20 Most Recent Sony CDX-S2200 CD Player Questions & Answers
0answers
If you havw geen listening to the radio and switch
check to besure your power supply fuse is not blown, other wise sounds like you have it connected to wrong 12 volt source, I think there sould be 2 12v connections to the radio one when the car is powered the other constant power.
6/18/2011 3:33:58 PM • Sony CDX-S2200... • Answered on Jun 18, 2011
Need a pic of wiring up to my van as some idio cut
The best advise I can give is to use the connection that you baught and cut of the end that connects to your VAN then you need to isolate the correct leads from your car. The chances are that they wont be the same colour so if you can get your hands on a voltmeter you should be able to find the correct leads. The manual for the stereo should tell you the correct colour wires for the head unit red=live black=neg.
Additionally, send us details about brand, year and model of your VAN, could be there some wiring diagram.
Keep in touch.
4/6/2011 4:38:14 PM • Sony CDX-S2200... • Answered on Apr 06, 2011
CDX-S2200 fitting to old golf
haha, yea sorry about that must have clicked the wrong button... if they spliced that old sony harness to the factory harness and did not cut the factory plug off then you can go to you local bestbuy or car audio store and get an adapter for your factory harness... but, if you have the tools and the time, its faster and cheaper just to hardwire on the new one... as for an adapter to convert the old sony to the new sony plug... ive never seen an adapter for that...
5/2/2010 7:08:12 PM • Sony CDX-S2200... • Answered on May 02, 2010
I have connected my MP3 player to laptop and now I
just restart your computer and you will be fine if you cant get to restart just press Ctrl +Alt + Delete Twist and it will restart that should be will you wont loost none of your music are Video
4/25/2010 5:17:27 PM • Sony CDX-S2200... • Answered on Apr 25, 2010
2answers
Need code for nissan micra blaupunkt radio
6541
4/9/2010 7:30:09 AM • Sony CDX-S2200... • Answered on Apr 09, 2010
Have just got sony CDX-S2200 can I connect my mp3
I dont think you can plug in mp3 but here is the manual download http://www.sony.co.uk/product/ica-cd-tuners/cdx-s2200#pageType=manual
3/24/2010 8:36:59 PM • Sony CDX-S2200... • Answered on Mar 24, 2010
All buttons have frozen except off and eject
try running the laser lens cleaner through it. and take a look at your wiring to make sure none of them are shorting on eachother. anything else probably means replacement
3/12/2010 5:34:46 PM • Sony CDX-S2200... • Answered on Mar 12, 2010
2answers
Radio and clock memory goes when engine is switched off
The radio was installed incorrectly or the memory wire has somehow been disconnected. The memory wire is the one which is connected to a permanent 12v feed even when the ignition is turned off.
The permanent feed is usually red, the memory feed is usually yellow (and a poor/lazy fitter may have piggy-backed it onto the red wire). Just connect the yellow to a fused permanent 12v source:either direct to the battery/starter motor terminal, or you can find others attached to the hazard flashers and often to the brake light switch on the pedal assembly.
Do yourself a big favour when doing the job and avoid clip on Scotchlok wiring connectors: they're a constant source of faults and no substitute for proper crimp-on bullet/spade connectors.
2/15/2010 10:20:40 AM • Sony CDX-S2200... • Answered on Feb 15, 2010
CD player, says error every time
get you a can of blow air spray(walmart) then insert straw inot cd **** and blow some air in cd slot from left to right..Its possible laser is dirty .Please not only do this when radio is turned off only .See if this works
8/5/2009 5:44:55 PM • Sony CDX-S2200... • Answered on Aug 05, 2009
Frozen buttons
Hi I am Vortash your radio I take it has a removeable security face , is it the type that folds down on a slide that allows you to put the cd in behind or do you place the cd through a slot in the faciure .. if it is the afformentioned then check the connecting ribbon is not damaged and cracked stopping the opperations .. if it is the latter check that the pins on the rear of the facia are clean and undamaged .. failing that there is nothing that you can do other than try a new facia or return it to the manufactures .. If you are In the Uk and your unit is under six years old then you have rights under the consumer act to get it repaired or replaced by the shop you purchased it from even if the guarantee has expired . All goods in the uk are coverd by this act so dont let the shop tell you any diffrent .. if they dont play ball report them to trading standards and they will take up your case in law . check out www.bbc.co.uk/oneshow and it is explained on there . If in the USA check out your consumer rights with the department of consumer trading .. hope this helps regards Vortash
7/4/2009 10:07:59 AM • Sony CDX-S2200... • Answered on Jul 04, 2009
Just bought car with the above cd player, &
take the face off and push the rest button if nothing happen u may have short circuit the unit when installing
7/1/2009 9:36:35 PM • Sony CDX-S2200... • Answered on Jul 01, 2009
Sony CDX-S2200 CD Player Logo
30 questions posted
Top Sony Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
 Grubhead
Grubhead
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Car Audio & Video
Most Popular Question
cdx s2200 fitting old golf
  • Car Audio & Video
