options" in the Windows search bar and select the first result. Switch to the View tab. Ensure that the option "Always show icons, never thumbnails" is unchecked. Click Apply and then OK to save the changes. That is about all I can offer. If you repost, include brand and model.
4/19/2024 8:18:20 PM • Cameras • Answered on Apr 19, 2024
2answers
I forgot the combination to my safe can i reset it
limited info generic answer notify manufacturer or locksmith for assistance
4/16/2024 7:20:17 PM • Cameras • Answered on Apr 16, 2024
Activition code digital tv 2050
Free version does not require activation, but unsure if that will work for you. Web site specifically states there is not any activation code and not supported. All of its software is "free, freeware, shareware, full version, trial, demo or open-source" https://www.download.hr/software-digital-tv-2050.html
4/15/2024 9:02:35 PM • Cameras • Answered on Apr 15, 2024
INTERNAL ERROR FREEGROMRIGHT SIZE 1431655766
I don't see anything that resembles 'make model (what it is)'. You posted to the category Cameras? https://www.google.com/search?q=FREEGROMRIGHT+SIZE+1431655766 ..
4/5/2024 1:31:05 AM • Cameras • Answered on Apr 05, 2024
2answers
Where can I get Manual for novar ed&s wireless colour camera
if you purchased the camera from a retailer or reseller, they may have a copy of the manual available.
4/4/2024 12:04:13 AM • Cameras • Answered on Apr 04, 2024
How do you turn on Digivue1.3? Has new batteries and used a while ago but pressing 2 button (Mode, Set) do nothing.
This is going to take patience and maybe the user guide. To turn on the Digivue 1.3, follow these steps: Connect to Your PC: Connect the standard USB cable (supplied) to a free USB socket on your PC. The end of the USB cable should be connected to the socket on the back of the USB digidock. Important: Do not connect any of the cabling provided with the Digivue before commencing the software installation. Install DigiConnect Windows® Software: Insert your Digivue into the docking station. If you are connecting for the first time, a Red LED will display in the Activity Window of the Digivue. Insert the CD provided into your optical disk drive. It will run automatically, and a dialog box will appear. If the autorun feature is disabled on your system, browse to the disk using Windows® Explorer and double-click Setup.exe. If you have a multilingual version of Digiconnect, you will be prompted for your language. Select from the list and click "Next." Accept the terms in the License Agreement and proceed with the installation. Choose the folder for software installation (default is the standard location for Windows® programs). Click "Install" to begin the installation. Leave the box labeled "Launch DigiConnect" ticked and click "Finish." Wait for the Red LED: Wait until a RED LED appears in the activity window of the Digivue. You may now proceed with the next steps. If you encounter any issues during this process, refer to the detailed instructions in the Digivue User Guide on page 9
4/1/2024 1:04:02 PM • Cameras • Answered on Apr 01, 2024
Hello, I would like to know how to solve an error called "ALLARME" "sicur camera"??
Reboot everything. If that doesn't work, Maker Support.
SICUR SERVICE ITALIA
SICUR SERVICE ITALIA https://www.sicurserviceitalia.it ·Translate this page 1.3 MP Camera · 2 Mega Pixel Camera · 3 Mega Pixel Camera · 4 Mega Pixel IR Camera · 5 Mega Pixel IR Camera · 12 Mega Pixel Camera · Speed Dome da esterno ... ..
3/15/2024 2:12:47 PM • Cameras • Answered on Mar 15, 2024
2answers
Which is the best weding photographer in ernakulam
Here are some highly regarded wedding photographers in Ernakulam, Kerala:
  1. Maks Wedding Photography:
    • Located inChelad, Kothamangalam, Kerala.
    • Specializes inwedding photography and videography.
    • Contact:099478 23133.
    • Facebook Page
  2. Lumiere Wedding Company:
    • Based in Ernakulam, Kerala.
    • Their crew beautifully captures emotions during the D-day, creating elegant pictures that will remain etched in your heart forever.
    • They cover weddings not only in Ernakulam but also in UAE, Malaysia, and other parts of the globe.
    • Contact:099951 48014.
    • Website
  3. Euforia Wedding Photography:
    • Located atUzhinjelil Tower, Convent Rd, Ponnurunni, Vyttila, Kochi, Kerala.
    • Offers candid and artful wedding photography packages.
    • Cherish the vibrant traditions and colors of your Kerala wedding with their skilled team.
    • Contact:090481 90403.
    • Website
  4. Dakshin Wedding Services:
    • Exclusive wedding photography and videography company covering events across South India.
    • Address:Js 5, 5th Floor, Heavenly Plaza, Kakkanad, Edappally, Civil Line Road, Ernakulam, Kerala.
    • Contact:070123 90551.
    • More Information
Remember to explore their portfolios, discuss your preferences, and find the photographer whose style resonates with your vision for capturing your special day! These companies use teams. It is difficult to pick out an individual photographer but perhaps you might find what you are looking for at the Lumiere Wedding Company. That company stands out among the four I mentioned.
3/15/2024 10:38:43 AM • Cameras • Answered on Mar 15, 2024
Hi, I am in Dubai,I
FUJIFILM MIDDLE EAST FZE [Subsidiary] Business Field (s): Digital Cameras
Address: P.O. Box 17212, R/A08, HB03, Jebel Ali, Dubai, U.A.E.
Tel: 971-4-883-9990
GRAND STORES [Distributor] Business Field (s): Photographic Film and Paper, Film Cameras, Digital Cameras, Digital Printers, Minilab Systems, Medical Systems
Address: Saleh Mohammed Bin, Lahej Building, Al Garhood, P.O. Box 2144, Deira, Dubai, U.A.E.
Tel: 971-4-2-823700
Dynagraph For Printing Industry [Distributor] Business Field (s): Graphic Systems
Address: Al Quoz Industrial Area, Sultan Al Suwaidi Building, Office No.1, Dubai, U.A.E.
Website:
3/14/2024 5:17:47 AM • Cameras • Answered on Mar 14, 2024
Hi, Have replaced batteries on model Gardenline brand model46715 garden timer and there is no digital screen showing on the timer. It is blank, like it needs new batteries.Can you please help me? Russ
Here are some steps you can take to diagnose and potentially resolve the problem: Check Battery Polarity: Ensure that the batteries are inserted correctly, with the positive (+) and negative (-) terminals aligned properly. Sometimes a simple reversal of the batteries can cause display issues. Reset the Timer: Some electronic devices benefit from a reset. Try removing the batteries, waiting for a minute, and then reinserting them. This action might reset the timer and bring the display back to life. Inspect the Battery Compartment: Look for any signs of corrosion or dirt in the battery compartment. Clean it gently using a cotton swab or a soft cloth. Corrosion can disrupt the electrical connection and affect the display. Test with Fresh Batteries: Even if the batteries are new, they might be defective. Try using a different set of fresh batteries to see if the display turns on. Check for a Backlight or Contrast Setting: Some timers have adjustable backlight or contrast settings. If your model has this feature, try adjusting it to see if the display becomes visible. Contact Customer Support: If none of the above steps work, consider reaching out to the manufacturer's customer support. Remember that the Gardenline brand model 46715 has received mixed reviews, with some users reporting issues related to the LCD screen. While some have had positive experiences, others have encountered problems like fading screens or dead displays . If none of this works, you may need to explore another timer.
3/13/2024 2:39:50 AM • Cameras • Answered on Mar 13, 2024
What type of battery does my TVG it has two batteries
All question need 'make model (what it is) as first 3 words or this happens https://www.google.com/search?q=What+type+of+battery+does+my+TVG+have Guessing is is a mobility scooter, but even so. Google know all the answers, your search query would be make model battery replacement Or just look at what is one the existing ones if you have them. Or Google make model manual Everything is online and my skill is finding stuff. ..
3/13/2024 2:19:59 AM • Cameras • Answered on Mar 13, 2024
The pop-up flash does not flash when taking a picture.
'make model (what it is)' is useful in questions like this!
How to fix the popup flash on your camera (Canon DSLR)
Tutorial Geek https://www.tutorialgeek.net > 2013/02 > how-to-fix-pop... Put the camera into Automatic mode and pry your fingernail under the flash (see the photo above). Right now the flash is locked, so you will not be able to ...
Why doesn't my D3100 take photos when the built in flash ...
Photography Stack Exchange https://photo.stackexchange.com > questions > why-doe... Feb 18, 2023 - I have a Nikon D3100. It doesn't take pictures while the built in flash is popped up, but is working fine when the flash is down. What could be ... 1 answer · 2 votes: I'm guessing that the exposure settings are significantly different (darker) when the flash is up because it is expecting the flash to add a lot of light. ... What to do when my pop-up flash doesn't work after being ... Mar 25, 2013 nikon - Why is my dSLR's pop-up flash not firing? Dec 29, 2019 Why won't my D3100 take flash pictures even when focused? Jan 21, 2013 Why doesn't my Nikon D5200 pop-up flash fire in manual mode? Dec 27, 2016 More results from photo.stackexchange.com ..
2/29/2024 7:06:29 PM • Cameras • Answered on Feb 29, 2024
How do l change the language of my Kenwood MDV-626DT from Japanese to English
There are some videos and the procedure is similar. The easy way is to use a Smartphone with the Google Translate app and use the Camera feature to translate what you are seeing onscreen. Also note that some models are made for the Japanese Market and only come in Japanese. ..
2/28/2024 4:24:24 AM • Cameras • Answered on Feb 28, 2024
Battery Biz Battery-Biz CANON E230 Camcorder battery Logo
1 questions posted
Top Battery Biz Cameras Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you a Battery Biz Camera Expert? Answer questions, earn points and help others
View Most Popular
Battery Biz Cameras
Most Popular Question
battery better cameras backup
  • Cameras
