20 Most Recent Kenwood KDC-C717 10-Disc CD Changer Questions & Answers
What is the yellow power output wire for on my 10
yellow goes to a constant power source.
6/15/2010 5:20:47 PM • Kenwood KDC-C717... • Answered on Jun 15, 2010
Just recently i got
Take it back and smack them in the head...lol
3/15/2010 6:41:15 PM • Kenwood KDC-C717... • Answered on Mar 15, 2010
3answers
I have a kdc-c717. which players are compatible
By players? do you mean DVD?
Please re-word your question to exactly what you are looking to do.
Thanks!!
2/18/2010 2:29:36 PM • Kenwood KDC-C717... • Answered on Feb 18, 2010
I am looking for a
I would recommend Kenwood KDC-W6041U.
You can purchase online from the Amazon link below:
http://www.amazon.co.uk/Kenwood-KDC-W6041U-AAC-CD-Receiver-Interface/dp/B00175GFLA
From the above link, you will find other Kenwood compatible cd players for for your kenwood changer.
Best regards.
2/17/2010 10:56:22 PM • Kenwood KDC-C717... • Answered on Feb 17, 2010
When I select the CD
The loader can not load the cd's due to a worn out plastic gear. The plastic gear drives the loader and locks it in place. Have a qualified person check it out and replace the gear.
Gerald,
Kenya
8/25/2009 7:48:08 PM • Kenwood KDC-C717... • Answered on Aug 25, 2009
2answers
Can't eject cd magazine - E-99 error message
I had the same problem. I opened up the unit and found out that there is a plastic gear that moves the loader. When worn the loader can not load tha magazines nor change cd's. I replaced the gear and the cd autochanger worked fine.
Gerald,
Kenya.
8/25/2009 7:33:58 PM • Kenwood KDC-C717... • Answered on Aug 25, 2009
Need a wiring schematic KDC C717
Black typically goes to ground.
Red goes to battery (+) (+ all the time)
Yellow typically goes to switched power (+ when ignition in run position)
3/6/2009 9:06:14 PM • Kenwood KDC-C717... • Answered on Mar 06, 2009
0answers
My kenwood kdc-u2159b display call n no sound out
Me radio kdc2159b is displaying the ward call,how do i remove it
4/14/2024 10:44:35 AM • Kenwood Car... • Answered on Apr 14, 2024
Reset a Kenwood 8070 without a remote?
To reset a Kenwood 8070 receiver without a remote, you typically need to locate the reset button on the device itself. This button is often small and recessed, so you may need a paperclip or a similar tool to press it. Consult the user manual or look for the reset button near the power or input/output ports on the receiver. Once located, press and hold the reset button for a few seconds until you see the receiver reset. Keep in mind that this process may vary slightly depending on the specific model of the Kenwood 8070 receiver.
3/6/2024 3:50:24 AM • Kenwood Car... • Answered on Mar 06, 2024
KDC-138 CD PLAYER/RECEIVER. What does code E-004 indicate?
Kenwood KDC-138 Instruction Manual [Page 18]
ManualsLib https://www.manualslib.com > ... > Instruction manual If the "E-99". code does not disappear, consult your. nearest service center. IN (Blink):. The CD player section is not operating. properly. ? Reinsert the CD.
My Kenwood KDC-d301 is giving me a E-4 error message ...
JustAnswer https://www.justanswer.com > car-electronics Aug 9, 2010 - Hello, The issue is most likely that the laser lens in the CD player itself is dirty, and not the disc. It may have been initially caused by a ... 1 answer · Top answer: You need the Kenwood radio keys that came with the unit to slide it out of the dash. It sounds ... Missing: 138 ‎' Show results with: 138
I have a KDC 138. It is stuck on OCER and will not reset.
JustAnswer https://www.justanswer.com > car-electronics > 5lw8u-... Sep 27, 2011 - This actually is DCER - you have a blown speaker. The radio is sensing a ground on the speaker circuit. Check that and let me know. If you leave ... 1 answer · Top answer: Thanks for stopping by: This actually is DCER - you have a blown speaker. The radio is sensing ... Missing: E- ‎' Show results with: E-
Cd Player Unit - Kenwood KDC-138/138CR Service ...
ManualsLib https://www.manualslib.com > ... > Service manual Kenwood KDC-138/138CR Manual Online: components description, Electric Unit, Switch Unit, Cd Player Unit. Controls Fm/Am Tuner, The Changer, Cd Mechanism, ...
2/16/2024 6:44:56 PM • Kenwood Car... • Answered on Feb 16, 2024
How to power supply of kCSWA900 Kenwood sub whooper power supply 10 pin
Take a look at this manual diagram. https://www.manualslib.com/manual/359815/Kenwood-Ksc-Sw10.html?page=5#manual Given the above is not your model, at least it shows the 10 pin. Ironically, below I offer a diagram of your model. The irony comes in the fact that the diagram appears labeled in Japanese But if you compare the two diagrams, maybe something will make sense from the one with the English labels. Otherwise, you might fire off a query to Kenwood customer support. https://www.manualscenter.com/manuals/kenwood/kscsw900-owner-manual.html Here is a 10 pin harness compatible with the subwoofer. Kenwood Subwoofer Amp KSC Wa100 Wa80 Sw10 10 Pin Harness for sale online ' eBay I don't have any information on how to power supply a kCSWA900 Kenwood subwoofer. However, I can tell you that the Kenwood KSC-SW10 compact powered subwoofer has a built-in amplifier with a 38 watts RMS power and a wired remote for control over volume level, variable low-pass crossover (50-120 Hz), and selectable phase control (0°, 180°) . The subwoofer comes with a power/ground wiring harness and preamp (RCA) and speaker-level inputs .
1/26/2024 3:58:54 AM • Kenwood Car... • Answered on Jan 26, 2024
2answers
Kenwood KDC-C717 10-Disc CD Changer Logo
Popular Tags
23 questions posted
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Kenwood Car Audio & Video
Most Popular Question
kdc c717 players compatible
  • Car Audio & Video
