20 Most Recent
Casio Keyboard Ctk-481 Ctk-631 Ctk-651 Questions & Answers
Where can i get a ctk 481 driver
CTK 481 only has MIDI-IN and MIDI-OUT ports & no USB. So you need to buy a USB-MIDI interface (cable-like) preferably one that is class-compliant for you OS. Class-compliant device do not need drivers (PCs, MACs, IPAD).
Ctk-651 sustain pedal working backwards
Buy sustain pedal made for CASIO or switable model.
Pedal for Yamaha or Roland will work in reverse on a Casio.
If you cannot return for exchange, then open up and solder a different type of micro switch.
My son has started learning
Most of these keyboards have such a function... the manual doesn't show any... however one could select drum set 5 and use the claves setting for a rhythm and control the rate with the tempo. This might be too complicated and it might be simpler to get a small metronome... some are very inexpensive.
(Wk-200) Volume wheel spinning all the way around and not stopping at "min" or "max"
If the volume wheel on your Casio WK-200 keyboard is spinning all the way around and not stopping at the "min" or "max" positions, it is likely that the potentiometer that controls the volume has become faulty or damaged. A potentiometer, or pot for short, is a type of variable resistor that is commonly used to control the volume on electronic devices.
Here are a few troubleshooting steps you can try:
- Power off your keyboard and unplug it from the power source.
- Remove any batteries from the battery compartment.
- Locate the volume potentiometer inside the keyboard. It should be near the volume wheel and will have three pins or legs.
- Check the potentiometer for any visible signs of damage, such as cracks or broken pins.
- Gently wiggle the volume wheel while observing the potentiometer. If it appears to be loose or wobbly, it may need to be replaced.
- If you have experience with electronics and soldering, you may be able to replace the potentiometer yourself. Otherwise, it is recommended that you take your keyboard to a qualified service technician for repair.
If the issue persists after attempting these troubleshooting steps, it is likely that the potentiometer needs to be replaced. In any case, it is best to seek the assistance of a professional technician to avoid causing further damage to your keyboard.
4/10/2023 12:24:14 PM •
Casio Music
Answered
on Apr 10, 2023
Casio tone bank m120 no power,ic AN8054 has been blown off any substitute for ic is available please let me know
The AN8054 is an integrated circuit used in the Casio Tone Bank M120 keyboard. If it has been blown off, you will need to replace it. An equivalent replacement for the AN8054 is the LM358N, which is a dual operational amplifier that can be used as a substitute. Other equivalent options you can consider include the LM741, LM7808, and LM324. It's always recommended to check the datasheet of the substitute IC to ensure it meets the specifications and requirements of the original IC.
1/31/2023 6:20:11 PM •
Casio Music
Answered
on Jan 31, 2023
