20 Most Recent Samsung ES30 Digital Camera Questions & Answers
How do i register my samsung camara
Hey TheAmazonWom,
You can register your Samsung camera by going to http://www.samsung.com/us/support/account/regist and filling out the information.
Thanks,
3/13/2019 3:04:23 AM • Samsung ES30... • Answered on Mar 13, 2019
0answers
2answers
My Samsung 5x ES30 Zoom Did Not Operate Normaly
Ensure you're using new batteries and try again.
11/6/2015 11:26:42 PM • Samsung ES30... • Answered on Nov 06, 2015
I am trying to delete picture. The camera has only 6 pics that i can view but on the screen it says that there are 100-203. I have been trying to delete them but just cant .
If you can find a reset button reset the camera fo factory default. It sounds as though you might have a memory card in the camera? If this is so put the card in a n adapter plug it into a card slot and format it. The reason you may not be able to see photos is if they were put on a card from another source. They may be in an incorrect format or in too large a sixe to be displayed on that camera
6/30/2015 1:44:05 PM • Samsung ES30... • Answered on Jun 30, 2015
MEMORY CARD SHOWING FULL BUT WHEN CAMERA CONNECTED TO DOWNLOAD TO LAPTOP OR DESKTOP ITS SHOWING FREE SPACE AND USED SPACE BUT NOT SHOWING ANY PICTURES AND VIDEOS,
Save the pictures and videos on the card. Try reformatting the card in the computer, and then again using the camera. The first reformat will ensure the card is empty, and then the camera reformat will ensure that it is recognized by the camera. If the camera reformat will not work, try a new card.
4/9/2015 10:48:17 AM • Samsung ES30... • Answered on Apr 09, 2015
I lost my cd for samsung es30 to transfer photos from the camera to pc how to download and install from net get me web adds
Get an external SD card reader/writer. They range from 3.00 to 13.00 US. It makes transferring photos way faster than using the cable that came with the camera. Photo's load directly to your hard drive so photo editing is easier.
10/1/2014 6:19:32 PM • Samsung ES30... • Answered on Oct 01, 2014
WHICH BATTERY DOES SUPPORTS IN THE SAMSUNG ES30 Will ENVI NI-CD battery work ?
You can use that battery. IT wont last as long as the alk or the Nimh
8/1/2014 6:16:08 PM • Samsung ES30... • Answered on Aug 01, 2014
2answers
The zoom did not operate
The solution is very simple. you are going to remove the battery (while this screen is on) as the command screen tells. And your camera should function properly. I tried it and it worked. NB; Do not try to close your camera then remove the battery. Remove it while the camera is still on.
6/22/2014 8:26:50 AM • Samsung ES30... • Answered on Jun 22, 2014
How do i delete pictures from a samsung ES30
To delete pictures, follow these steps:
To delete single file, 1. In playback mode (while viewing you pictures or videos), select a file and press the {Fn} key 2. Select YES to delete the file
To delete Multiple files, 1. In playback mode, press {Fn} 2. Select Multiple Delete. 3. Select the files you want to delete and press {OK} Press {OK} again to cancel your selection 4. Press {Fn} 5. Select YES
To delete all files, 1. In playback mode, press {MENU} 2. Select File Options > Delete> All > Yes
5/19/2014 9:17:22 AM • Samsung ES30... • Answered on May 19, 2014
How to transfer photos from the computer to camera
Depends on the type of computer you have. If your computer has a slot to introduce a memory card, go to start, then computer and bring up the folder where the desired photos you want to transfer are. Copy the pictures. At the "computer window," the memory card should appear. Right click on it and choose paste. I you meant to say HOW TO TRANSFER PHOTOS FROM THE CAMERA TO THE COMPUTER, insert the memory card into the computer; the computer should do it automatically, just follow instructions and choose a folder. If the computer does not allow you to choose a folder, copy the memory card pictures and open a folder where you want to transfer the pictures, right click on the folder and choose paste. I hope this info will help you. Also, most newer cameras come with a USB cable, if you have it, connect the cable to the camera and then the computer. the pictures.
4/21/2014 6:23:48 AM • Samsung ES30... • Answered on Apr 21, 2014
Usb connection show on starting
connect camera to pc and power on the camera.
12/15/2013 4:19:43 PM • Samsung ES30... • Answered on Dec 15, 2013
Factory reset
came from the factory that way
12/11/2013 8:02:31 AM • Samsung ES30... • Answered on Dec 11, 2013
Factory reset
In camera settings menu, on the bottom of the screen you find Settings. In Settings is the only reset the camera knows. You only will reset the menus and shooting options. Date, time, language and video output settings are not reset. If your camera has serious trouble, accessing menus or something like that, there is nothing like pressing a button for several seconds and everything will be ok. (not in the manual)
12/8/2013 4:43:29 PM • Samsung ES30... • Answered on Dec 08, 2013
Samsung ES30 Digital Camera Logo
77 questions posted
Top Samsung Cameras Experts
ZJ Limited
ZJ Limited
Are you a Samsung Camera Expert? Answer questions, earn points and help others
View Most Popular
ES Samsung
  • ES Samsung
Most Popular Question
factory reset
  • Cameras
