20 Most Recent
Sony ICF-SW77 AM/FM/SW Radio Questions & Answers
Nothing but static on all bands
There may be interferences from electrical appliances fridges, TV. Move the radio to some other place. For AM rotate the radio to get the best signal. For FM and SW deploy the telescopic antenna. For SW you may use an external antenna. For SW, to tune in on a station you need to know the broadcast time and the frequency.
From time-to-time no reception, just
These receivers have known problems with capacitors, solution is to replace all and clean up board. Contact me for service.... poikaa(at)yahoo(dot)com
No Battery Power
Late with this answer.... Battery tabs sometimes loose contact with signal board near volume slide, possible solution is to reapply solder and bend contacts slightly.
Have a sony world band
Bon Jour! Maybe a problem with antenna jack or possible capacitor problem. Contact me here .... poikaa(at)yahoo(dot)com
Time
Indicated the memory is lost, usually this points to back up battery that needs replacing. I do this service.... contact me here .... poikaa(at)yahoo(dot)com
