20 Most Recent HP PL4245N 42 in. HD-Ready Plasma Television Questions & Answers
I have a Panasonic Plasma while I am watching T.V.
It could be a power supply issue...Check the filter caps to see if any are leaky...bulged at the top, or if you have an ESR meter you can check them in ckt for excessive series resistance...in order to check for capacitance, they will need to be removed for that test...hope this helps....
11/10/2017 8:05:28 AM • HP PL4245N 42... • Answered on Nov 10, 2017
I have a Toshiba 50hp66.
Maybe you have a short circuit. But all the way. Take the board outside of the monitor. Try to start them: if the problem happens again you're lucky. If the board remains up and running, is your screen who have a problem and then you don't have 1000 possibilities. Found the problem or change screen.
5/30/2017 6:17:46 PM • HP PL4245N 42... • Answered on May 30, 2017
Our HP5060N/ HP PL4260N Plasma
Hi, I have just experienced the exact same loud pop sound. Then no picture or sound. Just died. Spoke with a rep at HP and was told that this (having owned for 4 years) is out of warranty and the "main board" has died. It will cost $629.00 plus tax to repair. This would provide a 90 day warranty on those parts replaced. It's about the same to buy a new tv! So I am throwing this JUNK away and will never buy HP again. Best of luck to you all!
8/6/2011 1:59:53 AM • HP PL4245N 42... • Answered on Aug 06, 2011
Looking for universal code for
Hi
Check with this code. it is for motorola s set top box.
MOTOROLA HDT100 [0618]
OK
7/10/2011 4:47:45 PM • HP PL4245N 42... • Answered on Jul 10, 2011
I have a HP PL4245N
Hello
I thinks you may be right. All plasma and LCD panel tVs will have cooling fans at the top side. Plasma screens will heat up much more, and if cooling fans stops work, of has damaged, the set will overheat, and awill automatically shut down; because there is a overheat sensor fitted inside it, will sense the heat, and if the set overheats, it will send a signal to the main system control fo the TV; which in turn shut down the whole system. look fans for proper working. If not replace them. OK.
7/4/2011 6:01:21 PM • HP PL4245N 42... • Answered on Jul 04, 2011
I have a Hp PL4245N
usually means a dead power board/inverter board. need to swap out to confirm.
6/12/2011 5:23:53 PM • HP PL4245N 42... • Answered on Jun 12, 2011
Screent just went blank but
Inverter problem change it.
2/8/2011 11:44:46 PM • HP PL4245N 42... • Answered on Feb 08, 2011
HELP! A growth is taking over my plasma screen!
This sounds like a problem with gas in the panel, early plasmas suffered with similar problems and was due to excessive periods when they were stored face down, a plasma must always be stored verticle and not laid down.
I cannot help you with this but if its under warranty it could be due to either warehouse storage or the carrier.
1/14/2011 3:34:08 AM • HP PL4245N 42... • Answered on Jan 14, 2011
2answers
I have a 3501q00200a powerboard in a 50hp66
The voltage regulator goes bad when that happens. its located on the power supply.
You would need to replace that and test the resistors next to it for the proper value.
For any parts you can get them at tvpartsandmanuals online. if you have a voltage meter
set it up on ohms and test the resistors, check the color codes to determined the value.
black for 0
brown 1
red 2
orange 3
yellow 4
green 5
blue 6
violet 7
gray 8
white 9
those are your color codes.. for any more questions. you can ask me at [email protected]
12/21/2010 5:38:40 PM • HP PL4245N 42... • Answered on Dec 21, 2010
I bought the 42inches tv
This tv is not useable in Nigeria,bcause Nigeria tv signal is used as PAL frequencies.The tv u bought in the US it used as NTSC frequencies.Sorry this tv is useless in Nigeria,can't be modifies it to PAL signal frequencies to use in Nigeria.Buy a tv from Europe,Asia or the Middle EAST all the tvs from these countries used PAL signal frequencies.It will work in Nigeria.
11/12/2010 10:17:32 AM • HP PL4245N 42... • Answered on Nov 12, 2010
Flashing on my vizio 47' tv. sometimes slow
so did u fix it and about how much did it cost u because im having the flashing problem only
8/21/2010 12:20:19 AM • HP PL4245N 42... • Answered on Aug 21, 2010
3answers
HP PL4245N - Fails to Power On
I have the same problem with the lights. Already replaced the main board and y-sus - didnt seem to fix. any help?
7/3/2010 11:59:56 PM • HP PL4245N 42... • Answered on Jul 03, 2010
2answers
Looking for replacement circuit board for HP TV
On ebay for less than $100
4/2/2010 4:39:27 PM • HP PL4245N 42... • Answered on Apr 02, 2010
42 in magnavox plasma tv has sound with no picture
Hi my name is Roety,
I can help you with your issue ,
If you have no TV menu either check for any swollen capacitors on the power supply.
If none are found measuring voltages will localize the defective board or boards the voltage test points are marked VA and VS on the panel and boards.
If disconnecting boards restores these voltages the suspected boards must be replaced .
Tech labor is about $250 plus parts.
Suspected boards
power supply
Y sus main & Y buffers
Logic board
mainboard
panel
If I have helped you with your issue
If you have more questions you can still respond
I will reply asap
Thanks I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
12/30/2009 12:33:44 PM • HP PL4245N 42... • Answered on Dec 30, 2009
Same Problem
yes.they should replace the tv
9/11/2009 7:53:04 AM • HP PL4245N 42... • Answered on Sep 11, 2009
2answers
Magnavox 42" tv has no picture, but still has sound
YOU MAY HAVE BAD Z SUS BOARD
8/24/2009 9:56:35 PM • HP PL4245N 42... • Answered on Aug 24, 2009
Same problem as rrobert4
The power supplies in modern TV sets are absolutely miserable and probably half of all problems stem from power supply malfunctions, not caused by circuits beyond them.
BTW, the main filter caps that you are replacing don't fail that often. Mostly it is lower value, lower voltage caps in the supplies feedback path that keeps the supply regulated and running are at fault.
7/17/2009 9:41:54 PM • HP PL4245N 42... • Answered on Jul 17, 2009
HP PL4245N 42 in. HD-Ready Plasma Television Logo
43 questions posted
Top HP Televison & Video Experts
 Mikey
Mikey
Stan Ford
Are you a HP Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • HP Televison & Video
Most Popular Question
hp pl4245n
  • Televison & Video
