20 Most Recent
Audiovox SP6CDP 6-Disc CD Changer Questions & Answers
Problem with 6 disc changer
Hi
I believe it is tellinng you that you do not have a disc Jacket. The case that holds the 6 discs. If you have this the switch inside the CD changerneeds some investigation.
I just burnt a new
Is the cd player new does it play burned cds??? If you now it does then check your format and make sure u are burning as an audio cd and not a data disk
Will the Audiovox SP-6cds hook to an Audiovox
Yes - the radio has cd changer controllers.
The Changer is FM modulated - and the radio becomes the controller.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Music won't play
take that to a local repair shop maybe they would help you around in $30
What are the input wires on a audiovox amp777
The Audiovox AMP777 is a 4-channel power amplifier, and the input wires will depend on the audio source you are using. Typically, the amplifier will have RCA input jacks for left and right channels, and you would use RCA cables to connect the audio source to the amplifier. Some amplifiers also have a high-level input option, which would allow you to connect speaker wires directly to the amplifier's input terminals. However, it's always best to consult the user manual or contact Audiovox support for specific wiring instructions for your amplifier model.
