20 Most Recent
Garmin GPSMAP 180 GPS Receiver Questions & Answers
NEED MAP DATA CARD FOR GARMIN GPSMAP 180
I have 2 data cards for Garmin gpsmap 180 and working well.I got this offshore boat from Tallahasse 3 wks ago that has a built in Garmin gps 180 with 2 data cards on it and I have no use for it because I have the boat in Texas now. Don't know if this is the right one that you need, all I know is that these 2 cards are programed for Florida gulf.I can ask the previous owner of the boat about the details of these 2 cards. I'm willing to trade it for a data card for the lower gulf preferably from Brownsville, Tx. to Louisiana or anything that will cover Port Isabel, Port Mansfield, Port Aransas. You can e-mail me at
[email protected] or call me at (956) 240-8420 .My name is Oliver.
Unit starts to power up and then shuts off.
the most common cause of this is that the battery is defective, the average life span of these GPS units batteries is around two years in average use, if it is run dead often the battery can fail sooner. For details on how to obtain battery service go to
www.mygarmin.com
Internal Battery Low
Same problem. Remove the 8 screws, unsolder the battery from the circuit board, pry off leads, place electrical tape around edge of new battery, solder on the leads, solder leades on circuit board. Remember which side was up before soldier, close unit, you should be good to go.
My garmin gps map 180
this is a software read problem, called Garmin and they said to send it in for repair or exchange, the 2 beeps are to alert you to the fact that the software can't load, that is why it won't turn on.
Garmin 180
You need to replace the internal Battery with the
Panasonic BR2032-1F2 battery. However, yes your waypoints will most likely get lost when you do this.
Garmin gps180 satellite search.
Book says should get satellite in cold. Goes on to saySearch the sky appr. 5 minutes. Same for autolocate.
You can go to Garmin and print out the owneers manual and that might help.
Also, antennas are cheap on Ebay.
Luck
Seadrive Joe
GPSMAP 180 power/data connector
Okay
guys: book says:
PIN 1 (red) 10-40 volts DC
PIN 2 (black) Ground
PIN 3 (blue) NMEA out Shows this goes to Autopilot/NMEA devise and to RXD positive RXD negative goes to ground (black)
PIN 4 (brown) NMEA in Goes to GBR 21 Beacon Receiver to a blue wire, brown wire on thaat devise goes to PIN 3 and the negative goes to ground
PIN 5 (white) no connection
PIN 6 (Green) no connection
PIN 7 (yellow) goes to alarm low Shows going to negative terminal on alarm relay and positive terminal goes to PIN 1 (red)
All Greek to me, have fun
Seadrive Joe
