20 Most Recent
GE 27GT616 27" TV Questions & Answers
Replacement power cord
I spent about an hour web searching, but I did find the model number of the power cord. From there, I searched the model number and found numerous websites that carried it.
How do I watch a DVD with this tv. It seems like it is connected right but just showing static
Hi. By static, do you mean 'snow' image ? DVD players must be connected to AV inputs and selected as an AV signal, either by using the remote control, either using the local controls in the set itself. If you see, what you call static, means that your TV is on "a" channel without areal input. (antenna inputsignal).
You can use the local TV channel button (-), go all the way down below channel 1. There the AV inputs are located. Good luck.
Television Fuse
if it is a glass tube with a small bit of wire in the middle, maybe painted or with a label round the tube, two metal end caps, and a springy clip holder then yes, its a fuse.
You should be able to get the same one at most hardware stores depending on the rating. usually the rating will be stamped in tiny letters on the side of one of the metal end caps, or on the tube if it is painted or labelled.
It would say something like 6A or possibly 500mA or similar or maybe just the numbers with no A or mA.
take the old one with you and you should be able to get a box of them cheap enough if you want.
even if it has no numbers printed on it - look where the spring clips are and next to them or between them it will probably have printed "F1" or similar (meaning first fuse), and a rating like 10A etc. get one that is the same as the printed rating instead of the old one that came out if they are different.
you might be lucky and find the one you got from the other tv is the correct one anyway, but you should check.
Hope this helps - if not then please post again :)
Blue power light is on, but no picture is displayed
The light does indicat that there is power to the sety but that doesnt mean that the power supplys working . Theres nothing uyou can do unless your a trained tech. The set should still have a parts warranty. Good Luck
Codes for ge
Hello
Three digit universal remote codes for GE are:
000/ 003/ 004/ 009/ 022/ 031/ 044/ 052/ 054/ 055/ 087/ 092/ 103/ 107/ 125/ 164/ 181
Four digit universal remote code for GE are:
0031 0107 0164 0004 0009 0044 0054 0000 0342 0003 0125 0015 0022 0052 0087
Direct Code Entry
- Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
- Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
- Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
- With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
How do you turn off
Hi eldia,
Welcome to FixYa.
My name is John. I will be assisting you with your issue
If you are using a cable box, you must first turn it off,
then press the menu button and you should see it, and
be able to turn it off. I hope this was helpful to you.
Thanks for choosing FixYa.
John
Where do I buy tv
You can go to any tv repair shop, they carry a large selection of fuses for various types of repairs.
Video mode on GE 27GT610
Try hooking up the dvd player and turning it on. Then use the setup and add/erase channel feature to look thru all of the channels. On my older GE tv I found that channel 91 was the correct channel for the video input. I saw the logo for the dvd player on this channel. I just added that channel and now it works. Your channel might be different.
I was given a GE
If your tv has video in socket (yellow color)and audio in socket(white color),you will connect the dvd player audio video output. it will give give clarity picture. your tv have not av socketyou can connect your dvd player audio video output to converter audio video input.And then connect to converter RFout to tv Rf input(antenna socket)and tune the tv you wlii get picture.
Need a remote control
Go to
www.remotes.com they should have a replacement or you can get an RCA,GE,or THOMSON brand name universal remote that will not require programming because the codes start with GE codes. Thanks for using fixya.
Rusty
Finding DVD Plugs
No it's not hidden but don't fret just open your wallet.
You need what is called an RF Modulator. All you do is connect your A/V component ( DVD ) to the modulator's input jacks, then connect the modulator to your TV's antenna/cable input and select channel 3 or 4 operation.
Your local department or super center should have it. If not you can always go to a Radio Shack near you they will have it.
