20 Most Recent Line 6 Flextone III Plus Guitar Amplifier Questions & Answers
Flextone 3 one speaker not working
Then you either have a blown amp or speaker. Turn the amp off and move the wires from the speaker on the working side to the other speaker. If the other speaker works, you have a dead amp channel. if it does not, move the wires from the speaker on the non-working side to the other speaker. If that works, you have a dead speaker. Dead amp channel means take it to the shop. Dead speaker means buy a new one from Line 6 and install.
11/25/2014 10:44:53 PM • Line 6 Flextone... • Answered on Nov 25, 2014
Speaker not working
try switching the leads on each speaker. if sound transfers then you have a bad channel. if you get no sound, then your speaker is bad.
4/18/2014 2:25:54 AM • Line 6 Flextone... • Answered on Apr 18, 2014
The parameters shift up and down while playing
if you're using a pedal. the cat 6 wire that connects the pedal to the amp. can be coming out of the "phone jacks" that line 6 uses, all it takes is for that wire to stretch and if one line breaks . it changes the protocol. sounds like yours is intermittent. put new connectors on each end (after checking continuity),
4/9/2014 7:28:21 AM • Line 6 Flextone... • Answered on Apr 09, 2014
The entire control board on
There is probably a power supply failure or with the power on reset circuit. Likely low voltage to the logic electronics. This is NOT DIY unless you are familiar with electronics.
4/22/2011 3:41:08 PM • Line 6 Flextone... • Answered on Apr 22, 2011
I bought a used line
Google is your friend to find the download:
http://line6.com/support/manuals/?families=7&submit=Submit&1st=1st
2/13/2011 6:33:42 AM • Line 6 Flextone... • Answered on Feb 13, 2011
Line 6 Low Down 400 bass guitar head
Make sure the volume and master volume are turned up. Try the amp with a different cabinet and a known good speaker cable. If you get sound, it's your speakers or your speaker cable. If still no sound, you need your amp serviced.
10/20/2018 1:02:56 AM • Line 6 Music • Answered on Oct 20, 2018
0answers
3answers
My line 6 lowdown 750 keeps cutting out when i play a low b on my bass
Protective circuits kicking in. You may be overdriving the preamp to a clipping condition the amp sees as a problem. If it is under warranty, contact Line 6 and see if this is normal for this amp. It should not be, but you never can be sure.
7/7/2014 2:15:18 PM • Line 6 Music • Answered on Jul 07, 2014
0answers
0answers
Tda 75 72r
Be the first to answer 1/21/2014 2:25:08 PM • Line 6 Music • Posted on Jan 21, 2014Be the first to answer
0answers
No sound at all
Be the first to answer 1/15/2014 10:58:18 PM • Line 6 Music • Posted on Jan 15, 2014Be the first to answer
0answers
Spider valve 112
Be the first to answer 1/10/2014 4:35:33 AM • Line 6 Music • Posted on Jan 10, 2014Be the first to answer
Line 6 Flextone III Plus Guitar Amplifier Logo
7 questions posted
Top Line 6 Music Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Line 6 Music Expert? Answer questions, earn points and help others
View Most Popular
Line 6 Music
  • Line 6 Music
Most Popular Question
flextone 3 one speaker not working
  • Music
