20 Most Recent GE 27GT271 TV Questions & Answers
You will not have much luck without a replacement remote.
GE 27GT271 TV | Answered on Mar 10, 2014
Check and replace damaged component/s at its main board. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
GE 27GT271 TV | Answered on Feb 17, 2014
Good: Connect the antenna to the converter box where it says antenna/in. Connect the coax cable to where it says to tv/out on the converter box. Connect this cable to the coax/rf input on the television. Plug in and turn on the converter box and the television. Make sure the television is on channel 3 and follow the setup process that pops up on the screen.
Better: Connect RCA cables to the converter box where the yellow red and white holes are. Connect them to an RCA input on your television. If you don't have a red hole on the television that's ok, just connect yellow and white and leave the red plug dangling. Connect the antenna to the converter box where it says antenna/in. Plug in everything and turn everything on. Press the video/input/source button until you have located the setup screen for the converter box and follow the directions on the screen.
GE 27GT271 TV | Answered on Dec 02, 2012
The remote mentioned only has about 50 codes built into it---and note: RCA and GE are the same= try all possible codes for each.
GE 27GT271 TV | Answered on May 16, 2012
I have the same problem. Try to programa de ic u201v with the original program.
good look
GE 27GT271 TV | Answered on May 01, 2012
Use channel up/down. Hit channel down below channel 2, will be your video inputs.
GE 27GT271 TV | Answered on Nov 24, 2011
No, it is not a HD set by any sense of the imagination.
SD TECH
GE 27GT271 TV | Answered on Sep 01, 2011
It may have something to do with the closed captioning... Hit the menu button, then select Screen. There you should see the options for CC. Try turning it off if they are on. Other than that the issue may not be with your TV but with the reciever for the satellite. Make sure it's not configured for a wide screen (that the aspect ratio is either 1:1, 4:3 and not 16:8)
GE 27GT271 TV | Answered on Apr 14, 2011
  1. On the front of the TV press the MENU button to display the MAIN MENU.
  2. Scroll through the choices using the VOLUME up and down buttons
  3. When positioned on the selection you want press the MENU button again.
  4. The first SETUP screen displays, asking you to select a language.
  5. Scroll to the desired language ENGLISH, FRANCAIS or ESPANOL and once it is highlighted in green press the MENU button to make finale selection.
  6. A SETUP screen appears asking if you would like the TV to search for all channel
  7. 1. Yes
    2. Skip this step
    3. 0 Exit
  8. Complete the SETUP routine or skip any of the steps and return to them later.
This information is from the User Guide that came with our set. Good Luck.
GE 27GT271 TV | Answered on Apr 12, 2011
i dont know to reset the password but i can remove this fault.Try to replace the system ic and copy the memory ic from good and the same tv type..
GE 27GT271 TV | Answered on Mar 25, 2011
TRY CONNECTING THE WIRES THE RIGHT WAY
GE 27GT271 TV Logo
73 questions posted
Top GE Televison & Video Experts
matt martin
matt martin
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • GE Televison & Video
Most Popular Question
turn
  • Televison & Video
