20 Most Recent Panasonic PT-47WXC43 47" Rear Projection Television Questions & Answers
0answers
Projection bulbs
Be the first to answer 1/4/2014 10:26:08 PM • Panasonic... • Posted on Jan 04, 2014Be the first to answer
3d in red. double image in red
convergence IC issue
6/19/2012 5:49:13 PM • Panasonic... • Answered on Jun 19, 2012
My tv looks like its
You will need to replace both STK392-110 Convergence ICs and also check and possibly replace the low ohm resistors. You can get the PT53WX53 convergence repair kit which covers your model. The kit contains the ICs , resistors and the CD with repair instructions. The kits available from www.tvrepairworld.com
7/22/2011 7:58:36 PM • Panasonic... • Answered on Jul 22, 2011
SCREAN WHENT BLACK and power light is blinking
Your symptom sounds like a damaged convergence IC.
If this is the case the power LED should be blinking 3 times when trying to power the set up. You should be able to get a local service center to repair this at your house for between $350.00 - $450.00, If you want to repair this set yourself, I have some instructions below that will be a help to you. While it is not a very hard repair, this repair can be a bit tricky. If you have a 45W soldering iron, solder, solder wick, and heat sink compound you can repair it yourself.When you remove the old IC's, please be sure to remove all of the old heat sink compound, as it can act as an insulation for the new IC's and cause them to overheat. I usually clean the heat sinks with alcohol and a small rag.There are two and large IC's that control the convergence in a big screen set. Some of the newer sets only have one. If you only have one, it is right in the middle of the set on the center circuit board. They are secured to a very large aluminum heat sink. They will have a part number stamped on them that will start with an STKXXX-XXX, like STK392-110.Along with the convergence IC's there will also be some associated components that will need to be replaced as well. There are some resistors that are part of the convergence circuit that will be open and need to be replaced. Most likely these will appear charred in the center. If you have an Ohm Meter or a DVM, check all the resistors that are close to the IC's and you should be looking for either ones that have opened or have changed values.If one of the convergence IC's are found to be bad, I would replace them both, if one has gone bad the other may go soon. I usually order my parts from Andrews Electronics in California, they will have the OEM components that you will need.Their site is http://www.andrewselectronics.com/welcome.aspxAnd their phone number is a 24-Hour Order Desk: (800) 274-4666I recommend the phone order so you can talk to the person about the different types of IC's that are available.I would also advise that the convergence IC's be OEM or better, just because they are cheap does not mean that they are a good deal. I have seen the cheap IC's fail after a short time, even though they look exactly like the OEM IC's. I think that the bottom line is that you will get what you pay for when it comes to the parts.You can also try http://www.tvrepairkits.com/ , I have not tried them yet, but they do carry OEM or better parts.I hope this information allows you to resolve this issue.If you need further assistance please comment to this post and I will try to help you further. Thanks for using FixYaasnowman
1/29/2011 6:03:05 PM • Panasonic... • Answered on Jan 29, 2011
My blue adjustment is messing up, particularly on
CERTIFIED TV EXPERT HERE, follow this information I provided 3 long solutions to this issue/s
Solution 1
Before we start taking things apart, lets try your simple remove power plug routine and power system back up. Also, please try your unit on a few different channels to see if your problem continues on each channel. Your Main Board, Power Board, T-Control Board are suspected problems at this time. Press and hold the power button for about 15 seconds, the unit should power down by itself after you have powered it on. If it does not, then do not be concerned. Let me know if the problem continues. The first link below will bring you directly to the troubleshooting guide if you need to continue forward with the same error. Additional information http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums http://en.wikipedia.org/wiki/Capacitor_plague Parts: www.shopjimmy.com
Lets focus on the external portion of the TV set first (95 percent of all TV problems are related to things EXTERNAL To the tv itself) Check the physical CONNECTION of all cables by removing each wire bare or RCA and reinstalling it (Each power cable as well), once you have removed one cable, check it for fraying, and if it is already bare, splice a new fresh connection for it. 5. Check to make sure there are NO OTHER uneeded radios, system nearby. these systems, when powered on, will cause electromagnetic interference and prevent more than just severe tv interference SURGE PROTECTOR Surge protectors account for more than 75 percent of electric faults to stereo equipment. Lets start with your AC Wall outlet. It is standard in america that 220 Volts from out of these outlets. This implies that each device will be using 220 Volts (From within that grid zone). If anything including an alarm clock is plugged into any AC outlet socket in the vicinity of the stereo equipment/TV, it will cause electric outage, and prevent electronics from even turning on! Your TV needs dedicated electric power. If your TV is located in the living room then unplug everything else in the living room. Lets plug the TV set into a Dedicated socket. Check all light switches to ensure that power is on for that outlet. Check the TV cable for Fraying both on the ac wall end and where it plugs into the TV. Check all GFCI outlets to ensure that all red reset buttons are pushed in, check the circuit breakers for proper connection and they are turned on. Now, lets try the TV set without it connected to any cable services, vcr, dvd, stereo system, etc. Please respond if we have found a solution.
When troubleshooting these units, there are always several variables to consider. First check to see what last occurred with the unit such as did the children play video games, did the electricity go out due to bad weather. You may see that there are many possibilities but let's focus on what occurred last to the unit. Once we determine what happened last, we may isolate the actual cause of the problem. The actual cause may be associated with projection issues, older versions (Picture tube), interference from devices located nearby, and even a radio turned on and located really close to your unit. This is normally known as electromagnetic interference to electronics and is very common with the error you have provided today. Please continue to look for anything EXTERNAL to the unit before looking at the internal components. I have been working on these a long time so feel free to follow up with me.
Add a comment
1/24/2011 3:19:13 PM • Panasonic... • Answered on Jan 24, 2011
2answers
Television won't turn on and the power light
98% OF THE TIME 3 blinks (which is short protection) means one or both of the two STK-392-110 convergence IC's is shorted.
Both chips along with any of the dozen or so 2.2 ohm blue resistors around them that are bad need to be replaced and the set adjusted.
You can buy a pair of chips on Ebay for less than 13 dollars plus shipping.
I have start to finish, step by step instructions I can post here if you are able to do the repair yourself.
I have a set tomorrow very much like yours I am going to go repair--same problem. Most shops get 300 or more for this repair--It takes about one hour and should be able to be done right in your home.
If you get someone to do this repair---make sure BOTH chips get changed or you are going to have the same kind of problem in a few months.
If you want the instructions let me know and I will post them here for you.
If this information has helped you rate this solution and understand I do this here for free.
SD TECH
1/17/2011 8:02:42 PM • Panasonic... • Answered on Jan 17, 2011
When powering unit on it makes noise like it would
u have a open resistor on power suuply next to a relay value 1.5 ohms at 5 to 10 watts , it look like a big whit pieace u cant missit
12/21/2010 6:52:17 PM • Panasonic... • Answered on Dec 21, 2010
How do I turn the
http://service.us.panasonic.com/OPERMANPDF/PT56TW53G.PDF
Here is a link for the owners manual the answer along with a picture is on page 34
12/4/2010 7:23:12 PM • Panasonic... • Answered on Dec 04, 2010
My t.v. is very blurry
carensimson,
You have a problem called "blooming" which is caused by a defect in the regulation circuit of the high voltage section. If you are not a technician you probably cannot troubleshoot it succsssfully as this is a hard problem to solve. You probably can change out the entire high voltage board if you are good with tools and concientious. I looked on http://www.encompassparts.com and they list a service manual and quite a few parts, some are no longer available. If they have the board you should be able to change it with my tip at http://www.fixya.com/support/r4916851-diagnosing_repair_tv_high_voltage .
Thanks for using FixYa and for the great rating. Great ratings will help keep the experts here helping everyone.
hardrocko
11/10/2010 10:12:56 PM • Panasonic... • Answered on Nov 10, 2010
I have a panasonic PT-47WX34J television. I'm
You may not need to remove the red wires, normally there is enough slack to be able to turn the board over just enough to be able to remove the chips. See where the wires are running and losen any clips/ties holding them in place. If you still think you need to remove the red wires normally pushing down into the black thing and twisting 1/4 turn then pulling it out slowly will work on most of them.Some red wires have a metal clip on the end with tabs on them which requires twisting it to get the tabs lined up properly. others have no tabs at all and just require pulling out. I would error on the safe side and try the first method. good luck
8/28/2010 9:21:34 PM • Panasonic... • Answered on Aug 28, 2010
My tv won't come on and the power light is
There are two and large IC’s that control the convergence in a big screen set. Some of the newer sets only have one. If you only have one, it is right in the middle of the set on the center
Along with the convergence IC’s there will also be some associated components that will need to be replaced as well. There are some resistors that are part of the convergence circuit that will be open and need to be replaced. Most likely these will appear charred in the center. If you have an Ohm Meter or a DVM, check all the resistors that are close to the IC’s and you should be looking for either ones that have opened or have changed values.
If one of the convergence IC’s are found to be bad, I would replace them both, if one has gone bad the other may go soon. I usually order my parts from Andrews
Their site is
And their
I recommend the
phone order so you can talk to the person about the different types of IC’s that are available.
I would also advise that the convergence IC’s be OEM or better, just because they are cheap does not mean that they are a
good deal. I have seen the cheap IC’s fail after a short time, even though they look exactly like the OEM IC’s. I think that the bottom line is that you will get what you pay for when it comes to the parts.
You can also try
I hope this
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. (Two Thumbs Up)
Please Note: If you cannot rate this post with the highest rating, then please do not leave any rating. I am doing this for free and I do not think that any rating other that the best is needed.
asnowman
6/21/2010 5:29:30 PM • Panasonic... • Answered on Jun 21, 2010
I have a panasonic PT-47wxc43
This problem is due to convergence output ICs failure and both chips will be replaced to fix the issue.
There are two big black ICs installed with aluminum heat sink on deflection board, these are convergence output ICs and will be replaced to correct the problem, it is common problem of rear projection tv.
Below image of deflection shows ICs (marked in red) that are need to be replaced.
IC number is STK392-110 and available with Part Store for $32 each.
Click above link to see an image of IC.
If you are handy with electronics stuff repair and can replace parts in tv circuit board then can replace these parts yourself or ask local tech to help you.
Hope these info will help you.
Let me know if you have additional question.
Thanks.
5/26/2010 1:46:34 AM • Panasonic... • Answered on May 26, 2010
I have a Panasonic PT-47wxc43
Hi
Thanks for using FixYa. The issue is with the convergence ICs going bad and needs to be replaced. It’s not a difficult job if you want to do this yourself, you should require some basic knowledge about soldering-resoldering components. To start with you’ll have to open the back of the unit and then blow the dust off. After this is done check the ICs which are located behind the black heat sink and also check the resistors as if they are short the ICs might blow again after sometime.
As you asked, the typical cost to get this fixed by a pro is around $300-$350. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
5/26/2010 12:09:44 AM • Panasonic... • Answered on May 26, 2010
Panasonic pt-53wv53g power light flashes 3 times
If you are getting the three red LED lights flashing then your symptom sounds like a damaged convergence IC.
While it is not a very hard repair, this repair can be a bit tricky. If you have a 45W soldering iron, solder, solder wick, heat sink compound, and some basic soldering skills, you can repair the television yourself.
I have repaired hundreds of these sets, so if you have any questions after reading the following, please reply to this post and I will help you in any way that I can.
With that aside I have some support suggestions that I have put together that may help you make an informed decision.
How do I tell if the IC’s are damaged?
Since you cannot look inside of an IC, you will have to locate some of the components in the area around the convergence IC’s. You may be able to see some resistors that have changed colors or you test a resistor and it no longer reads the value marked by the color bands or the printed value. You will have to replace the IC’s and the supporting components.
When you remove the old IC's, please be sure to remove all of the old heat sink compound, as it can act as an insulator for the new IC's and cause them to overheat. I usually clean the heat sinks with alcohol and a small rag.
Where are the IC’s located and how do I find them?
There are two and large IC’s that control the convergence in a big screen set. Some of the newer sets only have one. If you only have one, it is right in the middle of the set on the center circuit board. They are secured to a very large aluminum heat sink. They will have a part number stamped on them that will start with an STKXXX-XXX, like STK392-110.
If one of the convergence IC’s are found to be bad, I would replace them both, if one has gone bad the other may go soon. I usually order my parts from Andrews Electronics in California, they will have the OEM components that you will need.
Their site is
I recommend the phone order so you can talk to the person about the different types of IC’s that are available.
I would also advise that the convergence IC’s be OEM or better, just because they are cheap does not mean that they are a good deal. I have seen the cheap IC’s fail after a short time, even though they look exactly like the OEM IC’s. I think that the bottom line is that you will get what you pay for when it comes to the parts.
You can also try
http://www.tvrepairkits.com/ , they do carry OEM or better parts. When you order from them you will get a kit with instructions on how to do the repair, step-by-step.
With the low price of LED and Plasma TV's it is hard to repair sets today.
asnowman
5/13/2010 5:35:28 AM • Panasonic... • Answered on May 13, 2010
convergence ic short 350 to repair
5/6/2010 4:09:41 PM • Panasonic... • Answered on May 06, 2010
Panasonic PT-47WXC43G green ONLY is bowed on bottom and top
It still convergence chip problem, check big resistors nearby these chips that would be open or devalued and causing problem, specially in green convergence area, your green tube/ gun is just fine and just not getting convergence output signal to show correct image.
I would suggest to download service manual copy of this tv for small fee from any website and fix the issue with schematics help.
Thanks.
5/2/2010 7:33:17 PM • Panasonic... • Answered on May 02, 2010
Tengo un control y necesito los codigos para un
puedes checar en la web en Discount-merchant.com ellos tienen casi cualquier control que busques.
4/14/2010 2:46:00 PM • Panasonic... • Answered on Apr 14, 2010
The screen on my panasonic is warped towards the
You probably want to replace both IC's and possibly a few low value resistors gouped close to each IC on the aluminum heat sinks. The IC's wil have STK392-1xx written on them. Replace with either stk392-150 or 180's.
2/24/2010 8:50:08 PM • Panasonic... • Answered on Feb 24, 2010
Panasonic CT-36HX42F will not power on
If you remove just the lower half of the back cover (NOT THE UPPER PLASTIC COVER) you will see the power cord which is attached to the circuit board. Next to the power cord is the fuse, but be careful, this is not just a glass fuse you can buy anywhere. To make sure you order the right part go to www.mcmelectronics.com and go to OEM part finder. typed in your model number exactly how it is on the back and do your search. You will then see every part that is available through them that you can order. If you also notice you will see just above all those parts that they have a board location search. Look at the fuse in question and get the location number from the circuit board and type it into that search and you will have the correct part number shown to you, but if you look there is not a price listed. Copy the part number down and again go to www.mcmelectronics.com and on the top of the home part you will see a nice search bar where it will say enter part number or keyword here. Type or paste that part number into that and search. You will then be able to see how much the part is and if it is available. I do not work for MCM, but they are a great source in finding exactly what the part number is if your doing it by board location.
2/20/2010 2:17:35 AM • Panasonic... • Answered on Feb 20, 2010
Panasonic PT-47WXC43 47" Rear Projection Television Logo
51 questions posted
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Panasonic Televison & Video
Most Popular Question
panasonic pt 53wv53g power light flashes
  • Televison & Video
