20 Most Recent
Panasonic AG-DV2000 Mini DV VCR Questions & Answers
Transfer to DVD?
If the mini has two scart sockets you can connect a scart lead from scart 2 or av2 into av1 on a dvd recorder then select av1 as the record channel on the dvd and the press play on the mini and record on the dvd.
4/20/2014 9:03:29 AM •
Panasonic...
Answered
on Apr 20, 2014
When attempting to load a
i had the same issue with my ag-dv2000, a fun problem to solve without a service manual. first verify we are dealing with the same issue.first open hopper fully and apply power. you should get an f06 error(failure to close in required time), now close hopper and apply power, you should get a f07 error (failure to open in required time). if this is the case the bad part is the motor drive ic. ic 1 on the motor drive board mounted to bottom of dv mech. it is a 10 pin ic labeled xra6887. i have not located a source yet but you can confirm the chip is bad by replacing it with ic6502 on the same board. if you put the bad chip in place of ic 6502 you will ground power supply and will not have power, leave it out. it controls threading motor, not needed to verify problem. the door should work now. dont put in a tape untill you replace bad chip. if you find the panasonic part number for this part please post it. happy desoldering!
9/23/2011 8:31:21 PM •
Panasonic...
Answered
on Sep 23, 2011
I need to convert some
You'll need a computer with Firewire, aka IEEE1394. These cables don't have an end that is specifically computer or VCR ends, but they have an A for Alpha and a B size. A style connectors are the larger ones shown in the picture below.
After the cable is connected you'll need an editing program on the computer. Windows computers can use Windows Movie Maker, Mac Can use iMovie. Once connected you'll use the capture feature to get the video onto the computer.
5/17/2011 4:03:32 AM •
Panasonic...
Answered
on May 17, 2011
DV tapes will not load
the "dv sensor"is actually a mechanical lever built into the cassette
housing that moves the reel tables to match the reel spacing on mini or
full-size DV tapes. check to see if this assembly is free to move. if
it binds up, the reel tables may not move as far as they need to, and
can cause problems similar to the one you're seeing. to inspect the
mechanism, you need to remove the cassette housing. if you don't have a
service manual, get a tech to help -- it's a delicate procedure.
9/9/2010 7:08:15 PM •
Panasonic...
Answered
on Sep 09, 2010
Price
PANASONIC AG-DV2000 MINI DV DVCAM VCR NICE WARRANTY
Price:
US $699.99
8/19/2010 3:27:52 AM •
Panasonic...
Answered
on Aug 19, 2010
Recording instructions
well if the vcr is hooked up and you can watch a show on it put in a tape that has a movie on it then press play if you can see the show take out that tape put in your blank tape find the show on your tv u wish to record press record try this before the show comes on record a little bit of a show like 30 sec or so then rewind and play back to see if it did record if it did just repete this when the show that you want to record comes on hope this is helpfull....
5/31/2010 12:47:46 AM •
Panasonic...
Answered
on May 31, 2010
I need help using a Panasonic AG-DV2000 as an
USING A RCA PLUG AND SMALL HEADPHONE SOCKET TO LINE IN ON YOUR COMPUTER{IF IT HAS ONE}AND DEPENDING ON YOU SOUND AND VIDEO CARD ON YOUR COMPUTER YES IT DOES WORK.IF YOU CAN DO THIS,THER IS A PROGRAM YOU CAN BUY ON THE INTERNET CALLED AVS VIDEO CONVERTER WHICH HAS ALL DIFFERENT TYPES OF PROGRAMS IT WILL LET YOU COPY FROM YOUR VCR.
4/23/2010 1:14:00 PM •
Panasonic...
Answered
on Apr 23, 2010
Panasonic deck ag dv2000 gives error code f09
Your vcr seems to use the K Mech. F04 Means that the mechanism locks unloading.
The cause of which might be the loading motor timing.
F09 means No serial clock linking IC2004, IC7005 and IC7701.
6/16/2009 4:15:48 PM •
Panasonic...
Answered
on Jun 16, 2009
