20 Most Recent
Kenwood KDC-2025 CD Player Questions & Answers
Kenwood KDC-2025 won't play CDs
source
http://www.kenwood.nl/support/veelgestelde_vragen/
Changer Error Codes
? E-00: Poor Cable connection.
? E-01: Magazine not properly set in changer.
? E-02: No Disc in magazine.
? E-03: CD does not have selected track number.
? E-04: Disc is dirty, upside down or unreadable.
? E-10: No data is recorded on the MD. The player plays the next disc automatically.
? E-99: Changer malfunction, disc may be caught in machine or changer requires service.
I suggest the lens needs a clean, or someone has dropped it and broken the delicate lens mech.
Luck
Wiring diagram
Memory (+12v Constant)
Yellow
Ignition (+12v Switched)
Red
Ground (-)
Black
Dimmer
Pink/White (Alpine only)
Power Antenna
Blue
Amplifier Turn-on
Blue/White
Phone Mute
Light Blue (Sony only)
S p e a k e r s
Right Front (+)
Gray
Right Front (-)
Gray/Black
Left Front (+)
White
Left Front (-)
White/Black
Right Rear (+)
Violet
Right Rear (-)
Violet/Black
Left Rear (+)
Green
Left Rear (-)
Green/Black
NO SOUND
try wiring the speakers up directly to the stereo instead of the wires that are already in the car, if it doesnt work then give up
Cd is struck in my kenwood?
if you have a screw in the side of the deck, unscrew it a little and the cd should come out, i did the same thing
What do i do?
If you press the src button it should change to tuner and if it doesn't you could try resetting the unit, there are two ways to do this firstly you could just unplug the power lead or you could locate the reset button on the front of the radio and using a pencil press it briefly and then try your set again.
CODE POP UP
get back to me here if you have anymore to add... A NEW ONE CAN BRING EXTRA JOY. Good Luck
regards
Graeme
My kenwood kdc-2025
Try loading a disc to see if it will play, if it does see if any of the function buttons work. My guess is that it might actually play cd's if they are loaded but keyboard might not be functioning for some reason. if you need service manual I may be able to help
[email protected]
