20 Most Recent
Apple iPod touch 1st Generation (8 GB) MP3 Player Questions & Answers
Hi i have a 1st
Some devices such as yours have a 4 conductor jack, (used for earphones and microphone) and most earphones have a 3 conductor plug. They are not compatible. This would be my first guess. Second is earphones and earbuds get tossed around, put into pockets, etc. The cords can get damaged, and not be visible from the outside as the wires inside are very delicate. I would try a set that works in a different device.
My 1st generation 8gb ipod
It sounds like you have a headphone jack failure. Have you had any difficulty inserting the headset? Was there any event that happened when headphones were in and working.
Can't connect to the itunes store no matches
While setting up your device, you should create an Apple ID. That Id is used when you want to update, or buy something from the Apple store. Once setup, for everything you buy, one password will be enough. No checking of credit card numbers or other things.
Can't connect to the itunes store 'no matches'
Everyone can connect to the Apple Appstore, To buy games or content, you have to setup an account.
As soon as you want to buy something your account password will be asked. That is all.
Headphone is not working well
Try your Headphones on another Device, if they work there.If not, you probably should buy some new headphones, or try to get a replacement or new ones if you still have a warranty on them.If your headphones work fine on the other device you tested, you should send your iPod to repair or try to do it yourself, you can find guides for the repair aswell as the needed tools on
iFixit.
My ipod is locked on the main screen
Connect your iPod to your PC/Mac and Start iTunes.Click on iPodThen, Click on Recovery and let your PC/Mac go through the process.After the Recovery is done, you need to re-sync your iPod.
What happened ?
If it was bought new and the sound doesnt work, its most likely either a defect in firmware from the manufacturing, or the ipod internal audio jack or stereo was damaged while being shipped to the store. Its best to take it back to where you bought it to be replaced, before your return date ends. Or if you have a Apple warranty, you can contact them online or give them a call
