20 Most Recent
GE 13V110TD 13 in. TV/DVD Combo Questions & Answers
DVD parental lock
I have a GE 13TVR62 (with a problem listed here). I've learned that the Parental Lock Settings are changed by using the Remote Control. Usually the actual Settings are changed by pressing the Up or Down or Left or Right Arrows to make the Change; while the Parental Lock is Highlighted on the Menu.
Trying to find model number on my GE universal remote so that I can get codes for my converter box
Locating the model number on a GE universal remote can vary depending on the specific model. Here are some general tips to help you find the model number:
- Check the Battery Compartment:
- Open the battery compartment on the back of the remote.
- Look for a sticker or label inside the compartment that may contain the model number.
- On the Remote's Front or Back:
- Check the front and back of the remote for any labels or markings that might indicate the model number.
- User Manual or Packaging:
- If you have the user manual or the original packaging, check there. The model number is often mentioned on these documents.
- Behind the Battery Cover:
- Remove the battery cover and inspect the area behind it for any labels or markings that include the model number.
- On the Remote's Body:
- Inspect the body of the remote itself. Some models may have the model number printed on the front or sides.
Once you locate the model number, you can then proceed to find the correct codes for your converter box. The codes are usually included in the remote's manual or can be found on the manufacturer's website. If you are unable to find the model number or the manual, you may need to contact GE customer support for assistance.
If you provide more details about your GE universal remote, I might be able to offer more specific guidance.
Need universal remote codes for sansui hdlcdvd265b
https://www.fixya.com/support/r29872378-universal_remotes_no_facsimile_remote
4 Digit Universal Remote Codes for Sansui TV ; 0394, 5871, 1052 1556, 1208, 0135 ; 0888, 0310, 6071 ; 6061, 0806, 5441 ; 2832, 0264, 1230.
Replacement Remote Control for SANSUI HDLCDVD265 ...
Amazon.com
https://www.amazon.com > Replacement-HDLCDVD2...
This is a custom built replacement remote made by Redi Remote for the SANSUI remote control number 076R0LJ020. *This is NOT an original remote control.
Rating: 4.4 · 12 reviews ·
US$34.95
Replacement Remote for SANSUI HDLCDVD265, ...
Amazon.com
Replacement remote control for Sansui HDLCDVD265, HDLCDVD325B, 076R0LJ020 with
all functions of original one. It replace each button of original remote ...
US$16.00
Need codes FOR GE UNIVERSAL RC 24914-D TO CONNECT MY roku express
Yes, you can use a GE Universal Remote RC24914-D to set up your Roku Express box. To do this, you'll need to find the correct code for your Roku Express device and program it into the remote. Here's how:
- Turn on your Roku Express device.
- Locate the "Code Search" button on your GE Universal Remote. This button is usually labeled "Code Search" or "Setup."
- Press and hold the "Code Search" button until the indicator light turns on.
- Enter the code 9-9-1. The indicator light will blink twice.
- Point the remote at your Roku Express device and press the "Power" button. If the device turns off, you have found the correct code. If it does not turn off, repeat steps 3 to 5 with a different code until you find the correct one.
- Once you have found the correct code, press the "Code Search" button again to save the code.
The codes for the GE Universal Remote RC24914-D can vary depending on the version, so it's possible that the code 9-9-1 may not work for your device. If that's the case, you can try other codes listed in the remote manual or on the GE website.
I hope this helps you set up your Roku Express device using your GE Universal Remote.
Ge universal remote model um3-lr06
please reach out to general electric via twitter and ask them to post the product manual for you sos that you can download it and get the codes that you're looking for. Their id on twitter is @generalelectric.
Thank you.
I have a GE 13TVR70 with a blue screen
1. How to fix a GE 13TVR70 with a blue screen:
If your GE 13TVR70 has a blue screen, there are a few possible causes and solutions.
First, check to see if the blue screen is caused by a loose or disconnected cable. If so, simply reconnect the cable and power on the TV.
If the blue screen persists, the TV may have a faulty component that needs to be replaced. Consult a TV repair specialist for assistance.
2. What could be causing my GE 13TVR70 to have a blue screen?
There are several possible causes for a GE 13TVR70 to have a blue screen. First, check to see if the blue screen is caused by a loose or disconnected cable.
If so, simply reconnect the cable and power on the TV. If the blue screen persists, the TV may have a faulty component that needs to be replaced. Consult a TV repair specialist for assistance.
3. What are some common problems with GE 13TVR70s?
Some common problems with GE 13TVR70s include blue screens, picture quality issues, and sound problems. If you are experiencing any of these issues, consult a TV repair specialist for assistance.
4. How can I prevent my GE 13TVR70 from having a blue screen?
There are a few things you can do to prevent your GE 13TVR70 from having a blue screen. First, make sure all cables are securely connected.
Second, avoid using the TV in extreme temperatures. Third, do not use the TV in humid or dusty conditions. If you follow these guidelines, your TV should function properly.
I hope this helps!
I have a GE universal remote how do I get the codes to program my Magnavox sdtv tuner
First open the back of the remote and take out the batteries. There should be a sticker inside with different serial numbers and codes on it. You are looking for a "CL" number. It will be either a 3, 4 or a 5. This is the generation of remote you have and the remote codes listed will only work on these CL generations. Refit the batteries and back cover.
Go to the website below and it tells you what the codes are and how to use them to activate your remote control. You will need to scroll down the page until you get to where the Magnavox codes are listed. Magnavox has 11 codes listed and you might have to try all of them.
https://www.directutor.com/program-ge-universal-remote#ge%20universal%20remote%20codes
