20 Most Recent Kenwood KDC-X589 CD Player Questions & Answers
2answers
My son took my car
HI, thanks for posting your Question..
Problem can be solved..What made the radio go off is because the battery was connected wrongly and it has affected a part in the car called (Fuse),not the radio..
But first, you will need to unscrew where the radio is connected to the car, there is a fuse that looks like the one at the below diagram that is located at the back of the radio.
How to test the radio. You can use the multimeter to verify power in the radio harness. Set the meter for DCV, 20v range. Pull the radio, connect the meter's black lead to a ground point (some metal part under the dash will do). Turn your key to the accessory position. Test for voltage on the black/pink wire and the green/violet wire. Both wires should show 12V; if you have voltage on both wires, and the radio isn't working, try disconnecting it for a minute to reset it. Plug it back in; if it doesn't work after that, it's defective.
After checking that , next step will be your main fuse box..
In a car, there is a place where all the fuse that controls a particular function in a car is located in the car,locate the fuse box ..
Use the diagram below for guide lines..
http://www.videojug.com/film/how-to-replace-a-blown-fuse
After checking those,keep me posted let me know ..
Goodluck...
8/25/2011 6:59:10 AM • Kenwood KDC-X589... • Answered on Aug 25, 2011
All sound is adjustable in
It seems possible that when the CD circuit is activated there is a higher transcient signal that seems to drive the SUB WOOFER AMPLIFIER to shut off as it seems to go into a PROTECT MODE.
So what needs to be checked is that the unit must be taken out and checked for any ground fault on the CD board.Disconnect the linking cord to the HEAD UNIT and check, If so there can be fault in the board/ optical unit.
Finally look out for loose ends of cable connectors, tighten them as a weak link can be open signal.
Check also the power to the CD board, check for any DRY SOLDERING POINTS.
8/1/2011 5:24:13 AM • Kenwood KDC-X589... • Answered on Aug 01, 2011
When I Installed the Radio
could be bad ground or you crossed the yellowwith the red wire. yellow is battery red is ignition and you usually dont use the other ones unless its a newer vehicle. also these ones have 2 blue wires 1 power ant and the remote lead
9/13/2010 7:48:34 AM • Kenwood KDC-X589... • Answered on Sep 13, 2010
What is the lock code for kenwood - kdc-x589
There are afew types of override procedures for Kenwood.
Type 1
During the code request mode, while holding the DISP key depressed, press and hold the Volume UP or DOWN key for 3 seconds (so that “…” disappears).
Then using your remote enter your code.
Type 2
Press the "Auto" button and "Track up" on face of radio at the same time. The four dash lines ( . . . . ) should "disappear".
Type 3
Model# DPX-4020 and DPX-4030
Press and hold the 1 then the 6 preset key (preset keys are the buttons on face of radio for storing you "favorite" radio stations). "C" should display.
Then using your remote, enter your code.
Enter your number from the remote control unit. Your code number is 5227 (KCAR)
* Press numeric key “5” ( 2 times ) and press the Track UP/Next Track key
* Press numeric key “2” ( 3 times ) and press the Track UP/Next Track key
* Press numeric key “2” ( 1 time ) and press the Track UP/Next Track key
* Press numeric key “7” ( 2 times ) and press the Track UP/Next Track key
The security is canceled and the set enters the TUNER mode!
"TRACK UP BUTTON" for 3 seconds.. and youre done.
8/10/2009 5:18:08 PM • Kenwood KDC-X589... • Answered on Aug 10, 2009
2answers
I want to change the clock on my Kenwood Excelon KDC-X589.
try in standby mode push the menu button scroll through with track button till you see clock adj if not in standby mode try it in cd mode same steps
8/10/2009 12:28:17 AM • Kenwood KDC-X589... • Answered on Aug 10, 2009
Kenwood KDC-X589 seems like the CD player doesn't put out sound
you have to change the cd read setting it might got set to cd read 2 it needs to be cd read 1 in standby mode press menu button scroll through with track button till you see cd read and set it to cd read 1 if not in standby mode try in cd mode same steps
5/30/2009 3:15:36 AM • Kenwood KDC-X589... • Answered on May 30, 2009
How do i turn off the "loud" option
hold down the volume knob then hpf will come up then press control knob till you get to loud setting and spin knob it will change to off
5/30/2009 3:12:37 AM • Kenwood KDC-X589... • Answered on May 30, 2009
Kenwood excelon kdc-x589 demo mode makes me mad
CLICK HERE for your owners manual in PDF format.
Cancelling the DEMO MODE is explained on page 29... as follows....
Select the Demonstration mode
Push the Control knob to [FM] or [AM].
Select the "DEMO" display.
Set the Demonstration mode
Press the Control knob for at least 2 seconds.
Each time the knob is pressed at least 2 seconds,
the Demonstration mode switches "on" or "off"
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
5/21/2009 4:18:19 PM • Kenwood KDC-X589... • Answered on May 21, 2009
Radio code
KENWOOD SECURITY CODE CLEAR procedure
Your radio will require one of the following procedures.
Type 1
Type 2
Type 3
1/15/2009 5:19:48 AM • Kenwood KDC-X589... • Answered on Jan 15, 2009
Kenwood Manual for KDC-X589
http://www.retrevo.com/support/Kenwood-KDC-X589-Car-Receivers-manual/id/479dj585/t/2/
There you go, i dont know if you already found it but there it is for anyone else as well.
1/9/2009 11:38:51 PM • Kenwood KDC-X589... • Answered on Jan 09, 2009
My kenwood kdc-u2159b display call n no sound out
Me radio kdc2159b is displaying the ward call,how do i remove it
4/14/2024 10:44:35 AM • Kenwood Car... • Answered 2 days ago
Reset a Kenwood 8070 without a remote?
To reset a Kenwood 8070 receiver without a remote, you typically need to locate the reset button on the device itself. This button is often small and recessed, so you may need a paperclip or a similar tool to press it. Consult the user manual or look for the reset button near the power or input/output ports on the receiver. Once located, press and hold the reset button for a few seconds until you see the receiver reset. Keep in mind that this process may vary slightly depending on the specific model of the Kenwood 8070 receiver.
3/6/2024 3:50:24 AM • Kenwood Car... • Answered on Mar 06, 2024
KDC-138 CD PLAYER/RECEIVER. What does code E-004 indicate?
Kenwood KDC-138 Instruction Manual [Page 18]
ManualsLib https://www.manualslib.com > ... > Instruction manual If the "E-99". code does not disappear, consult your. nearest service center. IN (Blink):. The CD player section is not operating. properly. ? Reinsert the CD.
My Kenwood KDC-d301 is giving me a E-4 error message ...
JustAnswer https://www.justanswer.com > car-electronics Aug 9, 2010 - Hello, The issue is most likely that the laser lens in the CD player itself is dirty, and not the disc. It may have been initially caused by a ... 1 answer · Top answer: You need the Kenwood radio keys that came with the unit to slide it out of the dash. It sounds ... Missing: 138 ‎' Show results with: 138
I have a KDC 138. It is stuck on OCER and will not reset.
JustAnswer https://www.justanswer.com > car-electronics > 5lw8u-... Sep 27, 2011 - This actually is DCER - you have a blown speaker. The radio is sensing a ground on the speaker circuit. Check that and let me know. If you leave ... 1 answer · Top answer: Thanks for stopping by: This actually is DCER - you have a blown speaker. The radio is sensing ... Missing: E- ‎' Show results with: E-
Cd Player Unit - Kenwood KDC-138/138CR Service ...
ManualsLib https://www.manualslib.com > ... > Service manual Kenwood KDC-138/138CR Manual Online: components description, Electric Unit, Switch Unit, Cd Player Unit. Controls Fm/Am Tuner, The Changer, Cd Mechanism, ...
2/16/2024 6:44:56 PM • Kenwood Car... • Answered on Feb 16, 2024
Kenwood KDC-X589 CD Player Logo
Popular Tags
21 questions posted
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Kenwood Car Audio & Video
Most Popular Question
want change clock kenwood excelon kdc
  • Car Audio & Video
