20 Most Recent
Vivitar ViviCam X029 Digital Camera Questions & Answers
Need image imager software to download
You don't need any special software.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or, despite what I said first, you can use any photo cataloging program such as Picasa (
http://picasa.google.com ).
Blurry pictures
Is your camera in the macro mode?There's a slide switch on the end of the camera, near the USB slot. Slide it from the flower to the mountain, then take a picture of something at least three meters (ten feet) away. Is it still blurry?
Need software
Picasa.
I just bought the camera
Are you charging it by plugging it into a computer? The "MSDC" you see usually means "Mass Storage Device Class", which basically means the computer is using the storage on the camera as a removable drive. This would usually happen when plugging a camera into the computer via USB. There is usually an AC adapter that comes with a camera, or a separate charger for just the battery. If there was no charger that came with it, the camera is probably still charging. If the camera is on, try turning it off and plugging it in. Remember, even if it shows "MSDC", it is probably still charging. Hope this helps!
Date and time
In Photo Capture Mode, press the SET button to bring up the menu. Use cursor-left/right to select "Date/Time" then use cursor-up/down to select "Date Setup."Full details are in the "Date/Time Menu" section beginning on page 25 of
the manual.
