20 Most Recent Philips HSB2313 Theater System Questions & Answers
The shutdown seems to be caused by overheating of the heatsink electronics. My unit has a fan on the heatsink. This fan started making a noise. When I remove it the system shuts down as described. I will try to replace the fan.
Philips HSB2313... | Answered on Aug 28, 2012
I have a service manual pdf there isn't any way to attach it to this message. Give me your email address and I'll send it to you. Or if you have some other way to send it electronically we can do that.
Philips Audio... | Answered on Nov 24, 2019
Hi Darshan Ganesh, you can connect your phone to your Philips D573
You must connect the audio audio output of your phone (headphone output) to the Philips Auxiliary input on the rear panel
Hola Darshan Ganesh, puedes conectar tu telefono a tu philips D573
Debes conectar la salida de audio de audio de tu telefono(salida de auriculares) a la entrada Auxiliar del Philips en el panel trasero
https://www.philips.ae/c-p/FWD573_98/-
Philips Audio... | Answered on Oct 22, 2019
Here is a diagram for you.
Philips Audio... | Answered on Sep 30, 2019
You need to check the file format on music, windows media play does not support their format ((*.ra, *.rm). You can change the format to mp3 or .wav using other software.
Philips Audio... | Answered on Aug 24, 2019
I have a multimedia speaker DSP 3300.but I haven't the remote .Is there any way to operate it.
Philips Audio... | Answered on Jul 16, 2019
Google (Philips)(DVT1250)(manual) without parens.
Philips Audio... | Answered on Jul 04, 2019
What is the format of the drive? The Philips HTS6510 can only read USB drives that are formatted as FAT16 or FAT32. It can't read files from an NTFS drive. NTFS is the "new file system" for Windows but dates to Windows NT/Windows 2K or so. This is the default format for larger capacity USB drives since more files can be added per folder. See page 51 of the manual for the Philips HTS6510 for the file format specifications for USB drives.
If the file format is FAT16 or FAT32, try a different USB drive and check the current drive in another device. The USB drive may be damaged or may have lost the data it needs to find the files. All flash memory can fail with no warning. Replace a faulty drive. Alternatively, the USB port on the HTS6510 could be damaged. This can happen if too much current flows through the port. If the port is damaged, I don't recommend having the unit repaired unless it is under warranty (1 year). Copy your files to a CD and listen to the music or view the images from that media. The overall cost will be lower.
Philips has the manual on the product support page: https://www.philips.co.uk/c-p/HTS6510_05/-/support . The current link to the manual is https://www.download.p4c.philips.com/files/h/hts6510_05/hts6510_05_dfu_eng.pdf .
I hope this helps.
Philips Audio... | Answered on May 28, 2019
????? ??????? model name:SP050????
Philips Audio... | Answered on May 16, 2019
all these things are deleted through menu setting etc.
Philips Audio... | Answered on May 15, 2019
Hello Nicholas, it would be nice if you commented that audio signals are connected to your Soundbar, in this way I could find the possibility of failure, to find the best possible solution
I wait your answer
Greetings Franco Dosil
Hola Nicholas, seria bueno que comentes que se?ales de audio tienes conectado a tu Barra de Sonido, de esta manera podre buscar que posibilidad de falla, para buscar la mejor solucion posible
Espero tu respuesta
Saludos Franco Dosil
https://data2.manualslib.com/pdf5/110/10927/1092650-philips/hts8100.pdf?c627f1691eabddb18405d1975afcf790&take=binary
Philips Audio... | Answered on May 08, 2019
Philips HSB2313 Theater System Logo
Popular Tags
4 questions posted
Top Philips Audio Players & Recorders Experts
 Grubhead
Grubhead
Ekse
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Philips Audio Players & Recorders
Most Popular Question
philips hsb2313 topow power supply
  • Audio Players & Recorders
