20 Most Recent Panasonic TX-28DK2 TV Questions & Answers
Universeal remote control coad
GET ANOTHER AT WALMART THEY COME WITH PASS CODES YOU WILL BE HERE ALL DAY FOR SOME ONE TO TELL YOU PASS WORD THEY THINK IS TO YOUR TV.
2/15/2011 7:27:47 PM • Panasonic... • Answered on Feb 15, 2011
2answers
Tv is on stand by but won't 'fire up'
I don't know the age of your set but I've found some Panasonics with a loose connection on the heat sink (an aluminum plate standing vertically on the circuit board) of the regulator IC (chip). The IC gets its ground through the heatsink. If the ground is open the power supply puts out too much voltage and causes the set to go into shut down. I've found this problem several times. Stargazer
3/30/2010 12:26:22 PM • Panasonic... • Answered on Mar 30, 2010
Can we simply use this tv as a monitor? if yes
if it has a VGA port its possible for you tu use it as a monitor...
most of the flat tv nowadays are also good as monitor.
3/26/2010 4:11:48 AM • Panasonic... • Answered on Mar 26, 2010
2answers
Bbc1 bbc2 have been deleted after retune why
When TV channels are moved from one frequency to another frequency that was previously used by a different channel (sorry, but there's no simple way of saying that !) as has happened recently in th UK, some digital TVs and digiboxes struggle to sort the channel list out properly and channels can go missing as you describe.
If your equipment has the option to delete all currently stored channels (normally in the tuning menu options) then do so and then do a full re-tune.
Sometimes, this solves the problem as the equipment is no longer aware of any previous use of a frequency and just loads every channel it finds.
If this doesnt work, or your equipment doesnt have the option, then there is normally the option soemwhere in the menus to retore the item to "factory defaults/configuration". This will clear all previously stored channels and after a full re-tune your missing chanels should be there. However, any other configuration changes you previously made, e.g picture size, output type (RGB/NSCT/etc), etc will be lost and you'll need to set these again.
NB. some regions of the country have lost some channels temporarily now until after the switch over programme completes at the end of 2012. If you visit the Freeview website, this will tell you if your area is affected.
11/9/2009 11:42:06 AM • Panasonic... • Answered on Nov 09, 2009
BBC1 and BBC2 have simply disappeared from my TV.
I would let the TV do an autoscan/autoprogram and see if they return at that point.
11/6/2009 8:21:54 AM • Panasonic... • Answered on Nov 06, 2009
Freeeview update has not allowed BBC1, BBC2
Make sure all cables are securely connected to your Freeview Box or Freeview TV before you begin
Do a Factory Reset of your Freeview TV and then do a rescan of new channels. If successfull then all channels should be back and working.
10/14/2009 7:45:41 AM • Panasonic... • Answered on Oct 14, 2009
I want the sky remote to put the volume up and
Hello Colin
please follow the steps below:
TV
RED + SELECT (flashes twice)
TV
0051
try the volume if this works then press SELECT to save the code. If not then press TV again then the volume. repeat this step until the volume works then press the SELECT button to save the code.
cheers
Little Dish Fitter
9/17/2009 6:04:45 PM • Panasonic... • Answered on Sep 17, 2009
Sky remote to control Panosonic TV PV M20F8
Panasonic
0051
678,254,278,154,242,241,368,128,191,368,395,585
Try These might help
3/10/2009 11:39:11 PM • Panasonic... • Answered on Mar 10, 2009
Tv on mute
turn the tv off at the mains leave for 10 - 20 mins the turn back on, this should solve your problem.
3/10/2009 10:42:52 AM • Panasonic... • Answered on Mar 10, 2009
I`m trying to get my tv working with my sky remote
press tv, then select and red together until it blinks, then enter 0254. Worked for me.
1/25/2009 10:47:55 AM • Panasonic... • Answered on Jan 25, 2009
Repetitive dull thumping noise
You're in the UK, right? Try unplugging the set from the mains and let it sit for ten to fifteen minutes. Are your speakers built in or detached? How long has this been happening? Have there been any changes recently that coinside with the problem? Are there any other audio/video devices connected to the set? If you have other devices, does the problem exist when they're in use? The clicking noise sounds like a relay that's searching for another device or input. Check the audio settings on the menu to see if something has changed. Hope this helps.
12/23/2008 3:59:07 PM • Panasonic... • Answered on Dec 23, 2008
Panasonic hds700tds playing audio no videos
  1. Check the Input Source: Make sure you have selected the correct input source on your TV for the device you are using. Use the remote control to cycle through the input options until you find the one connected to your video source.
  2. Check Video Connections: Ensure that all video cables (such as HDMI, component, or composite cables) are securely connected between your TV and the device you are trying to watch content from. A loose or faulty cable connection could result in a loss of video signal.
  3. Restart the TV and Video Source: Try restarting both your TV and the device you are trying to watch content from. Power off both devices, wait a few moments, and then power them back on. This can sometimes resolve temporary glitches or issues with the video signal.
  4. Check for Software Updates: Make sure your TV's firmware is up-to-date. Sometimes software updates can resolve compatibility issues or bugs that may be affecting video playback. Check the settings menu on your TV for an option to update the firmware, or visit the manufacturer's website for instructions on how to do so.
  5. Reset Video Settings: If you've made any changes to your TV's video settings, such as resolution or picture mode, try resetting them to their default values. This can sometimes resolve issues with video playback.
  6. Try a Different Device: If possible, try connecting a different device (such as a DVD player or gaming console) to your TV to see if the issue persists. This can help determine whether the problem lies with the TV itself or with the original device you were using.
  7. Contact Panasonic Support: If none of the above steps resolve the issue, it's possible there may be a hardware problem with your TV. In this case, you may need to contact Panasonic customer support for further assistance or to schedule a repair.
  8. Hope this helps
4/9/2024 11:43:10 PM • Panasonic... • Answered on Apr 09, 2024
I have a Panasonic 50-in flat screen TV a storm came by and knocked out my TV and my Yukon no breaker was off so did it come through the antenna please help
  1. Check the Power Cord: Ensure that the power cord is securely plugged into both the TV and the power outlet. Make sure there are no visible signs of damage to the power cord or the plug.
  2. Inspect the Power Outlet: Try plugging another electronic device (such as a lamp or a phone charger) into the same outlet to verify if it is functioning properly. If other devices work fine, then the issue is likely not with the power outlet.
  3. Check for Tripped Circuit Breakers: Check your circuit breaker or fuse box to see if a circuit breaker has been tripped or a fuse blown. If so, reset the circuit breaker or replace the fuse and try plugging in your TV again.
  4. Test with Different Power Source: If possible, try plugging your TV into a different power source altogether, such as a different room or building. This will help determine if the issue is specific to the power source you were previously using.
  5. Contact Panasonic Support: If none of the above steps resolve the issue and your TV still does not power on, it's likely that there is a hardware problem with the TV itself. In this case, you may need to contact Panasonic customer support for further assistance or to arrange for repairs. Be sure to provide them with details of the troubleshooting steps you've already taken.
Hope this helps
4/9/2024 7:56:16 PM • Panasonic... • Answered on Apr 09, 2024
I'm about to lose my mind trying to find the + on a Panasonic remote! Can anyone tell me how to find it? The + is part of my router code to connect my tv to the internet.
Unfortunately there isn't one. The workaround is to change the Router Password or SSID to remove the plus + for something else.
need to input the plus sign for wifipassword XXXXX my ...
JustAnswer https://www.justanswer.com > Network Experts Apr 6, 2014 - How do i type the plus sign for my wifi password on my panasonic viera remote? I also need to input the "+" sign. - Answered by a verified 1 answer ยท Top answer: Okay, great. Go to Network settings on your tv menu> select Wireless ne https://www.google.com/search?q=Panasonic+remote+plus+symbol ..
3/8/2024 5:06:23 AM • Panasonic... • Answered on Mar 08, 2024
Tv diagram tc 2165ga
panasonic tc-2165ga
2/26/2024 11:40:35 AM • Panasonic... • Answered on Feb 26, 2024
How to reset lamp for Panasonic PT-vx400nt?
Turn off and unplug the projector. Locate the lamp cover on the projector. Remove the lamp cover. Take out the old lamp. Insert the new lamp. Replace the lamp cover. Reset the lamp hours: Press the Enter button to display the "Option" menu. Use the 5 or 6 button to select "Lamp Runtime". Press and hold the Enter button for approximately 3 seconds. The "Lamp Runtime" will change to "Time Reset [Power Off]". Turn off the power and disconnect the power cord. Finally, plug in and turn on the projector. Remember to consult your projector's operating instructions manual for specific details and safety precautions. How to change Panasonic vx 400 xga projector lamp change or replace (youtube.com)
2/17/2024 12:59:14 AM • Panasonic... • Answered on Feb 17, 2024
How do I get my Panasonic television out of self check mode if I don't have the remote?
Question edited for clarity, it is probably a Viera not a Viesta. You can try a power cycle reset. Remove the power plug overnight, press and hold the On button for 60 seconds. Plug back in. All televisions need a remote. https://www.fixya.com/support/r29872378-universal_remotes_no_facsimile_remote ..
1/31/2024 5:11:57 AM • Panasonic... • Answered on Jan 31, 2024
Panasonic TX-28DK2 TV Logo
Popular Tags
20 questions posted
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Panasonic Televison & Video
Most Popular Question
bbc1 bbc2 deleted after retune
  • Televison & Video
