20 Most Recent Kenwood CD-203 5-Disc CD Changer Questions & Answers
Cd player makes humming sound
You may have a bad RCA cable connecting it to them receiver/amp. Another possibility is that the power to the CD Player (If not polarized) need to be flipped. Good luck and be careful!
1/20/2013 9:38:48 PM • Kenwood CD-203... • Answered on Jan 20, 2013
Kenwood cd-203 5 cd humming sound
Check your RCA cables to make sure that they are not dirty, tarnished or not completely plugged in. Also, try switching to different (working!) RCA cables to see if that fixes the noise problem. Good luck!
1/20/2013 9:35:36 PM • Kenwood CD-203... • Answered on Jan 20, 2013
2answers
Bad line output jacks
this is a common problem with output jacks. the solder dries up over time and making it brittle and working its way loose. try resoldering the connections and all should be well.
12/23/2011 11:40:38 AM • Kenwood CD-203... • Answered on Dec 23, 2011
0answers
0answers
Can i use this unit in south america?
Sure if you have the necessary ac transformers to convert local juice to whatever it requires. It's a very common practice.
4/7/2011 8:32:56 PM • Kenwood CD-203... • Answered on Apr 07, 2011
Copied Audio CD not recognized
Audio CD copying is in fact very easy process and almost every CD Player accept it.
If CD-203 is few years old then optical lens would be little bit dusty and needs cleaning, take off top cover of player by removing its sides and rear screws and clean its optical lens with good quality cotton swab (q-tip) gently in circular motion and check.
Optical block emits laser that reflects back in optical block from CD surface that contains data, normal CD has 100% reflection but recorded CD reflection is approx 70% and little bit dusty lens reduce the reflected laser amount back in optical block that makes impossible to read data on disc surface.
Hope these info will help.
Thanks.
4/1/2011 5:11:49 PM • Kenwood CD-203... • Answered on Apr 01, 2011
Discplayerwontplay open or rotate
You will need to take off the surround metal and look down into the disc changer. There are gears mixed with small belt drives that are used to open and rotate the disc changer. If the teeth of the gear or the rubberbands are snapped this will cause the player to not work properly.
Please accept if this helpful.
Thank you
3/3/2011 4:17:59 PM • Kenwood CD-203... • Answered on Mar 03, 2011
SKIPS, SOMETIMES CUTS OFF, SOMETIMES DOES NOT PLAY
it sounds like it needs to be cleaned with a cd cleaner.
2/14/2011 3:39:01 PM • Kenwood CD-203... • Answered on Feb 14, 2011
0answers
KENMORE ELITE WASHER error (DL) then (F)
1. Unplug washer.
2. Remove the outer portion of the door bellow. This is the gray rubber boot around the door. Feel around the edge of the door bellow where it attaches to the front of the washer. You will find a wire retaining hoop in the seam between the rubber and the front case. Follow this wire hoop to the bottom of the door bellow and you will find a tension spring. Carefully, stretch this spring apart and remove the wire hoop.
3. Pull the rubber bellow from the door facing on the front of the washer being careful not to rip or tear it. Once removed, fold the rubber backwards inside the drum so you can access behind the front panel. DO NOT remove the rubber bellow from the wash tub.
4. The door latch assembly is located behind the front panel of the washer on the right hand side. Locate and remove the three screws on the washer front that hold the door latch assembly in place. The whole assembly should come free from the washer front and be held by a plastic mounting bracket and several wire connectors.
5. Carefully remove the latch assembly from the plastic mounting bracket BEFORE attempting to unplug any wires. It makes it much easier to access if you do.
6. Unplug the wire connectors using care not to break any of the wires. You may want to write them down, but I believe they will only plug into their respective slots.
7. Remove the old door latch and install the new one in the reverse order of the steps I just presented to you. Plug the wires back in first, then place the whole assembly back into the plastic mounting bracket, and then reattach to the front of the washer.
8. Now, when you get the reinstalling the rubber door boot, you may want to get the assistance of a second pair of hands as it can be difficult sometimes to manipulate the wire retainer back into place. Carefully reattach the rubber bellow to the door facing on the front of the washer first.
9. Starting at the top of the door bellow at the 12 o'clock position begin inserting the wire hoop back into the groove. Work your way around with both hands to the 4 and 8 o'clock positions. (This is where you could use those second pair of hands). While holding a slight downward tension on the wire hoop to keep it in place, pull the tension spring apart enough to snap the remaining part of the hoop into place at the bottom. Once you've completed these steps make sure the door closes and latches properly. NEVER slam a door with an electronic latch. They can break easily.
Now plug the washer back in and test operate. NOTE: You can run diagnostics on these washers by referring to the tech sheet provided by the manufacturer. The tech sheet is located behind the lower panel under the door, or along the interior cabinet walls. Included, are instructions on how to run diagnostics and troubleshooting tips associated with the list of fault codes. It is recommended that this tech sheet remain inside the washer to prevent it from being lost.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!!!!!!!!!!!!!!
9/16/2010 5:18:28 PM • Kenwood CD-203... • Answered on Sep 16, 2010
Kenwood CD-203 5-Disc CD Changer will not play CDs
The laser might be the culpert, be sure its clean by using a swab and a alcohol. If the laser is needed
it could cost approx $75 unless their using a Sony
which might be cheaper!
4/17/2010 5:30:46 PM • Kenwood CD-203... • Answered on Apr 17, 2010
Kenwood cd player not working correctly
there is a ribbon cable that goes to the screen from the main board that may have come unplugged. you'll have to remove the top case to see.
12/17/2009 2:24:18 PM • Kenwood CD-203... • Answered on Dec 17, 2009
Kenwood cd stopped pla computer made cds after i dropped it now will play for about 1min then stops
hi 1paullawrenc, try get your lens cleaned by using a lens cleaner hope this solve your problem.
raj..
7/7/2008 4:46:48 PM • Kenwood CD-203... • Answered on Jul 07, 2008
Kenwood surround sound receiver krf-7050d stuck on mute
Check the Remote Control: Ensure that the remote control is functioning correctly. Press the MUTE button on the remote control to unmute the sound. The "MUTE" indicator should turn off. Manual Adjustment: Navigate to the receiver's setup menu and locate the audio settings section. Adjust parameters such as bass, treble, balance, and surround sound modes to achieve your desired audio quality. Physical Connections: Verify that all audio cables are securely connected to the appropriate inputs and outputs. Check if any cables are damaged or loose. Speaker Configuration: Make sure your speakers are correctly configured. If they are set to "Mute", unmute them. Factory Reset: Refer to the instruction manual for instructions on performing a factory reset.
4/3/2024 3:18:34 AM • Kenwood Audio... • Answered on Apr 03, 2024
I have a kenwood ka-129 which is currently muted
No, you must press mute again on the remote to toggle off mute.
3/31/2024 9:08:56 PM • Kenwood Audio... • Answered on Mar 31, 2024
Need to know how to disable remote function for a Kenwood stereo integrated amplifier ka-129
You could put a peice of gaffa tape over the sensor window if you do not read schematics very well.
3/31/2024 9:07:55 PM • Kenwood Audio... • Answered on Mar 31, 2024
How do I change the input from analog to digital or optical on my Kenwood Kraft-v7772d? Thanks
To switch the input on your Kenwood KRF-V7772D receiver from analog to digital or optical, follow these steps: Check the Manual: First, consult the user manual for detailed instructions specific to your model. If you don't have the manual, you can find it online. The manual provides step-by-step guidance on how to change inputs. Input Selector Button: On the front panel of your receiver, look for the Input Selector button. It might be labeled as "Input," "Source," or something similar. Press this button to cycle through the available input sources. On-Screen Menu: Some receivers allow you to change inputs using an on-screen menu. If your Kenwood receiver has this feature, navigate to the menu using your remote control. Look for an option related to input selection or source. Remote Control: Use your remote control to directly select the desired input. Look for buttons labeled with input sources (e.g., "DVD," "CD," "TV," "Optical," etc.). Press the appropriate button to switch to the desired input. Digital Inputs: If you want to switch to a digital input (such as optical or coaxial), ensure that your digital audio source (e.g., Blu-ray player, game console, etc.) is connected to the corresponding input on the back of the receiver. For optical input, connect the optical cable to the "Optical In" port. Analog Inputs: If you prefer an analog input, connect your analog audio source (e.g., turntable, cassette player, etc.) to the appropriate analog input on the back of the receiver. Remember to adjust the settings on your connected devices (e.g., TV, Blu-ray player) to output audio through the selected input on the Kenwood receiver. If you encounter any issues, refer to the service manual for further troubleshooting
3/31/2024 6:30:55 PM • Kenwood Audio... • Answered on Mar 31, 2024
Kenwood CD-203 5-Disc CD Changer Logo
19 questions posted
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Ngoro
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Kenwood Audio Players & Recorders
Most Popular Question
copied audio cd not recognized
  • Audio Players & Recorders
