20 Most Recent
Lexmark Z730 InkJet Printer Questions & Answers
Will not work with dell laptop
Hi
The key thing here is not the laptop, but rather the the software and the printer cable.
You do not say which operating system you use.
As long as the cable fits both devices and the Driver and installation disc is compatible with your operating system (this should be printed on the CD) and you have installed the drivers and applications correctly there should be no problem.
If you have lready adone all this then the printer may be faulty.
I hope this helps.
I just put a new cartridge in my Lexmark Z730. It
These problems could be due to the new cartridge in the printer. Try to insert a different known working cartridge, like your previous cartridge, to check if the new one is faulty. Also, make sure the USB cable is properly connected into the printer and to your computer.
Wifi light is orange
The colors of the WiFi indicator light show the network status of the printer.
- Off means one of the following:
- The printer is turned off or is powering up.
- The printer is not connected to a wireless network and in power saver mode. In power saver mode, the power light pulses on and off.
- The printer is connected to an ethernet network. Refer to the Quick Reference Guide to find out if your printer has ethernet capability.
- Solid orange means one of the following:
- The printer has not yet been configured for a wireless network.
- The printer is configured for an ad hoc connection, but it is not currently communicating with another ad hoc device.
- Blinking orange on the WiFi light means one of the following:
- The printer is out of the range of the wireless access point (wireless router).
- The printer is trying to communicate with the wireless access point but the wireless point is turned off or not working properly.
- Either the configured printer of the wireless access point has been turned off and back on, or the printer is trying to establish communications with the network.
- The wireless settings of the printer may no longer be valid.
- Green means that the printer is connected to a wireless network and is ready for use.
Good afternoon. My Lexmark 792 printer shows error 956.02 at startup when adjusting colors, how can I solve it?
The 956.02 error on your Lexmark 792 printer indicates a system board issue. Troubleshoot it step by step:
Power off the printer: Turn off the printer and allow it to remain powered off for 10 to 20 seconds before turning it back on.
Check the code level:
You can identify the current code level using either of the following methods:
Method 1: Print the Menu Settings Page:
Touch the Menu button on the printer's operator panel.
Select Reports.
Choose Menu Settings Page to print the page.
Look for the code level under Device Information.
Method 2: Use the Printer's Embedded Web Server (EWS):
Open a web browser (such as Internet Explorer) and enter the printer's IP address.
Click on Reports and then select Device Information.
Download and install the latest firmware:
If your printer's code level matches any of the following:
For C792: LHS1.HC.P129 or LHS1.HC.P130
For X792: LHS1.MR.P131, LHS1.MR.P135, or LHS1.MR.P135a
For X925: LHS1.HK.P136a
Proceed to download and install the latest firmware.
For C792: LHS1.HC.P131 or later
For X792: LHS1.MR.P135b or later
For X925: LHS1.HK.P136b or later
Contact Lexmark Technical Support for service.
Update the firmware:
Download the latest firmware from the Lexmark Support website.
Save the file and extract it to the same directory.
Use the appropriate Authorization Keycode:
For Lexmark C792: c792
For Lexmark X792: x792
For Lexmark X925: x925
Update the firmware using one of the following methods:
Embedded Web Server (EWS): Open a browser, enter the printer's IP address, and select Settings > Update Firmware.
USB utility: Follow the detailed steps for updating via USB flash utility.
USB thumb drive: Refer to the steps for updating using a USB thumb or flash drive.
FTP: Follow the steps for updating via FTP.
If you need further assistance, please contact Lexmark Technical Support. When calling, have your machine/model type and serial number (SN) ready.
956.01 system board error ' Lexmark C792
Error Codes > Lexmark > X792dtse > Code 956.02 (printcopy.info)
