20 Most Recent
Audiovox XCS9 XM Radio Receiver Questions & Answers
No Signal on my XM Radio
Lately I have been loosing the signal constantly in the house. I've tried different stations to see if it would be any better and it's not. I called xm and they refreshed my signal but it didn't do ant good. It's really annoying to constantly have the signal fade. Everything is hooked up right. This is been going on for about 5 months and my neighbors complain about the same thing.
Any Suggestions
Just moved and can not
If you have the home system, you want your antenna in a south-facing window. There are helpful hints on setting-up your antenna on XM411.com - give it a try.
Setting my preferred stations
you need to select your station then press the preset button then 1 thru 0 to store the station. repeat for the rest of yoiure stations you want to store.
How can i get the surround sound to work.
You need to get an HDMI cable going from your Cable Box to the Surround Sound system. If you are low on HDMI ports, you can RGB cables for Video.
Your quote: " I have a HDMI cable plugged into the TV and the Cable box." move that cable to Surround Sound and Cable Box, and use RGB cable or HDMI to go from Cable box to TV!
If your Surround Sound has no HDMI, use a Fibre Optic to go Cable to Surround. It will work Great!
Good Luck!
RCA th1611-A mp3 player not recognized by software
This item is a USB2.0 device. Older computers use USB1.0 and new computers USB3.0. Depending on your computer age, this may not be recognized. I suggest you make certain all USB device drivers are up-to-date.
