20 Most Recent
Panasonic SC-DK10 System Questions & Answers
F61
F61 tells you its a power source problem
6/17/2011 9:00:34 AM •
Panasonic...
Answered
on Jun 17, 2011
Panasonic SA DK10 starts reading discs, gets to 00 and then stops
If this problem occurs only at this cd/dvd it's a disk problem. If it occurs on various disks try using a cd/dvd cleaner set, a wet one is better. Follow the instructions on the set. The main idea is to put one drip of the included liquid at the set (usually isopropyl alchohol) at a specific place (like small brush) on the disk surface and play this disk. This way the "brush" will clean up the laser lens and after that the cd/dvd player will be able to read the disks. BE CAREFULL not to put too much liquid on the "brush". In case this don't solve your problem, the cd player needs laser lens replacement by a technician.
In case of a problem or clarification, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
5/12/2010 11:45:22 AM •
Panasonic...
Answered
on May 12, 2010
F61
deffective power supply section or audio amplifier IC
(RSN311)
4/22/2010 7:00:08 AM •
Panasonic...
Answered
on Apr 22, 2010
Dvd stereo system SA-DK10 does not read cd's and dvd's
I took mine to Radio Shake and they replaced the mechanism for the reader. It was a total of 150.00 but it was worth it. I have to give it to them and they had to send it out to see what was wrong with it. I have used it two years later and it still works good. On occasion when I play about three to five dvds it will stop. After I let it cool down it starts working again. I am selling mine after 8 years of having it because my girl friend bought me a blue-ray theater system for christmas. Other then that it is a great product. if you need anything else let me know.
[email protected]
12/29/2009 12:07:22 AM •
Panasonic...
Answered
on Dec 29, 2009
How can I burn mp3 CD-R ?
MP3 pro?! Have you tried using a 3rd party writer like roxio and just chose data disc option, or import them into a conversion software even import into itunes (insuring mp3 is your selected format) and write the mp3 files created.
6/26/2009 3:50:38 PM •
Panasonic...
Answered
on Jun 26, 2009
NO disc
The same happened to me recently, you need to go to your electronic store and purchase a CD/DVD laser lens cleaner, put it in run it problem solved
6/21/2009 12:08:32 PM •
Panasonic...
Answered
on Jun 21, 2009
Surround Sound
You can run your sound from the TV or cable box (if those devices have that capability), but NO you can't run video into the SA-dk10. DVD is the only video output.
1/25/2009 7:08:36 PM •
Panasonic...
Answered
on Jan 25, 2009
DVD trays out - Panasonic SA-PM39D
there are very tricky mechanical devices that detect when the trays are closed and in what position they are in
A gear or mechanical piece is not in correct order or not functioning properly and will need intense studying to determine which position they all should be in at door closed , laser mech. position , standby position
can you upload a photo of the inside of the cd mechanism?
10/28/2008 3:13:41 PM •
Panasonic...
Answered
on Oct 28, 2008
