20 Most Recent Kenwood KDC-3022 CD Player Questions & Answers
When i type in the 4 digit code is there an enter button or should it unlock if enterd correcltly
You have to press the same button you pushed to move the cursor to the right. Once you do that it should "unlock"
11/2/2014 3:59:39 AM • Kenwood KDC-3022... • Answered on Nov 02, 2014
How do i switch to
the cd player says it can receive mp3 music recording
9/25/2010 2:53:20 PM • Kenwood KDC-3022... • Answered on Sep 25, 2010
Restart code
Hold the Display & press Vol. UP AT LEAST 3 SECONDS. THE "----" WILL DISSAPREAR. NOW TAKE YOUR REMOTE AND DIGIT "KCAR" WITH THE NUMBER PAD.
PRESS "5", "5", >>| (NEXT TRACK) YOU GOT A "K"
PRESS "2", "2","2" >>| (NEXT TRACK) YOU GOT A "C"
PRESS "2", >>| (NEXT TRACK) YOU GOT A "A"
PRESS "7", "7", YOU GOT A "R"
PRESS >>| (NEXT TRACK)
IF DISPLAY SHOWS "APPROVED" YOU'RE DONE.
This method remove code.
Please let us know if that was helpful enough.
Good Luck & Thanks,
Shiv.
8/18/2009 11:26:13 PM • Kenwood KDC-3022... • Answered on Aug 18, 2009
I burned datadisk mp3 but i dont hear the music
Go here and read please. i have same problem with NEW KDC W 3537G.
http://www.kenwood.com/audiofile/kdc_mp4036/english.html
Best wishes from sahib
6/14/2009 1:14:07 AM • Kenwood KDC-3022... • Answered on Jun 14, 2009
0answers
Kdc-w7531
Be the first to answer 3/18/2009 3:28:37 PM • Kenwood KDC-3022... • Posted on Mar 18, 2009Be the first to answer
Kenwood car radio code
Did you ever enter a code that you chose? If so, reenter it. If not, call kenwood with serial # and they can tell you the oem preset code.
1/5/2009 2:08:23 AM • Kenwood KDC-3022... • Answered on Jan 05, 2009
Wont work
DOES it ask for a code? check your power sources and make sure they are holding 12 volts.
1/2/2009 7:13:26 AM • Kenwood KDC-3022... • Answered on Jan 02, 2009
Kenwood kdc-3022
the only way you can get the code is to ring kenwood with the make and model or try 0123 ,1234,0000,4321
7/29/2008 4:58:49 PM • Kenwood KDC-3022... • Answered on Jul 29, 2008
Need code
only the original owners manual for the cd player has it as it is meant to prevent a theif from using it of selling it you can down load a copy of the manual at www.kenwood.com from the instruction manuals page
3/27/2008 3:36:39 AM • Kenwood KDC-3022... • Answered on Mar 27, 2008
Cd won't eject
can u take face off hit eject from behind it ? thers emgency eway but u need to pull whole unit out and on toppush it out
2/8/2008 5:02:38 AM • Kenwood KDC-3022... • Answered on Feb 08, 2008
My kenwood kdc-u2159b display call n no sound out
Me radio kdc2159b is displaying the ward call,how do i remove it
4/14/2024 10:44:35 AM • Kenwood Car... • Answered on Apr 14, 2024
Reset a Kenwood 8070 without a remote?
To reset a Kenwood 8070 receiver without a remote, you typically need to locate the reset button on the device itself. This button is often small and recessed, so you may need a paperclip or a similar tool to press it. Consult the user manual or look for the reset button near the power or input/output ports on the receiver. Once located, press and hold the reset button for a few seconds until you see the receiver reset. Keep in mind that this process may vary slightly depending on the specific model of the Kenwood 8070 receiver.
3/6/2024 3:50:24 AM • Kenwood Car... • Answered on Mar 06, 2024
KDC-138 CD PLAYER/RECEIVER. What does code E-004 indicate?
Kenwood KDC-138 Instruction Manual [Page 18]
ManualsLib https://www.manualslib.com > ... > Instruction manual If the "E-99". code does not disappear, consult your. nearest service center. IN (Blink):. The CD player section is not operating. properly. ? Reinsert the CD.
My Kenwood KDC-d301 is giving me a E-4 error message ...
JustAnswer https://www.justanswer.com > car-electronics Aug 9, 2010 - Hello, The issue is most likely that the laser lens in the CD player itself is dirty, and not the disc. It may have been initially caused by a ... 1 answer · Top answer: You need the Kenwood radio keys that came with the unit to slide it out of the dash. It sounds ... Missing: 138 ‎' Show results with: 138
I have a KDC 138. It is stuck on OCER and will not reset.
JustAnswer https://www.justanswer.com > car-electronics > 5lw8u-... Sep 27, 2011 - This actually is DCER - you have a blown speaker. The radio is sensing a ground on the speaker circuit. Check that and let me know. If you leave ... 1 answer · Top answer: Thanks for stopping by: This actually is DCER - you have a blown speaker. The radio is sensing ... Missing: E- ‎' Show results with: E-
Cd Player Unit - Kenwood KDC-138/138CR Service ...
ManualsLib https://www.manualslib.com > ... > Service manual Kenwood KDC-138/138CR Manual Online: components description, Electric Unit, Switch Unit, Cd Player Unit. Controls Fm/Am Tuner, The Changer, Cd Mechanism, ...
2/16/2024 6:44:56 PM • Kenwood Car... • Answered on Feb 16, 2024
How to power supply of kCSWA900 Kenwood sub whooper power supply 10 pin
Take a look at this manual diagram. https://www.manualslib.com/manual/359815/Kenwood-Ksc-Sw10.html?page=5#manual Given the above is not your model, at least it shows the 10 pin. Ironically, below I offer a diagram of your model. The irony comes in the fact that the diagram appears labeled in Japanese But if you compare the two diagrams, maybe something will make sense from the one with the English labels. Otherwise, you might fire off a query to Kenwood customer support. https://www.manualscenter.com/manuals/kenwood/kscsw900-owner-manual.html Here is a 10 pin harness compatible with the subwoofer. Kenwood Subwoofer Amp KSC Wa100 Wa80 Sw10 10 Pin Harness for sale online ' eBay I don't have any information on how to power supply a kCSWA900 Kenwood subwoofer. However, I can tell you that the Kenwood KSC-SW10 compact powered subwoofer has a built-in amplifier with a 38 watts RMS power and a wired remote for control over volume level, variable low-pass crossover (50-120 Hz), and selectable phase control (0°, 180°) . The subwoofer comes with a power/ground wiring harness and preamp (RCA) and speaker-level inputs .
1/26/2024 3:58:54 AM • Kenwood Car... • Answered on Jan 26, 2024
2answers
Kenwood KDC-3022 CD Player Logo
21 questions posted
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Kenwood Car Audio & Video
Most Popular Question
need code
  • Car Audio & Video
