20 Most Recent
Memorex MVD2019 19 in. TV/DVD Combo Questions & Answers
Tv wont turn on
If you want to DYI this tv yourself be careful for voltages.
Check the power board for standby +5 volt to the power botton.
If there is none, check the powerboard for open contacts; fuses, fried resitors or the FET. A photo-coupler sometimes is also the problem. Its a small black part with 4 to 6 pins that overbridge and regulate the need for voltages from the main and the powerboard.
If there is power but the tv still wont start, check the horizontal output.
Success
My Memorex remote control no work, and I by
If you are sure the original remote works before and after the battery change then you have a problen with the IR-receiver of the tv set. Simple test to check your original remote is using a pocket radio, set on AM frequentie and press any botton one by one holding the remote close to the receiver of the radio. If your remote is alright it has to make a whinning sound (a high freuqeuntie pitch sound).
There are different kind of IR receiver so you need the right part to replace it. Or take the set to the shop.
Memorex MVD2019 programing remote control
Try "auto search" with your remote. Normally you press the dish button and the "OK/Select" button simultaneously for about 3 seconds untill the dish light burns steady. Then press "channel up" one press at a time until the dish turns off. When it turns off, then press "power" on your remote and if the dish comes back on, test the other functions such as volume and mute. If all functions work, then press the "dish" button one more time to save the code and then you are "in business". If functions do not work, then continue to press "channel up" until the dish shuts off a second time. Then press "power" and test all functions. Continue repeating this until you find a code that enables all desired functions. Hope this helps.
Keever
My memorex hdmi mirror for android isn't putting out wifi signal
It seems like the Wi-Fi module on your Memorex HDMI Mirror may be faulty or malfunctioning, preventing it from broadcasting a Wi-Fi signal. Here are a few troubleshooting steps you can try:
Make sure your Memorex HDMI Mirror is within range of your Wi-Fi router. Move it closer to see if it picks up the signal.
Reset the Wi-Fi module by pressing and holding the reset button on the device for at least 10 seconds. Make sure the device is not connected to the TV while doing this.
Try connecting the Memorex HDMI Mirror to a different HDMI port on your TV to see if that resolves the issue.
Check if there are any firmware updates available for the device. If there are, update the firmware and try again.
If none of the above steps work, you may need to contact Memorex customer support or take the device to a repair shop to have it checked for any hardware issues.
2/24/2023 2:32:24 PM •
Memorex...
Answered
on Feb 24, 2023
How do I power on my Memorex HDMI screen mirroring device
- Make sure the device is properly plugged into a functioning HDMI port on your TV.
- Check the power cord for the device to make sure it is properly plugged into a functioning outlet.
- Check the TV's settings to ensure that the correct HDMI input is selected.
- Press the power button on the device to turn it on. If the device has a separate power switch, make sure it is in the "On" position.
1/3/2023 11:31:16 PM •
Memorex...
Answered
on Jan 03, 2023
My memorex hdmi mirror for android isn't working
Once memorex is connected to your tv and you've provided the correct username and password for your hotspot, then everything should work at least at some pace.
Please keep in mind that any type of streaming over mobile data maybe limited based on your mobile plan.
Whereas if you use, home or office based wifi, the streaming should be more fluid.
If still having an issue, please unplug and then plug back your memorex device before trying to connect to wifi again.
Thank you.
10/15/2022 9:37:43 PM •
Memorex...
Answered
on Oct 15, 2022
