20 Most Recent
Panasonic PT-45LC12 45" Rear Projection HDTV-Ready Television Questions & Answers
PT-45LC12 Problem after startup
When the lamp flashes 4 times this is what the error code means IC 2301 pin 11 has detected an LCD error which is caused by an error in the LCD power CBA. which means the lamp voltage has become more than 130 volts or less than 30 volts. Or the lamp current is more than 5 amps, or the lamp is cracked. Its one of thos 3 reasons that will make the lamp indicator blink 4 times. Hope this helps. If you need the service manual for this model you can get one emailed to you from the following link.
http://servicemanuals.vstore.ca/
11/18/2013 12:30:00 AM •
Panasonic...
Answered
on Nov 18, 2013
Red spot Panasonic pt44LCX65
Thanks to this website, I got our TV fixed. YEAH!!!!!!!
Before I found this website, I called Panasonic and they told me they couldn't help me and to call my local service tech. So I did and they were going to charge me $250.00 to fix it and I had to take my TV to them. Well months went by because I just couln't afford it. Two more spots appeared and I needed this problem fixed. I turned to the internet for help and found this WONDERFUL site.
I then took all the information and called Panansonic again. This time I was on the phone well over an hour. I was very persistant and had all the facts about this being a manufacturer defect and that they were well aware of the problem and they had fixed others for free. I expected the same same service and wanted it fixed.
They switched me from department to department and finally with my persistant, I got them to agree to come out in fix it for free. They came out this with 3 days and my TV is fixed.
By the way my TV was out of warranty. I bought in 2005.
THANK YOU THANK YOU THANK YOU FOR THE PEOPLE OUT THERE WHO HAVE EXPERIENCED PROBLEMS AND ARE WILLING TO HELP OTHERS!
3/20/2013 12:43:55 AM •
Panasonic...
Answered
on Mar 20, 2013
I turn on the power
szorehkeyhom,
If your unit is more than three years old you probably need a new bulb. Looking at it or even trying to test it with a DVM will not reveal if it is ok or not. It would be better to just replace it if it is more than 3 years old. I have a tip at
http://www.fixya.com/support/r4168009-change_lamp_in_dlp_projection_tv which explains where to get a quality lamp at a good price and how to do the repair.
Thanks for using FixYa and for the great rating.
hardrocko
12/9/2010 12:33:01 AM •
Panasonic...
Answered
on Dec 09, 2010
Not detectec new lamp. power
traviesin022,
You did not mention whether your unit is displaying a picture but from what you said I am guessing that it is displaying video. If that is the case you need to reset the lamp counter to get the light to go out. The reason for the counter is to indicate when you need to replace the lamp (before it blows out) and possibly causes damage to the projector. Therefore after replacing the lamp the counter needs reset. The procedure is straight forward and I have a tip which helps walk you through it at
http://www.fixya.com/support/r6593210-procedure_reset_panasonic_tvs .
hardrocko
11/30/2010 9:21:34 PM •
Panasonic...
Answered
on Nov 30, 2010
No picture, power light flashes green.
If you take the back cover off (and part of the front) you should be able to the cage that holds the lamp. Above that there is a small thermal fuse that occasionally goes out and causes this problem. Quick solution is to repalce with a normal 5amp fuse. Just clip it out and solder the new one in. I would use a pico fuse. Or invest in a replacement thermal fuse from a part store. Part number K5C117BC0003. Goodluck.
7/5/2010 11:46:53 PM •
Panasonic...
Answered
on Jul 05, 2010
Lamp doesnt look blown but lamp light flashing n tv wont turn on
Check the Lamp Fan if it is defective Lamp will try to light but will shut off, And the Ballast board is what turns Lamp on, For Part number o to Encompass parts distrubtion and type in your model they should list the ballast board and PN Then go to Ebay Look under Electronics type in PN, I got mine for $65.00
Lamp for $85.00
6/27/2010 5:46:38 AM •
Panasonic...
Answered
on Jun 27, 2010
New Bulb... No Screen...
Ballast Board ,it is what turns Lamp on! Call Encompass Parts for Part or look them up online they have website. Call 1-800-638-3328 Ok I looked it up Part# is LSEB3062A1 which showed No Longer avaliable,So try UED 1-800-648-6657 and Look on E-Bay under Electronics For Ballast Board.
4/1/2010 9:54:18 PM •
Panasonic...
Answered
on Apr 01, 2010
Panasonic tv model pt-44lcx65
Howdy,
The problem is with the EEPROM in the TV that needs to be reprogrammed. But you need to have the proper Correction Tool (LSUQ0100).
I don't think it's available to the public. Call a Service Company, but make sure they have the “Correction Tool”.
Thanks for using FIXYA, big IRISH.
1/2/2010 7:43:50 AM •
Panasonic...
Answered
on Jan 02, 2010
Lamp light out ?
Ck Fan behind Lamp first if it is OK then replace Lamp Look on E-Bay you can find lamps for as little as 82.00
8/6/2009 11:45:29 AM •
Panasonic...
Answered
on Aug 06, 2009
Panasonic PT-45lc problem
I took the rear bottom off of the set,lots of screws to take off.
On top of the bulb housing is a small yellowish thermal fuse.
I took mine completey out,jumped the black wire together,and bingo.set works perfectly.
6/22/2009 9:37:55 AM •
Panasonic...
Answered
on Jun 22, 2009
PT 44 LCX 65 Panasonic Red spot upper rt quadrant of screen
This is a FIRMWARE problem. do not let someone replace any parts in your TV.
I had a repair guy come out with a small computer and he took the back off of my tv, plugged in the computer and the red dot slowly began to disappear.
this was in March 08, no problems since
5/6/2009 1:00:33 PM •
Panasonic...
Answered
on May 06, 2009
Pt456c12 wont come on blinks green at the on off light
Good Day, teagues;
It sounds like a bad lamp. Lamps normally have a 5,000-hour life. Looking at the lamp can tell you if it’s bad if it looks burnt, but not always. Your Panasonic TV is also known for having failure of the ballast, which turns the lamp on. 95% of the time it’s the lamp, trouble shooting the ballast is a little more challenging.
The lamp replacement is a very simple process; instructions are in the TV’s owner’s manual. Call the factory, they will send you the lamp to your home with complete detailed instructions.
Good Luck, Big Irish.
3/6/2009 11:13:28 PM •
Panasonic...
Answered
on Mar 06, 2009
