20 Most Recent
Campbell Hausfeld Husky Gravity Feed HVLP Spray Gun, HDS79000AV Questions & Answers
Air bubbling up in cup
it means the air holes in the nozzle are blocked the air couldn't get out in the front so instead it went back to the cup makes it bubble
9/17/2011 8:59:58 AM •
Campbell...
Answered
on Sep 17, 2011
We are having trouble getting
when you pull the trigger can u see the needle moving backward? if so, then it's either the paint is too thick compare to the nozzle size or the passage for paint is blocked. try to take the nozzle, needle and the cup off and give it a good clean!
9/8/2011 10:21:24 AM •
Campbell...
Answered
on Sep 08, 2011
Campbell Hausfeld air gun has air coming from the nose tip and no nails
If air is coming out from the nose tip but the nailer is not firing any nails, it could indicate a problem with the driver blade or piston assembly. Check if the driver blade moves freely and is not damaged. Make sure the piston assembly is properly aligned and lubricated. Also, check the nail magazine to ensure that it is properly loaded and the nails are the correct size for the nailer. If the problem persists, it may be necessary to take the nailer to a professional for repair.
2/14/2023 2:59:32 AM •
Campbell...
Answered
on Feb 14, 2023
Need to know start cap specs for c1071080vmsa campbell air compressor
Kranson 3 Nov 03, 2022
I'm late to the party, BUT...
There's 2 ea of both start and run capacitors in this compressor...
Start: PN- 351052-53, 815-970 MFD, 165VAC
Run: PN- 175863-30, 30MFD, 370VAC
The section ^^ UP THERE ^^ is for asking the OP further information before committing to an answer down here. The question is now marked SOLVED and will show in Search. Thanks
11/3/2022 5:10:21 PM •
Campbell...
Answered
on Nov 03, 2022
Campbell hausfeld wont build pressure
The most probable are
Leak in air lines, bad valves, bad piston rings or o rings., bad check valve on tank, leaking unloader valve. Tou can google your model number and there will be more info.
10/30/2021 3:21:28 PM •
Campbell...
Answered
on Oct 30, 2021
Why does my campbell hausfeld 80 gallon 2 phase air compressor start to bog down at 90 psi
There is many reason for this simptome ,
could be running capacitor ,, Pressure switch dirty or it going bad,, Or ,If you meen lick choking and conteniu going could be also your check valve ,,,
If you can post a video I will help you better ,
I need to hear what it doing ,
9/8/2019 9:33:07 AM •
Campbell...
Answered
on Sep 08, 2019
