20 Most Recent Sony Walkman WM-FX290 Personal Cassette Player Questions & Answers
You may download the manual from here.
Sony Walkman... | Answered on Sep 21, 2012
Does it have buttons 1-6 on it????? If it does try going to station and try pushing and holding button one.....until it stops blinking.....
Sony Walkman... | Answered on Mar 24, 2012
If its Sony WM-FX290 then check Hold slide switch, it is located next to Headphone jack, turn it Off to playback tape or listen radio sound.
Let me know if unit model is other than WM-FX290 to provide you helpful info.
Click Sony Support link to download WM-FX290 user manual free copy, if required.
Thanks.
Sony Walkman... | Answered on Oct 04, 2010
motor belts are cheap. try replacing the belt that drives the wheel. this become distorted specially when the unit has not been use for quit long time. if you think its not about belt, clean up the rubber that touches the tape when played, also the tape head with 70% alcohol. hope this help.
Sony Walkman... | Answered on Apr 05, 2009
I have this walkman too and also need the instructions. I found them at this website:
http://www.docs.sony.com/release/WMFX290.pdf
I hope that helps you out!
Sony Walkman... | Answered on Dec 19, 2008
Of course, I have to start with the obvious. Try changing batteries and headset and see how that helps.
I would get some cleaning solution called deoxit, and clean the battery leads. Also coat the headphone jack with it and put the jack into the player. Recoat and try again. Twist the jack around, it should help distribute the solution.
If the static is caused by a poor connection, that should clear it up.
Sony Walkman... | Answered on Dec 04, 2008
Sony Walkman WM-FX290 Personal Cassette Player Logo
20 questions posted
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Ekse
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Audio Players & Recorders
Most Popular Question
need radio instrucions
  • Audio Players & Recorders
