20 Most Recent Hitachi Ultrastar A7K1000 HUA721010KLA330 - 0A35772-20PK 1 TB SATA II Hard Drive Questions & Answers
SATA HARD DRIVE - XP INSTALLATION
The problem is that XP installation CD does not have a SATA driver, unless you have a SATA drive on a disk etc. and can install the driver when XP asks for a hard drive driver then, XP cannot detect the hard disk and therefore won't install XP. The FIX. Go into the BIOS and disable the SATA drive (enable IDE emulation), this will make XP think it is a IDE/PATA hard disk. Then you can install XP normally. When Windows has been installed then install all the device drivers (including the SATA driver), then shut down and boot up and got into the BIOS and enable the SATA drive.
Hitachi... | Answered on Aug 25, 2012
You should be able to buy an external USB drive (or thumb drive) at any electronics store.
You can connect a USB hard disk drive or USB
memory stick to your TV by using the USB inputs of
the TV. This feature allows you to play files stored in
a USB drive. 2.5" and 3.5" inch (hdd with external
power supply) external hard disk drives are supported.
IMPORTANT! You should back up your files before
making any connections to the TV set in order to
avoid any possible data loss. Manufacturer will not
be responsible for any file damage or data loss. It is
possible that certain types of USB devices (e.g. MP3
Players) or USB hard disk drives/memory sticks may
not be compatible with this TV.
Quickly plugging and unplugging USB devices, is a
very hazardous operation. Do not repeatedly quickly
plug and unplug the drive. This may cause physical
damage to the USB player and USB device itself. Do
not pull out USB module while playing a file.
Media Browser Menu
You can play photo, music, and movie files stored
on a USB disk by connecting it to your TV and using
the Media Browser screen. To do this, perform the
following: Connect a USB disk to one of the USB
inputs located on the side of the TV.
You can connect two USB devices to your TV. If both
USB devices include music, picture or video files, USB
selection OSD will be displayed on the screen. The
first USB device connected to the TV will be named
as USB Drive1. Select a device by using up or down arrows
and press OK
Hitachi... | Answered on Nov 30, 2019
You will have to use the HDMI port on the mac. provided you have a HDMI input in the projector
Hitachi... | Answered on Nov 26, 2019
BENJAMIN, Your message does not qualify as a question or query for a problem, try somewhere else
DO NOT MAKE THIS SITE WITH YOUR GARBAGE
Take your GARBAGE to another Side
Your message qualifies as SPAM
Hitachi... | Answered on Nov 07, 2019
buried in endless spam are you.
does it fail on 2nd PC????????????????????????????
but yes, I am the MVP of external HDD< I build my own.
Have over 5 here for Backups .
lots of causes, for sure bad drive, or missing drivers..
bad HW hardware or BAD software SW.
Missing 12vdc 2amp power pack>, lost or using wrong one.
when pack above does the HDD spin? usb connected to PC.
NO PC stated, NO OS stated, windows/chrome/Linux/android?
its at lease 10 years old , see posts back that far.
not good old HDD,this old.
sold during W7 era. 2009.
The drive has 3.5" HDD that needs lots of power (Amps)
to start up that big motor inside, and is first thing to learn .
2amps it needs, ok? so if pack is missing it will never startup
on any USB port, not rated for 20x standard USB load factors.
some laptops only do 0.1amps (100mA) and are useless to startup any hdd motor of any kind.
see why here.
and see a better extremal solution cheap.! $10
http://www.pcdied.com/external-hdd.html
Hitachi... | Answered on Jul 03, 2019
Try holding the pen at a different angle so that your hand is not blocking the signal. Make sure the pen batteries have enough power. If the light on the pen doesn't turn green when you press the button, you need to replace the batteries. Make sure EasyInteractive Driver is installed and running on your computer.
Solutions When the Interactive Pens Do Not Work - Epson
https://files.support.epson.com/.../troubleshooting/.../problem_interactive_pen_separate_...
Hitachi... | Answered on Jun 19, 2019
Tried googling for the answer but couldn't find it. Try calling an it support company, I'm sure they'll help you out for free. Perhaps you can try https://www.computersinthecity.co.uk/, they have been helpful to me in the past.
Hitachi... | Answered on Dec 07, 2018
What is the router/modem model number?
Have you tried a different cable?
Have you gone into the menu, networking and setup ?
Hitachi... | Answered on Jul 23, 2018
Hitachi Ultrastar A7K1000 HUA721010KLA330 - 0A35772-20PK 1 TB SATA II Hard Drive Logo
5 questions posted
Top Hitachi Computers & Internet Experts
Ekse
Marvin
Marvin
Thomas F. Schneider
Are you a Hitachi Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Hitachi Computers & Internet
Most Popular Question
bios reconizes new hd drive but xp pro
  • Computers & Internet
