20 Most Recent
Samsung Digimax 4010 Digital Camera Questions & Answers
Card Locked , HELP PLZ !
Hi, I have a soloution I have literally just done it, for some reason the cards arn't going in camera far enough, get a little bit of card from a box and put it on memory card before you close the door, when u close the door it pushes the card further into the camera you can then format it and take pictures. it does work as i have just done it regards kev
Hi, I have this problem with my dell inspiron N
The LCD monitors and laptop monitors nowadays have a 'optimum resolution'. The monitor likes to work at a pre-defined resolution.
Games play at a resolution previously set. Usually this differs from the optimum resolution of a LCD/LED screen. Then this error message will appear.
However, crashing of the computer might happen due to other reasons.
*Defective RAM
*Not-so-good VGA
*Viruses
You have to make sure the above problems are not the reason for crashes.
Also try playing somewhat older games. If the problem occurs due to your VGA not supporting the new games, older games will work fine.
Try these suggestions and let us know.
Good luck, and thanks for using FixYa!
I can't get pictueers
Having gone two months without a response to my query, I assume my suggestion to use a card reader solved the problem.
Formatted a 2gb memory card
From your description, it sounds like you're formatting the card in your computer and then inserting it into your camera. Camera cards must be formatted in the camera only.
Recently purchased new computer with
This product is not compatible with Windows 7. The old drivers would not work, as they were intended to help with older versions of Windows. The only possibility is to contact Samsung and ask whether they have recently introduced any updated drivers for the same, though they are not available on their site.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
I have a digimax
SDHC is an extension of the SD standard that extends the capacity from 2GB to 32GB. It's backward compatible in that devices designed for SDHC cards will also work with SD cards. It does not go the other way---that is, SDHC cards will not work in devices designed for SD cards.
I presume you mean a 2GB card, since a 2MB card might hold one picture.
The Digimax 4010 works with SD cards, not SDHC cards. You may use an SD card. Just make sure it is an SD card, 2GB and smaller. SDHC cards start at 4GB and go up to 32GB but, as stated earlier, will not work in the 4010.
When I insert a SanDisk SD card 2GB it tells me
There are several possible causes for "memory card locked", "memory card error", or "no memory card". The most common is trying to use a 4GB or higher SDHC card with an older camera made before SDHC format came out. Other causes include problems with the tiny slide switch on the side of the card, or the electrical contact switch internal to the camera. The problem may also arise from simple formatting problems if the card has never been formatted in the camera (note that this will also erase the card). Troubleshooting tips for this problem may be found
at this link.
I have a 128MB sd card and it says card is locked?
Look at the memory card. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
