20 Most Recent ASUS K50IJ Notebook Questions & Answers
Asus k501
Go to a hardware store. Either that or order a new one online and hope that a guide will be shipped with it. Sorry for the slightly rude answer, but I cannot recommend trying to change your laptop keyboard unless it is either designed for it or having multiple support/technical experience.
2/21/2015 2:33:13 PM • ASUS K50IJ... • Answered on Feb 21, 2015
Asus delete passsword bios
Most bios passwords are 0000. It might work might not.
8/16/2014 5:00:17 AM • ASUS K50IJ... • Answered on Aug 16, 2014
Asus k50ij usb boot
Get you favorite bootable ISO image and using "ImageWriter.exe" application (under Windows 7/8) you could "transfer" the ISO to your USB device. In that way, your USB device becomes a bootable device. To boot from a USB device, your laptop should be "equiped" with a proper BIOS. Go to BIOS and change the boot order by having your USB stick already inserted in one of USB port (otherwise, you couldn't select to boot from USB!) Instead of "ImageWriter.exe" application, you could use also "Win32DiskImager". For any of them, google it!
7/21/2014 7:27:00 PM • ASUS K50IJ... • Answered on Jul 21, 2014
Reverse webcam
Check the settings in your webcam software for mirror/normal switch.
3/21/2014 5:20:26 AM • ASUS K50IJ... • Answered on Mar 21, 2014
Asus k50ij backlight not working
Can you see your screen when you hold a flashlight to it? If so then it may be an issue with the power inverter. I have the same issue on my laptop. Unfortunately It is hard to find the proper Inverter online. Hope this helps!
3/16/2014 2:17:57 PM • ASUS K50IJ... • Answered on Mar 16, 2014
Remove bios password
um try typing "DDA4A10D" that's the factory password. But just to cover my but here....if the laptop is stolen it doesn't matter if you remove the bios and reset it....as soon as you get online and it's lo-jacked...it will be found regardless....good-luck...and if its not stolen Yey for you.
8/29/2013 10:42:06 PM • ASUS K50IJ... • Answered on Aug 29, 2013
TOUCHPAD IS NOT ACTIVATED
3/22/2013 2:19:53 AM • ASUS K50IJ... • Answered on Mar 22, 2013
2answers
I have an asus k50ij and my webcam image is upsidedown, what should I do to fix it? i got windows 7 x64
WEBcam Image SettingsCheck the WEcam settings. Most WEBcam have a setting toinvert and mirror the image
1/3/2013 4:11:00 PM • ASUS K50IJ... • Answered on Jan 03, 2013
Can anyone sort me a video of how to replace the buttons under the the touch pad on ASUS notebook K50IJ series
This may get you started, the videos on the right may help as well: http://www.youtube.com/watch?v=vdPa3iuLwOc REMEMBER take pictures of your repair in stages, it will be a good reference when reassembling.
12/20/2012 11:51:56 PM • ASUS K50IJ... • Answered on Dec 20, 2012
The cursor jumps around on my ASUS K501J notebook.
Step 1
1. Open Mouse by clicking the Start button, clicking Control Panel, clicking Hardware, and then clicking Mouse. 2. Click the Pointer Options tab, and then do any of the following:
To change the speed at which the mouse pointer moves, move the Select a pointer speed slider towards Slow or Fast.• To make the pointer work more accurately when you're moving the mouse slowly, select the Enhance pointer precision check box.• To speed the process of selecting a choice when a dialog box appears, select the automatically move pointer to the default button in a dialog box check box.• To make the pointer easier to find when you move it, select the Display pointer trails check box, and then move the slider towards Short or Long to decrease or increase the length of the pointer trail.• To ensure that the pointer doesn't block your view of the text you're typing, select the Hide pointer while typing check box.• To find a misplaced pointer by pressing the CTRL key, select the Show location of pointer when I press the CTRL key check box.
Change mouse settingshttp://windows.microsoft.com/en-US/windows7/Change-mouse-settings
Step 2
If you are using touchpad, try reducing the Touchpad sensitivity and check
1. Click on the "Start" icon in the lower left corner of the screen. Select "Control Panel." Next select "Mouse" under "Hardware and Sound." You can also left-click the touchpad while the cursor is anywhere on the desktop. From that screen, choose "Mouse Pointers."2. Select the "Buttons" tab at the top of the dialog box that opens. This shows the type of touchpad device installed on your laptop.3. Set the touchpad for right or left-handed use from this dialog box. You can adjust the double click speed of your computer as well. When you finish making any changes, click "Apply."4. Pick the "Device Settings" tab from the dialog box now. You can see the touchpad for your Vista machine highlighted on this screen. Select "Settings."5. Read the information provided in the next dialog box. It gives you options for tapping your touchpad, using the buttons, scrolling, pointer motion and sensitivity.6. Make any changes you want from the various topics. When you make a change, click "Apply." Click "OK" when you finish making all your changes.7. Do some work on your computer for a while, If the touchpad is still too sensitive, return to the "Mouse" menu and continue to adjust the settings until you get them just the way you want them.
Step 3
If the issue persists try to perform a clean boot and check whether the issue is still persists.
Follow the steps mentioned in the article given below.
How to configure Windows Vista to start in a "clean boot":
http://support.microsoft.com/kb/929135
Note:Once the troubleshooting is over, reset the computer to start as usual.
Also I would suggest you to keep in touch with mouse manufacturer
10/9/2012 5:03:47 AM • ASUS K50IJ... • Answered on Oct 09, 2012
The laptop keeps buzzing and freezing at random times.
The problem may be with the hard drive, sub out the ram one at a time and test each time just to be sure it is not something simple, if there is no change! the hardware is suspect.
4/5/2012 10:19:25 PM • ASUS K50IJ... • Answered on Apr 05, 2012
0answers
Asus usb flash
Be the first to answer 2/24/2012 4:30:05 AM • ASUS K50IJ... • Posted on Feb 24, 2012Be the first to answer
Internal microphone not working (don't
Yes this notebook has an internal mic, maybe it's only muted in Windows mixer, please also check if it's not set to very low volume.
2/22/2011 8:55:10 PM • ASUS K50IJ... • Answered on Feb 22, 2011
ASUS K50IJ Notebook Logo
30 questions posted
Popular Products
Top ASUS Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
K ASUS
  • K ASUS
Most Popular Question
touchpad not activated
  • Computers & Internet
