20 Most Recent
Trek Navigator 100 Questions & Answers
What parts and tools do I need to replace the free hub and bearings?
First, to answer your question you will need a new free hub (obviously) a chain whip, a lockring tool, cone wrenches, and a free hub remover tool, which is often a large hex wrench. If you've never done this and you aren't particularly mechanically inclined I'd recommend bringing the bike to a shop.
"Free hub" is a Shimano trademark. Given your description you may have a freewheel, which is removed in a slightly different way and with a different tool. In either case you may be able to fix your problem with nothing more than a can of lube and a hammer. Attach the red plastic hose to your lube and squirt it into the front and rear gap of the freehub (or freewheel) body, into the place where the ball bearings and springs and pawls are. Shoot it with lube and tap it with a hammer or wrench to set up some vibration. Spin the body backward. This will usually loosen up the body enough to allow you to coast without issues.
Pedal assembly for a trek navigator 100
This bike had a square-taper bottom bracket. What happens with this type is that the bolts holding them on become slightly loose over time. The crank arm begins to wobble and the "wollows" out the inner hole on the crank arm such that a new one will have to be purchased. They are about $15.
The only parts envolved are the cranl arm and the both that holds it in place.
I to replace the seat
Oh, any bike shop, online searches (Performance Catalog, for example). You need to know the exact diameter (embossed into the post) and length. Example 27.2 x 300mm
Ineed to know how to mount the computer on the frame of my Trek 3.1 road bike.
You have several options:
1. Follow the instructions for the computer that came with it or that can be found on the manufacturer website.
2. Go to a bike co-op for help
3. Have a bike shop install it.
4. Provide some useful info here such as the make and model of the bike computer. Without that nobody can help you.
11/6/2019 1:14:24 AM •
Trek Cycling
Answered
on Nov 06, 2019
How do I remove the front tire of my Trek Fuel Ex 7 29?
Check youtube my friend, there are great instructional videos there.Remove wheel from front forks, release any air from tyre, using 2 plastic tyre removal tools to remove tyre. Further instructions will be found on youtube.
10/2/2017 8:10:21 PM •
Trek Cycling
Answered
on Oct 02, 2017
Price of mens bicycle trek 7.1 15"?
The price is between $1,760 and $1,800.for more details check www.trekbycirclesuperstore.com the go to search on the page to get the price for your choice bike.
1/12/2017 12:03:53 PM •
Trek Cycling
Answered
on Jan 12, 2017
