20 Most Recent
GE 7-5295 Undercounter DC /Radio Combo - WHITE CD Player Questions & Answers
GES050 undercounter radio/cd player
..just read about your reception/interference problems and, having lived through similar situations for some time — particularly with different weather conditions. The following solution has settled it all : wrap power cable around storage brackets at back of radio with a short length then wound around support posts (between radio and cupboard from which radio hangs), then run short length to power supply outlet. In my case this result comes after much experimentation with the length of unwapped power cord (including fully unwrapped and stretched out) and different patterns of winding around the support posts. This final result takes care of everything (better sound, no interference/loss-of-reception when moving around in the room or in front of the radio, weather has no effect, stations received that could not be before due to overlap by nearby, more powerful ones). I have only about 2 1/2 feet of cable running from the brackets at back of radio, then wound once around center support and half around right support to then go to wall and down to receptacle close by (I tried all kinds of combinations of unwrapped lengths and winding patterns around 1 to 3 posts)...individual cases may be different. so GOOD LUCK, 'cause the radio is great...!
5/20/2014 6:16:36 PM •
GE 7-5295...
Answered
on May 20, 2014
No digital display
The power supply might be bad- if it is not that then then you can try a reset of the unit but further than that it is beyond the users control.
12/15/2012 12:04:02 PM •
GE 7-5295...
Answered
on Dec 15, 2012
CD player skipping
Make sure the unit is mounted level and not to secured that its pinching down on the unit
7/24/2012 3:23:57 PM •
GE 7-5295...
Answered
on Jul 24, 2012
Hi, I had a GE
If it's hard to find why don't you just look online (eBay) for it or a similar one? There are several.
8/11/2011 4:58:37 PM •
GE 7-5295...
Answered
on Aug 11, 2011
