20 Most Recent
Seloc Johnson Outboards 2002-2007 Repair Manual Questions & Answers
What is the gas mixture for a 9R-70C?
What a neat little fisher motor. All needle bearing motor so you can run it on 50/1 --would use synthetic for the best operation. Take care of that starter spool- slowly engage the plastic gear to the flywheel before you pull the starter for the start.
Johnson 4hp starts first pull runs 5 minutes dies will then only run with choke on
You may have left the fuel vent closed. If working, put a clear plastic fuel line between the fuel pump and the carb. Look for bubbles indicating an air leak between the tank and the carb.On a rear occasion you can have some varnish flakes floating round the fuel bowl. But these tend to cause random problems than the "about 5 min" problems you are having.
Change question
sounds like a fuel venting problem. Loosen the cap to the gas can and see if that works.Then (if that fixed it) you will find the vent built into the cap is sticking shut or you forgot to open it.
I just bought a new boat and need to buy a boat
Never buy a trailer with the same capacity as the weight of your boat! This can be very dangerous! Instead, make sure the trailer's capacity is at least twice that of the weight of the boat, all your gear, and the boat's motor.
12/5/2023 6:58:35 AM •
Boating
Answered
on Dec 05, 2023
What is the size of a small yacht?
Small yachts, also known as Silboats or Cabin
Cruisers are 20-40 feet. There are of course larger Yachts that can get to over
100 feet, also known as Mega Yachts.
11/15/2023 8:08:55 AM •
Boating
Answered
on Nov 15, 2023
What is the most expensive yacht in the world?
Off-course There are so many companies who are offering expensive yacht charter for rent in and around Europe. I suggest you to enter Kavas is the only yacht chartering company in Greece with over 25 years of experience in our industry. Kavas is offering all range from reasonable to luxury yacht services in Athens, Kos Island and Lefkas Island. For more details visit
Bareboat or Crewed Yacht Charters in Greece
10/13/2023 4:52:02 PM •
Boating
Answered
on Oct 13, 2023
