20 Most Recent Cobra 19 DX III 40-Channels Base CB Radio Questions & Answers
2answers
In Thailand Cb radio users must use freq range
Thailand actually has three "CB" bands, the first is the same as the U.S. / CEPT (EU "European Community) band 26.965 - 27.405 MHz, the second is a 78MHz VHF mid CB band (I think its either 40 or 80 channels with FM mode) and then the 245.0000 - 245.9875 MHz VHF 80 channel band - apparently the law also stipulates that the 78MHz CBs must be yellow colored and the 245MHz CBs must be red colored.But yeah, 245MHz Thailand VHF CBs are very illegal in the United States.
4/29/2016 9:38:45 AM • Cobra 19 DX III... • Answered on Apr 29, 2016
Cobra 19 DX III
www.cbtricks.com has your manual .
12/17/2014 8:14:53 PM • Cobra 19 DX III... • Answered on Dec 17, 2014
The 19 DXIII only receive,
its the vertical boards inside the radio.. if they vibrate loose it will loose either tx or rx or both.. resolder them they should return to operation.
9/25/2011 10:31:07 PM • Cobra 19 DX III... • Answered on Sep 25, 2011
My cobra 19 Dx if it receives the signal of
If I understand you can receive but not transmit. Try replacing the final transistor in the rear of the radio and see if that works.
3/5/2011 8:38:05 AM • Cobra 19 DX III... • Answered on Mar 05, 2011
Adjust the receive and turn
Then put a 40 watt modulator in line with a 400 watt amp. You will have an out put of 800 watts to the antenna. Make sure you have an antenna thats rated for it. Francis whip is a good one, Palamar, another good one.
2/26/2011 10:16:33 PM • Cobra 19 DX III... • Answered on Feb 26, 2011
No power to cb ?
If the fuse is O.K. it could be that the input diode is burned....this is to protect in case of the radio being hooked up powerwise the wires have been reversed. Usually RED is 12 Volt POS. If you open the radio look where the power cord comes in....you will see the diode and I found usually at the Right side of the chassis, that is right rear with component side up. It is usually burned and if you replace it you'll be in business ! ! Goo0d luck.
10/8/2010 11:01:35 PM • Cobra 19 DX III... • Answered on Oct 08, 2010
0answers
It will not turn on
check the power going to the power wires. for dc voltage. then if good check the fuse in power wire. if good check the ground for good connection. if good check to see if you have at least 5amps of dc pwr going into the radio. if good has the radio been hooked up backwards. or even just sparked ground or + wire, if so contact us for repairs. that could have blown the protection diode. and will not let the unit turn on. or may have a burnt trace on the board to the switch.
12/16/2009 6:55:34 PM • Cobra 19 DX III... • Answered on Dec 16, 2009
When pa is on all i get is a shrill noise when i
TURN DOWN THE VOLUME ! ! ! You are getting feedback thru the mic because the speaker is too close to the mic.
11/20/2009 12:47:25 AM • Cobra 19 DX III... • Answered on Nov 20, 2009
GREAT TRANSMISSION HARDLY NO RECEPTION
need to take it in to have the SWR set on antena
2/19/2009 7:21:07 AM • Cobra 19 DX III... • Answered on Feb 19, 2009
President mckinly ssb/am model with mb8719 pll chip.
It looks like you had some loose connections in that CB. you may want to also check for other cold solder joints throughout the units and touch them up with some solder. Might I suggest you use a desoldering tool and then just add new solder to the connection.
9/5/2007 8:47:40 PM • Cobra 19 DX III... • Answered on Sep 05, 2007
Cobra RX385 Two-Way Radio. Why does my walkie-talkie send messages but can't receive any sound.
Question edited for clarity and translated into 'Adult'. Question moved from Cellphone category. https://www.google.com/search?q=cobra+rx385+no+audio https://www.google.com/search?q=Cobra+rx385 ..
1/1/2024 9:42:37 PM • Cobra Radio... • Answered on Jan 01, 2024
I have a Cobra 148 GTL side mike jack.
There appears to be help here and that forum is the best place to ask. It is a Post Factory modification according to this.
WTB cobra 148 gtl side mic
WorldwideDX Radio Forum https://www.worldwidedx.com > threads > wtb-cobra-... Feb 27, 2019 - 148 GTL side-mic uses 5 pin mic receptacle. If the radio in question is a side mic and has a 4-pin receptacle, then it was put in post-factory ... Cobra 148 GTL Malaysia.. side mic?? Should I buy? Aug 13, 2018 148gtl blown d44 and mic Jack conversion - WorldwideDX Mar 1, 2018 Old school Cobra 148GTL.... ' WorldwideDX Radio Forum May 13, 2019 Cobra 148gtl Basket case! ' WorldwideDX Radio Forum May 7, 2018 More results from www.worldwidedx.com https://www.google.com/search?q=Cobra+148+GTL+side+mike+jack ..
12/3/2023 5:48:29 PM • Cobra Radio... • Answered on Dec 03, 2023
6 wires d-104 white shield blue black red & yellow what color goes to what number 5 pin cobra mobile 148 gtl
Here are the instructions:
  • PIN #1 ~ WHITE
  • PIN #2 ~ SHIELD
  • PIN #3 ~ BLACK
  • PIN #4 ~ BLUE
  • PIN #5 ~ RED YELLOW N/C
I hope this helps!
10/29/2023 6:57:32 AM • Cobra Radio... • Answered on Oct 29, 2023
2answers
I have a Cobra Microtalk walkie talkie, one sends & receives, the other just receives it won't transmit just makes loud noise. What is happening?
8/16/2023 11:51:42 AM • Cobra Radio... • Answered on Aug 16, 2023
Mods for Cobra 29LX max ?
Manuals in the link tell you how to tune. What kind of 'modifications'? https://www.google.com/search?q=Cobra+29+LX+max+manual ..
8/15/2023 5:37:15 AM • Cobra Radio... • Answered on Aug 15, 2023
How to wire a Sadelta M3 to a Cobra 29 LTD Classic
I believe to wire a Sadelta M3 microphone to a Cobra 29 LTD Classic CB radio: The Sadelta M3 microphone has four wires: white, shield (bare wire), red, and black. The Cobra 29 LTD Classic CB radio's microphone jack also has four pins: Pin 1 (Audio), Pin 2 (Ground), Pin 3 (Transmit), and Pin 4 (Receive). To wire the Sadelta M3 to the Cobra 29 LTD Classic, you need to connect each wire from the microphone to its corresponding pin on the microphone jack. The white wire carries the audio signal from the microphone's element to the radio, the shield wire provides a ground connection, the red wire activates the radio's transmit function when the microphone is keyed, and the black wire is used for receive audio. Here are the specific steps to follow:
  1. Cut off the existing microphone plug on the Sadelta M3 microphone cord.
  2. Strip about 1/4 inch of insulation from each of the four wires in the Sadelta M3 microphone cord.
  3. Connect the wires to the pins on the microphone jack as follows:
  • White wire to Pin 1 (Audio)
  • Shield (bare wire) to Pin 2 (Ground)
  • Red wire to Pin 3 (Transmit)
  • Black wire to Pin 4 (Receive)
  1. Solder each wire to its corresponding pin on the microphone jack. You may want to use a multimeter to verify that each connection is solid and that there are no shorts or open circuits.
  2. Once you have soldered all the wires, test the microphone by speaking into it and checking that the radio's TX meter moves as you speak. Also, check that you can hear audio through the radio's speaker when receiving signals.
  3. If the microphone is working correctly, use heat shrink tubing or electrical tape to cover the soldered connections and provide strain relief for the wires.
Note that some microphones, including the Sadelta M3, may have additional features such as a built-in amplifier or power supply that require additional wiring.
2/26/2023 11:41:56 PM • Cobra Radio... • Answered on Feb 26, 2023
Cobra 19 DX III 40-Channels Base CB Radio Logo
Popular Tags
12 questions posted
Top Cobra Radio Communications Experts
Mike Cairns
Mike Cairns
eradiostore
eradiostore
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
View Most Popular
  • Cobra Radio Communications
Most Popular Question
in thailand cb radio users must use freq
  • Radio Communications
