20 Most Recent
Sony PlayStation 3 (120 GB) Black Console Questions & Answers
Connect storage media at save destination
How much free memory is left, and how are you tying to download your data? Via internet, media server, or usb? For the bluetooth devices, they may not have the same signals as your ps3.
My ps3 comes on and
First of all dont panic!
it happens to everyone, we have 3 playstation 3's in our house.
basically all it has done is either run out of charge.
or has lost sync with your console.
all you need to do is connect it with the supplied cable and press the ps button.
all 4 lights will flash momenterally and it will re-synch or start charging.
How to play play ps2 games on your ps3
You can only play PS2 games on your PS3 if it is backwords compatible, and the easy way to find out is to see how many USB Ports are in front of the console. If you have 2 USB Ports, no go. If you have 4 USB Ports in front, it is backwords compatiable. Another easy way to find out is if you own a fat PS3 with 4USB Ports you are good to go, just pop the CD in and it will play. If you own a slim PS3, you are out of luck, when Sony intoduced the slim ps3, to save money, they removed the backwords compatible chip from the hardware inside.
I keep getting error code 80710092
If this error message occur when trying to connect network just go to media server settings in your PS3 and disable the streaming media servers
Can't play any ps2 games
You can try updating by connecting your PS3 to the internet and selecting SETTINGS > SYSTEM UPDATE. If your PS3 is not connected to the internet, you can manually download the update
here.You can place this file onto a USB drive to update. Create a folder called PS3 in the drive, then a folder called UPDATE inside that one, place the downloaded file there and insert the drive into your PS3. More info can be found
here.
I can not sign into play station network. internet
Happening all over the world
Hi there, unfortunately there is nothing you can do at the moment.
The playstation network is down worldwide. We just have to wait till sony fixes this
http://kotaku.com/#!5794265/is-the-entire-playstation-network-down
or
http://kotaku.com/#!5794440/sony-playstation-outage-likely-to-last-days
or
http://blog.us.playstation.com/2011/04/21/latest-update-on-psn-outage/
or
http://blog.us.playstation.com/2011/04/20/update-on-psn-service-outages-2/
Check the links for updates
How to connect my internet to my ps3
Error Code 80710A06??? Personally I think the network has been hacked. I don't believe any 'Routine maintenance' would take so long. PSN say the network could be down for a couple of days, so It'll be Saturday before we're all hopefully back online.
Hope this helps.
LJ.
It have dust all in it.so how do u clean it out
First you need make sure its off and unplugged completely. Then move it to a clear surface. after that get the suction hose off your vacuum and put it to the vents on both sides and front of your play station 3 and suction th dust out.
How to delete data on a game on a ps5
first you need to go to settings and then you need to scroll down until you see an option named saved data games/app settngs click on it and then if your game version is ps5 then go there and if it is ps4 go there, then there will be an option named console storage click and press "R1" on your controller to go to an heading named "delete" then select the game in which you want to erase the data and then select the option "delete", the game data will be deleted
